Engine Cover Emblem Needed
Old Aug 3, 2009 | 06:15 PM
Skier's Avatar
OK, after exhaustive search, I have to come out and ask the question. Does anyone have an 03' engine cover emblem, or know where they can be purchased new? I went to courtesy parts etc., and they have every emblem accept the one I need. I just repainted my cover, and it came out so good that I can not reuse my old emblem, or even repaint it. It is badly damaged and it will not do justice to the repainted cover.
Thanks in advance...
Old Aug 3, 2009 | 07:33 PM
Rochester's Avatar
For whatever reason, Nissan doesn't part out the engine cover emblem on the Maxima. However, they do part it out on the Altima SE, and it's the identical part, with the same part number stamped on the back. The last 5 characters are 5Y710.
Try again with Courtesy Parts. You can buy it for under $20.
^^ Here's the burger, with the lettering painted red. Looks awesome in red, IMO.
Old Aug 3, 2009 | 07:36 PM
Col Ronson's Avatar
ah you mean that lovely hamburger? how about putting an infiniti logo to upgrade your pimp status haha
Old Aug 3, 2009 | 08:04 PM
03VQMAX's Avatar
Engine cover emblem is about $25 at Nissan, Part # 14048-5y710. Ordered one as well when I painted my engine cover.
Old Aug 4, 2009 | 05:18 AM
Skier's Avatar
Thank You all for your response and input. It is much appreciated. I recently got hooked on engine bay detailing and will post a pic when the cover is done. I guess being obsessed with keeping the rest of the car clean was not enough to satisfy my type-a personality.
Thanks Again...
Old Aug 4, 2009 | 05:28 AM
Rochester's Avatar
Thanks Again...
Glad to help.
Regarding the engine cover... here's another tip: the 4 bolts on the cover are black, 6m hex-heads. (Apparently, 6m is a very common thread, all over the Maxima.) Anyway, they're probably pretty corroded by now. Grind the corrosion off the bolts with a desk-mounted wire-wheel, then paint them black. I used flat-black stove paint... they look fantastic. Better than new.
Old Aug 4, 2009 | 09:25 AM
Skier's Avatar
Already repainted the hardware Rochester (good suggestion though), but I have access to stainless steel hardware at work, so I may see how that looks against the blue color I put on the engine cover.
Is there anything else you have painted under the hood?
I am thinking the upper IM could use some sprucing up, but that would require a hiogher temp rated paint.
Old Aug 4, 2009 | 11:05 AM
Rochester's Avatar
Is there anything else you have painted under the hood?I am thinking the upper IM could use some sprucing up, but that would require a hiogher temp rated paint.
Little things... the upper radiator brackets, the hood switch bracket, replace all the screws and washers along the front with stainless or black.
The 3.5 engine cover is pretty big and visually dominates. As long as you paint or replace rusted bolts, really all you need to do is keep the bay clean for it to look sharp.
Things like having an alternator casing bead-blasted and painted to match... those days are long ago and nearly forgotten for me. Pick and choose your obsessions, I suppose.
Old Aug 10, 2009 | 05:40 PM
Skier's Avatar
Rochester, Pics of finished engine cover, thanks again!
[IMG]G:\Engine Cover[/IMG]
Old Aug 10, 2009 | 05:45 PM
Skier's Avatar
So much for that attempt... can anyone see what I am doing wrong posting pictures? I followed the "how-to" instructions....
Old Aug 10, 2009 | 06:20 PM
zero2sixtyZ's Avatar
You embarrass me.
They need to be hosted online first. Try putting it on imageshack or photobucket first, then putting the hosted image url in that spot.
Old Aug 10, 2009 | 06:28 PM
Ghost_54's Avatar
You are trying to post a picture from your G drive and it has to be loaded up to a web hosting account such as photo bucket once you have loaded it there you will be presented with the linking code which you then copy and paste into your post.
Old Aug 10, 2009 | 07:14 PM
Skier's Avatar
Thanks... Lets try again...[IMG][IMG][/IMG][/IMG]
Old Aug 11, 2009 | 05:34 AM
Rochester's Avatar
Skier, although I'm not too keen on metallic blue, from your picture here it sure appears that you did a great job painting the cover. Looks very detailed. Your bay looks very clean, too. Nice.
What's next under that hood...? A FSTB, perhaps?
Old Aug 11, 2009 | 06:19 AM
Rochester's Avatar
Ghost - not that it matters, but out of curiosity... why did you upload my red-letter burger image to photobucket and re-post it?
Old Aug 11, 2009 | 09:21 AM
Skier's Avatar
Well, it was originally color matched to the car, but I found that quite boring. I wanted something that would look custom, and "pop" when the hood is opened. This was all practice anyway for some work I need to do to a console piece that needs repainting. I had never painted anything before so it was a confidence builder and a way to learn the technique.
