CV shaft nut will not stay tight
A few weeks ago I changed the axle on the passenger side and installed the new castle nut that came with the axle and torqued it to 250 ft-lbs. A week later the wheel bearing on that side went bad. I had a new one pressed in with the old hubs. At the time it did not occur to me that it might be prudent to install a new one but the tech at the service center said the hub looked fine.
The load dependent vibration that was occurring before the wheel bearing change is still present but is much less pronounced. So today while doing a rotation, I rechecked the torque on the castle nut on the passenger side axle spindle and found it required another 1/4 turn to reach 250ft-lbs after 30 miles of driving (and I torqued it correctly yesterday). Retorquing the nut did not have a huge effect on the vibration.
The vibration is the only problem I still have, no more tram lining, wheel wondering or mushy steering.
Does anyone have any recommendations as to what I can do to fix this problem? Torque the nut past 250 ft-lbs and use thread locker? Should I replace the CV, hub and get another nut? I'm running out of options and time before I have to pack up and go back to school.
Edit:03 maxima FSM says 188-245 ft-lbs. It seems a few 5.5th geners have had a similar problem and it usually was wheel bearing/hub/drive shaft related. I've also heard of the 04 6th gen guys have loose wheel nuts that required torquing beyond factory spec to get them to stay on.
knight_yyz
11-01-2015 01:34 PM
