HOW-TO: Black-Out & Add Audi LED strips to your headlights
Old 09-05-2009, 11:27 PM
SHIFT_om nom nom nom
Metal Maxima's Avatar
Alright, as my final HOW-TO on the .org, I am going to be detailing how one can black out your headlights and add the newly coveted Audi LED effect to your headlights. Without much adeiu, let's begin!
ITEMS NEEDED
Flexible LED strips from Oznium ($40) *CLICK HERE FOR LINK*
Amazing Goop from Home Depot ($4)
About 5 hours...this is actually a pretty quick mod
STEP #1
Remove headlights. I am not going to detail this, there are two screws to remove that are exposed at the bumper level then just pull out...HARD.
STEP #2
You're going to need to remove some hardware from the headlights before beginning. All rubber components, bulbs, and any screws that will come out. One universal item the bulbous thingie that was a beotch to remove in the previous step.
STEP #3
Obtain a flat baking sheet and a large towel. Wet the towel so it's wet, but not dripping wet. Drape across the entire length of the sheet. TEST FIT THE SHEET WITH THE HEADLIGHT IN POSITION. Once you're comfortable with the fit, preheat the oven to 250F. Place the headlight facing UP.
STEP #4
Bake for 10-12 minutes, ONE AT A TIME. Feel free to nervously pace the kitchen floor. *DING* That's the sound of opportunity! Take your headlight out. I recommend using leather gloves, you'll need the dexterity. Start be removing the two screw where the bulbous thing is...they are easier to remove once the adhesive is at working temp. Pry your headlight apart by using a flathead screwdriver to pry the mechanical attachment points open. Then pull...I only did 10 minutes and pulled...hard.
STEP #5
Remove the chrome components from the body. Here's a shot of the only two screws for the 5th gen. The 5.5 gen will have more, sorry, I have limited pics of the 5.5gen. NOTE: Your lens portion will need to be warm for the 5th gen shroud to be removed; this allows proper expansion...believe me, it ain't comin out otherwise.
STEP #5
You're going to want to tape the chrome sections you want to retain. This is actually easier then it sounds. Use small peices when going around the corners. TIP: Take the tape and slowly walk it across the contours...you will have 0 difficulties if you do so.
STEP #6
Paint using Duplicolor's High Temp Engine Enamel. Do 3 coats; two light coats at about 12" distance, very quickly. Do a third "wet" coat; you can do multiple light coats, but I've used close to 100 cans of spray, so I have an unfortunate familiarity with how it behaves. Allow 2 hours cure time, then peel away.
Metal Maxima is offline
Old 09-05-2009, 11:39 PM
STEP #7
Cut your LED strip to size and attach using the double-sided tape included. One the 5th gen, you'll use 21 LEDs. The 5.5 gen is considerably more, just cut to size. NOTE: The array on the strip is in denominations of 3, so you must have a multiple of 3 in order for the full length to light!!! (i.e. 36, 33, 30, etc.)
STEP #8
Drill a small hole to allow for wire passage...I did mine as seen here on the 5th gen...I recommend going toward the turn signal as it is less readily seen below:
STEP #9
Now this is what I consider to be the hardest step. In order to properly reseal, we need to reuse the existing sealant. SO, back in the oven we go...ONLY PLACING THE LENS AND BODY IN THE OVEN. Do so at 250F for 10 minutes. You're going to want to leave the body face up as the channels will likely contain the largest portion of sealant. Remove when the adhesive is glossy, meaning it's at working temp.
STEP #10
While everything is hot, QUICKLY reassemble. Be confident, you can do it. You'll need to do this for the proper seal. Push the body and lens together, making sure the mechanical tabs properly latch. Route the wire behind the lens shroud, you can drill your own hole or use the vent line aperture.
STEP #11
*WHEW*, ok, so you got the lenses probably 80% sealed. Time for some GOOP! Add some extra sealant, we've done all this work and don't want to blow it now.
Old 09-05-2009, 11:42 PM
STEP #12
FIRE IT UP! Test with a 9V to enjoy the awesome effect. These things are BRIGHT!
