HID conversion issues. help?
Old Jul 24, 2009 | 05:21 PM
anomaly117's Avatar
So i have a cheapo ebay conversion kit. (no projectors... ftl, i know) Recently my left headlight has been giving me issues. It'll cut out randomly, and sometimes when I hit bumps, and when i turn the headlight switch off and back on, 99% of the time it comes right back on, but sometimes flickers a bit at first. I checked all connections, they seemed solid, and questioning the ballasts, i swapped them. Same problem, same left light.
Not knowing where else to turn while i still had daylight, I got in the zone, and asked the kid that worked there. He seemed to know what he was talking about, and said he solved the same problem in his car by cutting the cheapo watertight connectors on the + and - wires coming off the bulb, and soldering the connection instead, cuz he said the connectors are junk. I did that, and the problem is much less frequent, but still is happening. Left headlight every time. Any ideas of what else i should check??
Old Jul 25, 2009 | 01:59 AM
Mr. Blue Sky's Avatar
If yours came with a harness, I guess you could double check if the ground wire is properly grounded on the harness(maybe sand down the grounding point a bit). That is the only thing I can think of
Old Jul 25, 2009 | 12:22 PM
anomaly117's Avatar
yea, ground is the first thing i checked. wouldnt both lights flicker out if it was the ground though?
Old Jul 25, 2009 | 10:21 PM
quite possibly. they are running off the battery right?
Old Jul 26, 2009 | 12:58 AM
Sammy Z's Avatar
I have a question on the ABS light in a 2001. I read where you can reset it if you ground pin 9 three times in 12 seconds, but mine won't clear. What am I doing wrong?
Old Jul 26, 2009 | 06:38 AM
anomaly117's Avatar
:matt93se: post this in the "i'm new and have a question" thread. not in mine
Old Jul 26, 2009 | 06:39 AM
anomaly117's Avatar
yea, but my point is i only have a problem with the one light. not both. thats why i dont think it could be the ground
Old Jul 27, 2009 | 07:25 AM
Calcvictim's Avatar
have you tried swapping bulbs to see if it follows the bulb, this way you know that the balast is eliminated, and you can narrow down whether it's the connection somewhere or the bulb itself
Old Sep 24, 2009 | 02:15 PM
2kMAXIMAGXE's Avatar
Hey anomaly117 did you ever find out what was causing this problem,
I am having the exact same problem on my 2000 Max,
The left headlight is giving me the same symptoms as you described.
I thought it was the ballast, I made the seller send me a another new ballast, worked for a week and went back to the same problem.
Please let me know if ever got the lights to work fine,
Thanks a lot,
Old Sep 24, 2009 | 09:15 PM
anomaly117's Avatar
figured it out, but i need to get a new kit. the terminals on the control module that supply power to the right headlight have that lovely bluish white oxidation all over them; leading to an inconsistent connection. Ive done every thing i could think of/read about to try to get them clean, but alas.
check those terminals, and clean em if you can. then protect them with dielectric grease to prevent it from happening again. maybe theres still hope for yours. gl.
D Mason
Jun 21, 2016 04:43 AM
Calabar
Oct 5, 2015 09:57 PM
leatherneck
Sep 30, 2015 09:16 PM
Vistance
Sep 17, 2015 05:17 AM
