MOOG ball joints and rod ends
Old Aug 7, 2009 | 10:28 AM
Whitebread's Avatar
I bought some MOOG rod ends and tie rod ends for the front suspension of my 2003. There is grease in the grease port where the check valve goes but none in the boot. Do I need to add more?
Old Aug 7, 2009 | 10:41 AM
djfrestyl's Avatar
Suspension Yoda
Never a bad thing to add grease. I have installed without adding additional grease without issue.
Old Aug 7, 2009 | 12:59 PM
Whitebread's Avatar
Any recommendation as to grease? I bought a mini grease gun and some of the generic coastal grease from vatozone.
Old Aug 7, 2009 | 03:05 PM
djfrestyl's Avatar
Suspension Yoda
Lol Vatozone. That should be fine.
Central NJ? I'm in East Brunswick
Old Aug 7, 2009 | 04:03 PM
Whitebread's Avatar
About 45 minutes from me, I live in Pennington.
Got the new ones pressed in no problem. The check valves on the other hand are either cross threading or don't screw in very far. Are they designed to have about 2 turns of thread showing or am I cross threading them?
Old Aug 7, 2009 | 04:23 PM
djfrestyl's Avatar
Suspension Yoda
They don't need a whole lot of threads, 2 is fine.
Old Aug 7, 2009 | 06:18 PM
ridinwitha35's Avatar
vatozone, lol
Hey I got a cheap grease gun & some coastal grease too once I put my Moog stuff in (tie rods, tie rod ends, swaybar end links, swaybar lca bushings). Been going crazy with it...all I need now are some Moog balljoints & bushings & if they made 'em, struts, and can say I have a Mooged suspension. But I still have this damn tramlining/bump steer/alignment issue!
Old Aug 7, 2009 | 08:07 PM
Whitebread's Avatar
My car bumpsteers badly also but I've yet to replace the worn struts or get an alignment. The vibration issue persists but it's not as bad as before. And the car drives much better now. Ridin, you might have something that is slightly bent. Maybe replace the LCAs?
One more step and hopefully I can put this problem to rest.
And yes, Vatozone.
litch
123
Jan 4, 2024 07:01 PM
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
BobTX10
Oct 7, 2015 08:43 AM