STEP #13
Wiring...yeah, when I figure this out tomorrow, I'll let ya know!!! TO BE CONTINUED
Old 09-06-2009, 02:21 AM
Mr. Brett's Avatar
This looks awesome. Definite future mod for the Max...
Good work.
Mr. Brett is offline
Old 09-06-2009, 04:51 AM
1800bucks's Avatar
You're a mind reader Metal Maxima. It's exactly what I've been wanting to do to the Max. Unsure about the LED strip for me, but the painted chrome piece is a must. In an earlier thread I asked if anybody had ever wrapped that chrome piece in carbon fiber cloth to try to compliment the look of the SE tails, but I never got any responses, so I'm assuming this has never been done? My concern was heat from the light bulb possibly melting the cloth.
1800bucks is offline
Old 09-06-2009, 05:57 AM
VQP0WER's Avatar
Good write-up!
VQP0WER is offline
Old 09-06-2009, 06:18 AM
anomaly117's Avatar
great how-to. EVERYONE with a 5th gen is gonna do this now, hahaha
anomaly117 is offline
Old 09-06-2009, 08:40 AM
It's not going to be easy on a 5th gen. You're going to have to wrap the contours around the turn-signal housing, which WON'T be easy. It could be done, but the only way I would recommend doing it is to tue the turn signal housing out, which, using the right cutting tool, will remove about 4mils of the housing. When wrapping, tuck the CF around the opening, then reattach the turn signal housing using the resin that will be setting; the CF should make up the difference in material.
It's moderately difficult in theory...so you can imagine the real life difficulty.
Old 09-06-2009, 08:41 AM
GOOD. This is a community to help one another.
Old 09-06-2009, 02:40 PM
GigEmAgs07's Avatar
try and find a way to wire it to the fogs so that those of us with the fog re-wire could sport just the fogs and these strips. that'd look pretty slick imo.
how long were the strips you purchased?
GigEmAgs07 is offline
Old 09-06-2009, 04:03 PM
danger300z's Avatar
you sir ,are the man.
danger300z is offline
Old 09-06-2009, 04:57 PM
arcueda's Avatar
nice thanks for the writeup!
arcueda is offline
Old 09-06-2009, 05:59 PM
SoulEater's Avatar
Very nice. this should help a lot for orgers.
I have a question. do i need 2 of 19 inch Led?
SoulEater is offline
Old 09-06-2009, 07:24 PM
You will need two strips, one per headlight. You can use the 9.5" for the 5th gen, 19" for the 5,.5
Old 09-06-2009, 07:27 PM
Not new, I re-registered.
That Girl's Avatar
Nice salt and pepper shakers.
That Girl is offline
Old 09-06-2009, 09:02 PM
You're almost at 15, please feel free to postwhore so you can pose a question that has been answered ad nauseum in the stickies
Old 09-07-2009, 12:08 AM
blbrizzi1's Avatar
Hey, did you catch the not-new, re-registered in the profile? Kinda touchy on this one, as I'm not new either, and had to post 15 times to free up my profile to be able to add to the discussion on the org. I was a member (BLBrizzi) here some years ago, changed email, lost password, re-registered myself. But, hey, nice write up, and my favorite was the see-through canisters.
blbrizzi1 is offline
Old 09-07-2009, 01:20 AM
bgsl1ck's Avatar
Nice post and a must on my max, I have one question what color leds did you use white or blue????????????
bgsl1ck is offline
Old 09-07-2009, 08:37 AM
That Girl's Avatar
Your response was really uncalled for. I've been surfing this site since 2003. If I were a postwhore, don't you think I would have more posts than 10...11, by now? I will ask the moderators to delete my previous comment on your "write-up". I didn't mean for it to offend. Jerk. And, thanks for YOUR response, thereby letting me add this one so that I may further "postwhore". Maybe I'll get banned.
