can you adjust headlights right to left ?
Old Aug 25, 2009 | 08:17 AM
wish2345's Avatar
i know you can adjust the headlights up and down but can they be moved right or left ? i have a 5.5gen if that makes a difference
Old Aug 25, 2009 | 10:00 AM
LA02MAX's Avatar
Without modification to the reflectors, no. And that would be very difficult. Why do you need to do this? If the beam pattern isn't wide enough for you, there's always a projector swap...
Old Aug 25, 2009 | 10:03 AM
wish2345's Avatar
was just wondering. thanks for your imput. i thought that would be the answer
Old Aug 25, 2009 | 02:59 PM
03VQMAX's Avatar
On the 5.5 headlamp there is a bolt on the left corner looking at the headlamp from the back of it, you can move it left to right, but it won't make it wider i believe.
Old Aug 25, 2009 | 04:40 PM
e-subliminal-2's Avatar
How would you adjust up and down? Tried searching for it but every link is DEAD... ftl..
Old Aug 25, 2009 | 04:48 PM
03VQMAX's Avatar
Should be the main adjusting ****, its white and has a 5/16 hex head type of ****, towards the bottom of the lamp.
Old Aug 26, 2009 | 07:42 AM
MillionBlades's Avatar
mine are both kinda broken. the passanger side is even worse I tried a philips screw driver to adjust but I moves very little not only that but one side in higher than the other... any suggestions on how to adjust them if the **** is not moving without spending $300+ on a new set???
tarun900
19
Dec 20, 2021 06:57 PM
bigfrank
Oct 1, 2015 12:51 PM
leatherneck
Sep 30, 2015 09:16 PM
