how do i replace teh lights in the instrument cluster + climate control
Old Aug 25, 2009 | 01:50 PM
Jordan22's Avatar
any one know what size bulbs i need to order for both the climate control and gauges(instrument cluster) i would like to swap to blue L.E.Ds. also what do i got to do to take everything apart??? pics would be helpful too THANKS GUYS
Old Sep 11, 2009 | 10:56 AM
mrm121's Avatar
I'm looking, too
I am doing the same thing. I am doing as many of the interior lights with LEDs as I can. Just plain white though. If you find anything on the cluster lights or the climate control, let me know. I want to replace the cluster ones and the A/C lights need to be replaced since one of them has stopped working. I am doing the dome light, courtesy lights, license plate, trunk cluster lights and climate control. Where are you getting your LEDs? I am looking at superbrightleds.com I think. Resellerratings.com has good reviews on them...
Let me know!
Ryan
Old Sep 11, 2009 | 11:20 AM
nzelinsky's Avatar
I think most of them are 194's... I ordered a 10pack of them on ebay yesterday. But those are for sidemarkers/courtesy lights etc etc.... Im not so sure about the gauges, but I will be doing those soon too
Old Sep 11, 2009 | 11:21 AM
bigpopaj369's Avatar
same here i want to match my new HU. ive searched a few times never really got a correct answer on what bulbs they are
Old Sep 11, 2009 | 12:06 PM
mrm121's Avatar
Here is what I have found: (from another forum: http://www.b15sentra.net/forums/arch.../t-169400.html)
#74 bulbs for the guage cluster...
Just changing out the bulb is really easy, only 5 screws to remove:
1. Tilt your steering wheel all the way down
2. Look at the plastic bezel around the gauges, Remove the two Phillips screws on the top.
(It can be tricky getting this peice out with the steering wheel in the way, I had to carefully bend it to remove/reinstall it.)
3. Now you see the white gauge cluster, with three phillips head screws. one on the top, and one on each side. remove them.
4. Gently pull the cluster toward you, and face it downwards on top of the steering column.
5. You will see where the base of the light twists into the cluster, untwist and remove the one you want to replace.
6. Swap the "base" of the burn out bulb to the new bulb, they "wedge" into the base.
7. Screw the bulb back in, re-assemble with the 5 screws you removed. Done.
same goes for installing the #74 l.e.ds, but if you want to change the color and still see your gauges at night, you'll have to pull the whole cluster apart and do some sanding.
Old Sep 11, 2009 | 12:08 PM
mrm121's Avatar
LEDS Needed
2001 Maxima
#74 - guages
194 - sidemarker
7443 - stop
921 - backup
168 - lic plate
DE3175 - dome
Old Sep 11, 2009 | 12:29 PM
nzelinsky's Avatar
I found a write up the other day that mentions a calibration procedure for the needles. I wouldnt pull everything out until you read that.... the guys on the forum you just quoted had problems with thier needles.... Metal maxima has the writeup on his cardomain page.
Also, I think its easier to use a paint thinner than to sand the backing off the cluster.
Old Sep 11, 2009 | 12:32 PM
nzelinsky's Avatar
http://www.cardomain.com/ride/758364/2
Old Sep 11, 2009 | 01:19 PM
qstick777's Avatar
what about the HVAC (slider, not auto) bulbs? My burnt out a while ago - figured I would change them when I do the HU, which isn't anytime soon, but since the thread is active I'll write the info down for later use.
Old Sep 11, 2009 | 01:26 PM
mrm121's Avatar
Nice
I like that write-up and definitely think the calibration needs to take place! I think I will still just go with the standard #74 bulb to keep things uniform and keep from having to tear into things, but I am just doing white. If you are doing a color that may be a good idea so you have the extra light.
Old Sep 11, 2009 | 01:35 PM
nzelinsky's Avatar
tear apart the centre console and rip out all the bulbs and wires... leave nothing behind. then just throw new wireless bulbs in anwhere, jam them in every crevice and you're good to go!
Old Sep 11, 2009 | 06:44 PM
danger300z's Avatar
http://forums.maxima.org/5th-generat...ghts-leds.html
http://forums.maxima.org/5th-generat...sion-pics.html
http://forums.maxima.org/5th-generat...es-anyone.html
those are a few search is your friend!!!!
Old Sep 11, 2009 | 07:01 PM
Ghost_54's Avatar
http://www.torontomaxima.com/forum/v...&t=1314#p20014
You can also PM knight_yyz (member here as well) should you have any questions as he has swapped out just about every bulb in the Interior
Old Sep 12, 2009 | 07:27 PM
The6spdMax's Avatar
Is this the PLCC-2 leds for climate control?
Old Sep 13, 2009 | 10:36 AM
mrm121's Avatar
Map Lights
also:
Door lights - 161
Map lights - 1895
Old Sep 13, 2009 | 12:21 PM
knight_yyz's Avatar
Toolie
climate control are neo wedge bulbs, cluster bulbs are #74
Old Sep 13, 2009 | 03:52 PM
Ghost_54's Avatar
Would the neo wedge bulbs be the Twist & Lock type
Old Sep 13, 2009 | 05:40 PM
knight_yyz's Avatar
Toolie
http://cgi.ebay.com/ebaymotors/2pcs-...Q5fAccessories
Old Sep 13, 2009 | 05:47 PM
thats awesome im going to grab some of these too! ive wanted to match my climate control to my hu for the longest time. i found these http://www.superbrightleds.com/cgi-b...next=50#NEOb-x not to threadjack but my question is which size should i get?? 3,4,5mm? does it matter? they are the NEOx wedge ones
Old Sep 14, 2009 | 06:41 AM
alright anybody on this^^^^^ im trying to order these today half my climate bulbs are out
Old Sep 14, 2009 | 08:07 AM
ksd35's Avatar
Are the neo wedge bulbs the same on the auto and the manual climate control?
Old Dec 5, 2012 | 02:47 PM
mikeymouse1995's Avatar
If I have a GLE and replacing my guage cluster with red LEDs, will I have to sand it down..
Old Dec 5, 2012 | 03:10 PM
Amerikaner83's Avatar
Love that you searched...but there are some newer LED threads that are much more relevant today then back in 2009
To answer your question, no you should not have to sand them down if you get the 74 (gauge cluster) LEDs...just be sure and get the 74-xHP3 (x is the color variable) from SuperbrightLEDs.com
http://forums.maxima.org/5th-generat...ad-w-poll.html
and more on topic for you:
http://forums.maxima.org/5th-generat...one-works.html
Old Dec 5, 2012 | 03:18 PM
rebelhell's Avatar
I wouldn't tear the cluster apart to sand it down before you saw what the red LEDs looked like first. There is a thin blue film that might give you problems. Here's my cluster with cool white LEDs. You can see how it gets a light blue tint from that film.
Old Dec 5, 2012 | 03:19 PM
In one of the threads I linked, someone has red in their cluster and it looks just fine.
Old Dec 5, 2012 | 03:23 PM
rebelhell's Avatar
I wasn't at all saying it wouldn't, I was just saying I haven't tried it but I certainly wouldn't risk pulling the cluster apart before I did. If the LEDs are bright enough I doubt the tint would make that much difference. Just figured he should be aware that it's there.
MikesChevelle
Mar 2, 2021 11:32 AM
dr3am
25
Oct 22, 2015 08:53 PM
rtirbany
Sep 8, 2015 11:46 AM
homeyclaus
Sep 3, 2015 06:15 PM
Stelianos
Aug 19, 2015 02:07 PM
