The Auto Trunk Lock Kaput
Old Jul 21, 2009 | 04:10 PM
Roymg's Avatar
Hi all,
I have a 2003 Max and my auto trunk release stop working. The relay will energize but the lock won't open.
To anyone with a diagram, is the fuel door and lock mechanism electrically on the same circuit? I think both of these devices use the same 15a fuse. If that's the case then I have a bad electric lock that need to be replaced. It looks like the solenoid is integral to the mechanical lock?
Thanks,
Royg
Old Jul 21, 2009 | 04:28 PM
SoulEater's Avatar
i think your switch is locked up. pop up your trunk and look at the bottom where you can see the mechanism. there is a switch on it and is right at the actuator.
Old Jul 21, 2009 | 04:48 PM
Roymg's Avatar
K..I looked at the lock and the mechanical latch. The latch is fine and I can open the lock with my key.
This switch on the actuator, are u talking about the key lock?
Thanks,
Roymg
Old Jul 21, 2009 | 04:57 PM
SoulEater's Avatar
Thanks,
Roymg
When the switch is locked, the only thing you can open your trunk is by using your key. the switch is where i circle yellow http://s204.photobucket.com/albums/b...DSC00519-1.jpg
Btw, you dont need to use bold and over size sentences. I CAN READ IT VERY CLEARLY
Old Jul 21, 2009 | 05:08 PM
Roymg's Avatar
OOOkay....I'll check it out as soon as I can get the photo to download.
Thanks much,
Roymg
Old Jul 21, 2009 | 05:14 PM
SoulEater's Avatar
The easiest way to find the switch is by looking from the side. not from the top
http://s204.photobucket.com/albums/b...=1248221522553
Old Jul 21, 2009 | 05:48 PM
Roymg's Avatar
Bingo...Got your picture and figured it out that the solenoid is located on the bottom part of the latch and not on the key lock. The latch had slip down to were it was not touching the above lock mech. This happen this weekend while caring some yard equip in my trunk using a bungee cord to hold the lid but I hit a bump and the top lid came down and I suppose cause the latch to slip. I did not know that until today.
You were right on and I guess u have seen the problem before.
Thanks again for your help and time
Roymg
Heck..looking back, there is a slot built in where u can put your finger on the lock mech. and u don't have to remove any trim to get to it. Duh!!
Roymg
Old Jul 21, 2009 | 05:52 PM
SoulEater's Avatar
glad can help you out
Old Jul 22, 2009 | 06:28 AM
MysticCBR's Avatar
hope this doesnt happen to me i took my lock out of my trunk for a back up camera ...
Old Feb 24, 2010 | 03:26 AM
tarantula212's Avatar
I used this today on my new to me 2000 SE. Thought it was broke, Thanks for the link. Glad I found you guys.
Old Feb 24, 2010 | 03:29 AM
Gemner's Avatar
i had a keg one time and bend that lever back to the point where it refused to open the trunk and now for some reason it happens a lot more often than it ought to
REDinLV
Aug 15, 2024 12:30 AM
BobTX10
Oct 7, 2015 08:43 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
