Major problem!
Old Jan 1, 2002 | 01:20 AM
blackmax2000's Avatar
Major problem!
My 2 friends and I were driving down to Savannah Ga for the new years celebration. We were in my max. We figured it would be better to take back roads b/c there would be less cops. Well I just got off a dirt road and back onto pavement when I noticed that I had No Power what so ever. I was real confused. So I pulled over thinking that I may have a flat tire or something, and to my surprise my rear rotors are glowing yellow!! The dang rear brakes had locked up. One side would have been weird enough, but both sides at the same time. We got the brakes unstuck but they still make a scraping sound when the car is moving...Has anyone else had anything like this happen, or does anyone know what it could be.
Any help would greatly be appreciated.
Kinch
Old Jan 1, 2002 | 01:30 AM
TimW's Avatar
The silent but deadly Moderator
probably..
your emergency brake cable stuck... not common, happens on lots of makes/models. Could be moisture then freezing temps. You can usually feel a lack of resistance on the emergency brake lever.
If so, dont mess with it. if you can show it stuck, then you might get warranty work. if not, they will just think you forgot to take off the emergency brake.
Old Jan 1, 2002 | 01:37 AM
Re: probably..
Is there anyway to fix it myself?
And would the ebrake just suddenly lockup in the middle of driving?
Old Jan 1, 2002 | 08:17 AM
wdave's Avatar
Re: Re: probably..
Your hand brake didn't release completely when you started the trip. At first the drag was slight and you didn't notice it. Then the rear brakes faded and you really didn't feel it. Finally the rear brakes got so hot the fluid boiled and forced the calipers closed. In addition to lubing the handbrake mechanism you will have to bleed all of the black stuff and bubbles out of the rear brakes and probably change the cinders you now have for brake pads.
Old Jan 1, 2002 | 12:05 PM
Re: Re: Re: probably..
thanks wdave, i'll go try that. I just changed the rear brake pads, so they still look fine.
Old Jan 1, 2002 | 12:07 PM
Originally posted by yo_its_ok
lubricate the cable... use white grease in spray form and play w/ E brake handle...get under the rear of your car... also its posible that your rear caliper siezed.
thanks Yo, where should I spray, the cable has a rubber covering under the car doesn't it?
Old Jan 1, 2002 | 12:40 PM
irvine78's Avatar
Re: Major problem!
Kinch
that is a major problem...
Old Jan 1, 2002 | 01:21 PM
CharlieNewbieMax's Avatar
Re: Re: Major problem!
*cough******!*cough*
Old Jul 24, 2009 | 08:29 PM
PJalst1's Avatar
I had this happen to one side(rear passenger side) last night. I haven't driven it since. Anyone know what it could be? how can I unlock it?
Old Jul 25, 2009 | 09:20 AM
foodmanry's Avatar
Da Roller Coaster!
If it is one side then it most likely is a frozen/stuck caliper.
Pull the wheel and caliper off. Try moving the piston. If you can't move it you need a new caliper. If you can move it then flush your brake system of all old fluid.
FYI..if you have a 96 Max like is in your profile, then you are in the wrong forum. You need to be in the 4th gen forum.
Old Jul 25, 2009 | 05:43 PM
PJalst1's Avatar
Thanks for the info and sorry for posting here.
user 11122324
42
Jul 18, 2022 03:35 PM
Unclejunebug
Apr 2, 2016 05:42 AM
Noela
Sep 26, 2015 08:22 AM
homewrecker
Sep 24, 2015 07:01 PM
