Feels like braking on ice
Old Sep 6, 2009 | 04:50 PM
rroderiques77's Avatar
Demodded and Forgotten
So I was driving around today and upon applying the brakes, my ABS started engaging. I could feel the brake pedal kicking back at my feet. There was no ABS light or pattern to it. This happened sometimes at the end of stops, sometimes in the beginning, or whatever. Basically, it felt like sometimes I was stopping on ice, if you know what I mean. I have yet to inspect the brakes/ABS system.
What I think is happening is that my front rotors are glazed and the pads are losing grip. When this happens, I am willing to bet that the ABS system is sensing what appears to be a skid, thus engaging the ABS. What I plan to do to remedy the situation is swirl the rotors and pads to break the glaze. Hopefully this will do the trick. My current brake set-up on the front are 13" Brembos slotted, Hawk HPs, and Z33 aluminum calipers.
Has anyone else ever experienced this issue? If so, what did you do to resolve the problem?
Old Sep 6, 2009 | 08:16 PM
anomaly117's Avatar
on deglazing your rotors. i was gonna suggest it til i read it.
love ur max btw. big fan.
Old Sep 6, 2009 | 09:26 PM
Thanks man!! I appreciate it.
These f-ing things never broke in properly from the get go.
Old Sep 6, 2009 | 09:44 PM
Max_5gen's Avatar
AFAIK ABS would engage if your wheels stop spinning (locking) while what you describe sounds the opposite - 'losing grip'? Did the tires started to skid when it was happening? When I was breaking on the ice the car was not really slowing down while the wheels were locking due to very little friction between tires and the road. It should be hard to do this at this time of year. Something else must be wrong ...
Old Sep 6, 2009 | 09:46 PM
jasonmax's Avatar
check the pads?
what is glazed rotor?
Old Sep 8, 2009 | 10:34 AM
Found the problem.
When I installed the KSports, I forgot to ziptie the abs wire on the driver's side. As a result, the wire came out of the metal bracket and rubbed through all the way to the copper, thus causing the abs to engage at times when applying the brakes.
I felt like a
I taped the wire. I hope it is ok.
Old Sep 8, 2009 | 10:49 AM
maximase86's Avatar
I love lamp.
Glad you found it. I was going to say check the ABS sensor/harness. I had a similar problem with ABS kicking in for no reason when stopping. Though the interesting thing is my abs light would come on after a couple times.
S
Old Sep 8, 2009 | 11:27 AM
and1jr17's Avatar
S
this is crazy.. i drove my car today and had this same exact problem.. and the light came on after a while.. but when i shut it off it went away.. was your harness loose?
Old Sep 8, 2009 | 12:45 PM
No. It wasn't loos. It just rubbed through the insulation. No light ever come on for me either.
Old Sep 9, 2009 | 07:38 AM
and1jr17's Avatar
i figured it out yesterday.. somehow the threads on my axle are stripped, therefore the axle nut loose.. so when i was braking the axle continued to spin.. so the car thought it was sliding and therefore would engage the ABS.. this whole thing has grooved my rotors and screwed my pads.. so i need a new pass. side axle.. get my rotors cut.. and new front pads..
Old Sep 9, 2009 | 08:00 AM
sontakke's Avatar
Does that mean that the wheel was ready to fall off the car????
Old Sep 9, 2009 | 08:35 AM
Not only did the axle continue to spin, but it probably also slid outwards cuasing the exciter ring to not be lined with the abs sensor.
Old Sep 9, 2009 | 10:42 AM
and1jr17's Avatar
I don't think so.. The cotter pin would have stopped the axle nut from backing off past a certain point..
Old Sep 9, 2009 | 10:48 AM
and1jr17's Avatar
Exactly.. That was part of it also.. I took off the ABS sensor to clean it.. And it was covered in metal shavings stuck to it..
Old Sep 9, 2009 | 01:01 PM
I guess I don't feel like such a now..
Mar 12, 2020 12:06 AM
t6378tp
Sep 29, 2018 04:27 PM
05RLS2
Sep 27, 2015 09:24 PM
imported_Nismo_max
Sep 20, 2015 08:19 AM