Old 09-07-2009, 09:20 AM
B_Eaze's Avatar
I was planning on doing this with my R34s on my 4th gen. Great write up, I might do mine the whole length of the headlamp, including the corners
B_Eaze is offline
Old 09-07-2009, 11:02 AM
choiiiiiiiiiii's Avatar
LOL you're a hoot
choiiiiiiiiiii is offline
Old 09-07-2009, 12:04 PM
1800bucks's Avatar
Alright.
EPIC FAIL!!!!! I tried this per your directions. I FAILED!!!!! I broke the damn chrome piece trying to remove it. Got my @ss kicked by plastic.
Old 09-07-2009, 12:42 PM
Alright.
Did you read the note in step #5? I'm asking because I'm curious to how that could have happened.
Old 09-07-2009, 12:51 PM
ampire's Avatar
For what its worth, there are cheaper LED strips on ebay. You can buy whole reels of the stuff. I have no idea if it is usable for your mod but I figured Id mention it.
ampire is offline
Old 09-07-2009, 01:04 PM
GigEmAgs07's Avatar
haha women are stinkin funny.
any idea when we can see installed pics/wiring tips?
Old 09-07-2009, 01:06 PM
Stormzusmc's Avatar
looks good - i just wired my halos and leds up to the parking lights...works great!
Stormzusmc is offline
Old 09-07-2009, 01:09 PM
I'm finishing up wiring in a few hours, all...sit tight
Old 09-07-2009, 06:32 PM
bigpopaj369's Avatar
this should be a sticky
bigpopaj369 is offline
Old 09-07-2009, 07:03 PM
mist max2000's Avatar
nice write up metal...still good to see some old school max dudes still hangin around here making this site what it is..
my side notes...on 5.5 lights..there are 3 tiny screws on the back of the light that need to be removed before seperating.. and the 2 times i opened mine.. when resealing.. i placed the headlight back together, even though the seal wasnt sticky.. and then once it heats i pull it out and its already in place.. leaves less room for mess/glue(which oddly smells like pine needles) getting on the lens..
my ?..what is the life/longevity on those led's,.. i have 2 stips that appear similiar to those that are under my dash.. and they started blinking/going out in rows of 3.. i know i needed a resistor.. but are u afraid of those going out...thanks
mist max2000 is offline
Old 09-07-2009, 07:09 PM
bgsl1ck's Avatar
bgsl1ck is offline
Old 09-07-2009, 07:12 PM
MURDRMAX's Avatar
i think you will need a resistor on these depending on the current draw. if not they will burn out. im sure ozium will help you out with that .
MURDRMAX is offline
Old 09-07-2009, 07:37 PM
Turbo'd Saab
DrunkieTheBear's Avatar
I'm gonna do this to my GTP lights
DrunkieTheBear is offline
Old 09-07-2009, 09:22 PM
LEDs were white. They have built-in resistors, but I think they only calculate out the design for 12V draw, but of course, the altys can given 'em 14.4, so looks like I will have to put some fawking regulators on them
Going to try and finish this tomorrow...too much time detailing the car.
Old 09-08-2009, 07:37 AM
Ephraim's Avatar
nice!
i notice you have the LED strip for 5.0 gen lights up close to the clear housing
not bashing, but my first thought is it might be more natural placed flush along the rim in front of the chromed reflector
did you experiment with the strip location or just put it in the front?
Ephraim is offline
Old 09-08-2009, 07:53 AM
If you position it further back it becomes far too pronounced and doesn't provide a very "clean" look. I tried a few different positions before settling on this one.
Old 09-08-2009, 08:28 AM
maxximaa's Avatar
pics on 5.5 PLEASE?
maxximaa is offline
Old 09-08-2009, 09:00 AM
It's business time.
Progress's Avatar
Did you get your whole car repainted? Where TF are all your rock chips up front?
Progress is offline
Old 09-08-2009, 10:28 AM
Yes.
Old 09-08-2009, 05:22 PM
danger300z's Avatar
Originally Posted by maxximaa
pics on 5.5 PLEASE?
post #3 first pic
Old 09-08-2009, 06:19 PM
I R The Law
The Law's Avatar
metal max at it again!
The Law is offline
Quick Reply: HOW-TO: Black-Out & Add Audi LED strips to your headlights
