Will man motor mounts fit auto cars.
yes they will, any manual motor mount from 95-03 will work. 5spd or 6spd. I woould recommend buying a set of manuals at a wrecker and buying the energy suspension motor mount inserts, press out the liquid filled garbage and press in the urethane. You will never need to replace them again.
To the OP which motor mounts? Theres four, two on the sides and two on the bottom on the cross member
no, I have helped 3 guys do this to an auto and there are no check engine lights. And no point in doing the side mounts, just do the front and back lowers. There is no pressure on the upper mounts, they rarely wear out.
knight_yyz help me and replaced my front and rear mounts and the smaller upper and lower bushings, my car is an 03 and had the electronic front one, and I have no engine codes from the swap out, The ES bushings have really helped with getting rid of wheel hop.
I see my trans mount has some play in it so why wouldn't filling it with urethane help?
i have an auto and my pass side upper mount is cracked. I am going to get a cheap ebay mount and fill it with poly to make it solid
http://cgi.ebay.com/ebaymotors/NISSA...Q5fAccessories
ok guys got the old mounts of but looking at it seem that if i press out the old mounts the new es ones are to small or do i just burn the old rubber out, or do i need to buy manual motor mounts?
I'm still waiting for an answer. I can't do my front or rear mounts cause my support beam is permanently attached to the lower rad support, and the rubber is still centered in the mount, and was just gonna do the sides along with the NWP anti wheel hop new whatchamacallit thing they released...
I have electric mounts in great condition.I swapped them when i did my manual swap. I replaced the mounts about a year ago. PM me an offer. I have both for tranverse link. And no the mount will not throw a code if you do not use the electric mounts.
That sound like the engine is hitting the firewall/fender over bumps, it was a thumpy/rumbling sound. It progressively got to the point it was doing it over all kinda bumps. They inspected and showed my the front and rear mounts, no crack etc fine. The passenger side one was really cracked/worn and the drivers side was on its way out.
I remember you being one the 1st guys to realize that that horrible noise was coming from the side mounts(paticularly the front passenger 1) instead of the front and rear mounts. My mechanic said he has fixed several 02 and 03 Maxima's with owners thinking the front and rear are shot and it was the side mounts shot once he broke them down.
vingodine
45
May 21, 2016 12:46 PM
Rage Maximus
Sep 3, 2015 12:26 PM
CAN-Other LF: Worn / Broken Parts
george__
Aug 18, 2015 07:06 PM
