Fogs on with High Beams
Old Nov 28, 2001 | 04:28 PM
Greg's2kGLE's Avatar
Has anyone rewired the foglights to stay on with the high beams? If so, can you explain how you did it? Thanks!
Old Nov 28, 2001 | 04:45 PM
RussMaxManiac
Re: Fogs on with High Beams
LOL! I can't even see my fogs on anymore, no need for them! :P
Old Nov 28, 2001 | 04:54 PM
Re: Re: Fogs on with High Beams
You and your HIDs
Old Dec 3, 2001 | 08:07 PM
Pat DiPersia's Avatar
After looking at some wiring schematics, it looks like Nissan designed the ground wire on the fog lights to be cut when you hit the high beams. Play around with those ground wires and a multi-meter, see if you can find the one that's cut while the highs are on and re-wire it to a permanent ground source. This won't affect any other operation of the fogs that I could see as far as when they're on/off, just the high-beam operation.
Old Dec 3, 2001 | 09:45 PM
xydavid's Avatar
I think the trick was to wire it to be powered off the clearance/parking lights instead of the low beams. Sorry I don't remember exactly what, but I do remember a write up being on someone's site or in the forum. You might be able to find reference to it in a search if the message is still avail.
Old Dec 4, 2001 | 06:10 PM
Close. Wiring the fogs to the parking lights instead of the low beams will only make them work with the parking lights and low beams. Still will not fix the high beam issue. You'll need to get around that ground wire first.
Old Dec 4, 2001 | 11:11 PM
serin's Avatar
why not just ground it to the chassis? the 12v is switched to come on the lows right? so that should still allow it function with lows and highs.
Old Dec 7, 2001 | 12:33 AM
xydavid's Avatar
My bad. I just did some reading. THe parking light rewire was for ppl to get fogs on without having to have the lights on.
It does appear as if wiring them to stay on with the high beams would be a bigger deal than it seems.
The simplest instructions I could find to do it were from sixman, which I've pasted below. but there were no further posts confirming if it worked:
The combination light switch is why the fog lights will not operate with hi-beams on. There is a switch that connects terminal 7 (connector E100) to terminal 5 (E100) that breaks the ground connection when the hi-beams are on. If you take the Green/Yellow wire off the fog light switch connector (E98, terminal 32) and run that to ground instead of to the lighting switch (E100, terminal 7) you will bypass the hi-beams switch that cuts off the fog lights.
Be aware howvere, to get to the connectors on the combination switch, the driver's side airbag and steering wheel must be removed.
one post I read said it was designed this way to keep the load on the wires low. Not really sure if that would really be an issue.
Old Dec 26, 2001 | 09:04 AM
hakk97se's Avatar
How bout with 4th Gen?
Is this the same on the 4th Gen max's? I think the "fogs" look cool and would like to have them on in all three modes, parking lights, low beam, and high beam. As such I was thinking about running the fogs through a 12V switch in the car, bypassing the factory switch so that I can just manually turn on or off the fogs. Not sure how to go about this, but it was a thought. I really don't like the idea of having to remove the steering wheel/airbag to get at a simple electrical source.
Ugh.
- Jon
Old Dec 26, 2001 | 09:48 AM
RussMaxManiac
Re: How bout with 4th Gen?
Ugh.
- Jon
The 4th gens stay on with highbeams. They changed something in the wiring that now makes them turn off now.
Old Dec 26, 2001 | 01:38 PM
Re: Re: How bout with 4th Gen?
Are you sure about that? Hmm I never noticed that on my brother's 97 SE...
Old Dec 26, 2001 | 02:40 PM
RussMaxManiac
Re: Re: Re: How bout with 4th Gen?
Yep, after I rewired my 96 and 98, it stayed on.
Old Dec 26, 2001 | 02:55 PM
emax02's Avatar
Re: Re: Re: Re: How bout with 4th Gen?
