how do u wire subs into the bose system
Old Jul 29, 2009 | 09:16 PM
PatKeo6373's Avatar
I have a set of JL W6's just sitting in my trunk. i was told i can pick up the remote wire and RCA wires straight from the stock amp in the trunk. Has any one done this? Or is this the hacks way to wire them in.
Old Jul 30, 2009 | 06:48 AM
AEMAXIMA01's Avatar
check audio/electronics subforum...
Old Jul 30, 2009 | 03:28 PM
maxgen5's Avatar
I have the Bose system in a 2000 Maxima and I added a JL10W3 powered by a Fosgate 300Watt amp by using a PAC line level adapter connected to the right and left front speaker inputs before it goes into the Bose amp. I'll have to check the wire colors later.
modifiedlife.com/car-stereo-radio-wiring-diagram-2000-nissan-maxima/
2000 Nissan Maxima Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Yellow
Radio Switched Ignition 12V+ Wire: Purple
Radio Ground Wire: Chassis
Radio Illumination Dimmer Wire: Red/White
Radio Antenna Trigger Wire: Green/White
Left Front Speaker Wire (+): Green
Left Front Speaker Wire (-): White
Right Front Speaker Wire (+): Blue/White
Right Front Speaker Wire (-): Blue/Yellow
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Brown/White
Right Rear Speaker Wire (+): Blue
Right Rear Speaker Wire (-): Pink
Good Luck!
Old Jul 30, 2009 | 03:48 PM
bigpopaj369's Avatar
for best results this should of been posted in the audio and electronics forum but u need a line out converter for those rca's u can get them cheap i did mine before i got rid of the bose HU by wiring a LOC from the stock sub and tapped the remote wire from the back amp as well. do u have an aftermarket hu? or bose? if aftermarket u wont need a LOC if ur HU has preamp outputs
Old Jul 30, 2009 | 04:15 PM
Maxima112's Avatar
Curb Rash Repair 100 a wheel
i have a line out converter for sale if you want it i used this to add only a sub. Line In from the sub, RCA out to your amp and you're done. you can adjust gain too if you want.
$20 shipped.
Old Aug 3, 2009 | 03:46 PM
PatKeo6373's Avatar
ya i have a stock navi so i will need to buy a LOC
Old Aug 3, 2009 | 03:58 PM
papo99's Avatar
if you have the money buy a jl audio cleansweep its the best and it has and ipod hook-up i ran my 13w7 with my stock radio
9aj9
Apr 5, 2020 12:11 AM
A32goldylocks
Sep 2, 2015 06:39 AM