No FSTB for me. I want to keep the Max clean and sharp, but I am looking to get a summer car in the spring. Perhaps a pre-owned 350Z. If I do, my motorcycle is going to really feel left out next summer.
Too many toys, so little time, never enough money…
Thanks again for the help guys....
Old Aug 11, 2009 | 10:28 AM
Augustus Maximus's Avatar
Nice to see an engine compartment with that all too often cone shaped air filter. Maxine is a virgin and so she will remain...untouched just highly maintained at any cost.
Old Aug 11, 2009 | 01:25 PM
tookrzy4u192's Avatar
ill be needing an emblem too when i finish my engine cover.. just too lazy to sand it down lol
urs came out nice though.. looks real clean
Rochester's Avatar
Well, that was just silly.
For that matter... you named your car? And you gave it a chick's name?
Yikes!
Old Aug 12, 2009 | 05:39 AM
Rochester's Avatar
Originally Posted by onefifth
my emblem melted from the heat of the engine. has that happened to anyone elses? your bay is so clean!
If my "melted" you mean, the chrome plating on the plastic separated, wrinkled and started peeling... then yeah, that happens to everyone eventually.
Old Aug 12, 2009 | 10:14 AM
Skier's Avatar
Thank You. I have this "type A" disease. I have an 11 year old motorcycle that could literally go back on the show room floor. It is easy to keep the bay clean once you get it clean. Buy the emblem at the dealer. It only cost me $19.60. I plan on removing the engine cover for the winter months so it stays in nice shape.
Old Aug 12, 2009 | 03:15 PM
Ghost_54's Avatar
in an effort to help the one poster with how to upload a pic, it has to be from a web hosting site and it appeared that he was attempting to load from his own G drive, Yes I could have simply said to right click on your picture and select properties so he could see that you were using a web host service, but I didn't ... my intention was to help not offend you or any of the other postings ... sorry about that.
Old Aug 12, 2009 | 05:54 PM
Wheelie King's Avatar
The cover looks great. What kind of paint did you use?
I just replaced my nissan battery with an aftermarket battery. The original looked very cool. Maybe you can consider that if you ever need to replace the battery you have now.
Old Aug 12, 2009 | 06:40 PM
Skier's Avatar
Ghost 54: You did not offend me. I needed the help posting the pic... Thanks
Wheelie King: Thanks... I used "Duplicolor" primer (2 coats), paint (3 coats), and clear (4 coats)...
Old Aug 12, 2009 | 08:31 PM
Rochester's Avatar
No, I don't mind, Ghost. If the photo is on the web, have at it. I was just curious.
I love that red-letter look. Very glad I tried it out.
Old Aug 13, 2009 | 05:30 PM
SoonerFan's Avatar
Cletus
i got a new one from dave b
Old Aug 13, 2009 | 05:59 PM
th3shuck's Avatar
Good looking engine bay you got there.
Old Aug 14, 2009 | 05:44 AM
Rochester's Avatar
Most of your reservoir caps seem to be gray, instead of the original yellow.
Did you paint them?
Old Aug 14, 2009 | 03:12 PM
SoonerFan's Avatar
Cletus
Did you paint them?
yes
Old Aug 14, 2009 | 04:56 PM
Rochester's Avatar
yes
Interesting idea.
So... you didn't paint your dipstick?
Old Aug 30, 2009 | 12:09 PM
Rochester's Avatar
how is the Nissan emblem attached to the engine cover? Does it just pry off or do I need to remove the engine cover to take it off? Mine looks horrible.
Remove the cover, it's 20x easier that way. Sit yourself down in a comfortable position. Like the kitchen table.
The burger is attached with a very thick adhesive pad fitted to the entire underside. In addition to that, there are 2 post holes in the middle. You have to be real careful and patient when prying it off. Take care not to notch the edges of the circular depression when doing so. (Hard not to do.)
The new emblem comes with this adhesive pad already attached, ready to peel and press.
Old Aug 31, 2009 | 05:36 PM
Mangi1's Avatar
paint engine cover...what colour?
Hey all,
I have a black 03 Maxima. Can I get suggestions what colour to paint the plastic engine cover? It is gray and looks like crap. I want some punch. Red? This blue is ok.
Thanks,
Chris
Old Aug 31, 2009 | 06:01 PM
Ghost_54's Avatar
My car is Sterling Mist and I had to do some bumper stone chip repair, so I picked up an aerosol spray can of KT3 from my local Napa Parts store and once I had finished with the bumper repair I pulled my engine cover and taped off the large black lettering and the 3.5 as well as the Nissan engine cover Emblem and repainted mine the same Sterling Mist
Old Aug 31, 2009 | 07:36 PM
phxgold's Avatar
whos up for a wire tuck on the max?
smplyamzng
Dec 13, 2015 01:19 PM
TonyJr
Aug 20, 2015 12:14 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
BassAddictJ
Aug 4, 2015 11:38 AM