Ya, after you rewired it. A stock 4th gen's fog lights shut off when the high beams are on.
Old Dec 26, 2001 | 03:41 PM
Y2KMaxGXE-R's Avatar
are you trying to say that from the factory, when you turn on your high beams, your fogs are off? first time I hear smthg like this..
Old Dec 26, 2001 | 04:20 PM
Your fog lights stay on with your high beams (from the factory)? My '00 GLE doesn't and neither does my friends '00 SE. I have never seen the fog lights stay on with the high beams before.
Old Dec 26, 2001 | 06:26 PM
hakk97se's Avatar
4th gen fogs
It's true, the 4th Gen stock fogs from the factory shut off on the high beam. They only turn on with low beam, nothing else. I have found a detailed webpage with pictures and stuff on how to rewire it. Pretty simple. Thanks.
Old Dec 26, 2001 | 06:32 PM
RussMaxManiac
Re: Re: Re: Re: Re: How bout with 4th Gen?
Yea but even after rewiring the 2k it still shuts off.
Old Dec 26, 2001 | 06:39 PM
TPI Monte SS's Avatar
I know in NJ (probably most other states too), it's illegal to have the high-beams on with the fogs. Even when you add in an extra set of PIAAs, Pilots, or whatever, they're supposed to be shut off when the high's come on, or they'll fail you at inspection.
Just remember that before you guys mess around with the lighting.
SSeeya,
Steve Ragusa - www.bowtiepower.com
'00 Maxima SE and a resto-modded '85 Monte Carlo SS
Old Dec 26, 2001 | 07:21 PM
Re: Re: Re: Fogs on with High Beams
SSeeya,
See now I didn't know that. That would explain it. Looks like I am leaving it the way it is. Where did you find that info anyways?
Old Dec 26, 2001 | 07:32 PM
gee I guess that leave me with a mod none of you have
my GXE didn't come with fogs...I had a shop install Pilots right where foglights are...they do not aim straight, but I have a bluish light, that is on with running, and high beam. I wish I could post a pic here, but it is over 500kb in jpg.
Old Dec 26, 2001 | 08:25 PM
Re: Re: Re: Re: Fogs on with High Beams
A friend of mine had a Caprice and he mounted fogs under the front bumper. When he took the car to state inspection (Bayonne area), they failed him, and told him he needed to re-wire the lights so they'd shut off with the highbeams.
I also have a few friends that are cops, and they've told me the same thing. Maybe this weekend I'll do that trick 5th-gen Fog Re-wire mod on my SE...hopefully I have time.
Hey Greg, what part of Jersey is the club for?
SSeeya,
Steve Ragusa
North Jersey
www.bowtiepower.com
Old Dec 26, 2001 | 09:33 PM
zman187's Avatar
Re: Re: Re: Re: Re: Fogs on with High Beams
SSeeya,
Steve Ragusa
North Jersey
www.bowtiepower.com
I know when i have my highbeams on and another car comes, i occasionally forget to turn them down. and i just got my PIAA super white platnium and new fogs that match and i would probably blind the h$ll out of the other car, so i wouldn't do that cause knowing my luck it would be a cop and another ticket for me
Steve, the club is for anyone in NJ. I just got my 00' SE a couple weeks ago, and even before that i would go in my black 89 legend just to check out the cars, but now i can actually join in. Hope to see you at the next meet.
Old Dec 26, 2001 | 11:37 PM
MaxPower2K2's Avatar
my 2k2 fog lights cut off when i turn on my high beams
Old Dec 27, 2001 | 11:37 AM
Steve, the "club" is for anyone in NJ. It's just a site to let people know what kind of Maximas are roaming around on the streets on NJ. If you want to be on it, just send me the year, model, color, tranny (auto or stick), mods, future mods and up to 4 pictures. Thanks for your interest.
trsandrew
Apr 8, 2016 06:45 PM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
Calabar
Oct 5, 2015 09:57 PM
