Changing Front passenger Driveshaft
I just picked up a reman passenger side driveshaft from autozone today and have 2 questions about installing it. I was told by a Nissan tech that the driveshafts for the LSD models with ABS differ from the regular 6mt cars. I have the transmission with the LSD. I was also told that the reman shafts are generic and might need to be modified depending on what options you have. Does anyone know if I need to do anything to the reman shaft before I can install it?
Also, after 110K miles of driving, I'm sure the shaft that is on the car won't want to easily slide pase the splines on the spider gear in the differential. For those of you that have changed driveshafts before, what did you do to get the shaft out of the transmission?
Thanks.
Thanks.
On the daughter's 2000, the passenger side was a bear. After removing the 3 bolts for the bearing retainer, the axle couldn't be pulled out as the bearing was frozen inside the bracket. Rather than removing the bracket, I used a chisel to try and turn the outer part of the bracket, but no go. I then heated the bracket and then the axle was able to be pulled out easily. Once out, I cleared the inside of the bracket of rust, and then cleaned up the outside of the bearing as I was just replacing the torn boots and keeping the OE assembly.
The driver's side needed to be pried out of the trans, but the pass side comes out easily.
See you're only about 5 miles away.
Hmmm, maybe I should pick up some Mapp gas. Or would that be to hot? Propane maybe?
I asked Dave B, and also by looking through 2 websites with part numbers lists there is only one version of drive shafts for the 03
Actually Hunterdon County, between Stockton and Ringoes, and Mapp ia what I uaed. I covered the oil pan sensor with a wet rag, and moved the O2 sensor line out of the way. Just hit it with short burts if there is a problem getting the bearing out of the bracket.
Also the axle could split apart at the joints doing this, then you'd still have to pop it out of the trans the proper way; just take the extra 30 seconds (although it's actually quicker) to use a pry bar to get the axle out.
I'm having a hell of a time getting the passenger axle out. The axle will not come out of the bracket despite using over 1 minute of heat. Should I just use more? What methods do you guys use?
I've never had to use heat to get a passenger side axle out, just basic hand tools.
If you put the bolts back in (but not all the way), you can tap on the heads of them to slowly drive the axle out of the carrier bracket.
If nothing else, you could cut a slit in between the axle and the bracket, and use a prybar or a chisel to force it away.
Search around the forums, there are many threads on good ways to get the axle out.
Are you using any sort of force, or just heating it up and tugging on it?
Heat+pb blaster and taping it with a punch to rotate the CV cup in the carrier. I've got a small gap at this point but its quite tedious. I tried using the screws in 2 ways but there is no room to fit a socket on the outside and no room to tap on the screws because the cat is in the way.
Just use a long extension and a hammer to hit them.
The converter is a lot further back, it shouldn't be in your way at all...
I ended up getting it out by slowly striking the CV with a blunt object at an angle which caused it to rotate and slide out with each blow. It took about 2 hours to get it out but its out. I'm going to buy an air hammer tomorrow....
Just for future reference:
Heat then a chisel between the bolt flanges. First use heat on the engine side of the bracket, then a very sharp chisel between the bracket halves. When it starts to separate, place the chisel between the bolt flanges and drive upwards. Go easy and the bracket will continue to separate. After I had it apart, I cleaned the rust off the outer shell of the bearing and all the rust from the inner part of the bracket with emery cloth. Used ant seize when it was put back together.
carguy96
20
02-06-2021 06:21 AM
CAN-Other LF: Worn / Broken Parts
george__
08-18-2015 07:06 PM
RealityCheck
08-05-2015 06:18 AM
