5.5gen Pulley Install - Annoying Problem!!
Old Sep 11, 2009 | 10:04 PM
MIK3's Avatar
So, while trying to remove my stock pulley, I have a friend hold the brake to prevent the crank from turning. The pedal is mashed, and the stupid crank still turns. I can not remove the stock pulley until I prevent this movement. Any suggestions? I'm on a 6MT for the record.
Old Sep 11, 2009 | 10:48 PM
maximase86's Avatar
I love lamp.
You could remove the crank position sensor, and use a flathead screw driver to hold the flywheel in place.
S
Old Sep 11, 2009 | 10:58 PM
djfrestyl's Avatar
Suspension Yoda
Uh, your brakes prevent your rotors/axle from turning, not your crank.
Old Sep 11, 2009 | 10:59 PM
Mr. Brett's Avatar
S
I think this is exactly the way it's outlined to be done on most of the how-to websites. You just need to make sure you don't bend/shear any of the teeth off of your flywheel when lodging said screwdriver in.
Old Sep 12, 2009 | 06:09 AM
VQP0WER's Avatar
Lol, when he said he tried using the brakes to stop the crank, I just laughed. hahahaha
Old Sep 12, 2009 | 06:42 AM
SteveB123's Avatar
Take it to a friendly shop and have them loosen it with a big impact gun, then gently snug it back up.
Old Sep 12, 2009 | 07:32 AM
Tee00Max's Avatar
yeah my boy had this same problem and mostly needed a shop that would hit it with the impact gun real quick...
Old Sep 12, 2009 | 08:01 AM
nismowolfe's Avatar
Impact gun FTW.
Old Sep 12, 2009 | 08:11 AM
mtrai760's Avatar
'Trynna' is not a word
Impact gun would be the prefered method. You can also get a long breaker bar, put the end on the crank pulley bolt, and get the end of the wrench as close to the ground as possible, then crank the engine over for a second. Remember, lefty loosy, righty tighty, you need to have the wrench on the right side or it will just fling against the bottom on your car.
Last option would be a strap wrench around the crank pulley.
Old Sep 12, 2009 | 06:11 PM
MIK3's Avatar
I'll have access to an impact gun here in a couple days. Thanks for the helpful info (for the majority). For the others, take into consideration that it was late and I was very tired, obviously not meaning crank...the crank shaft was on my mind when writing the thread. I type 100 wpm, errors happen. Glad I could provide laughs though. I probably would have as well.
About using a screwdriver on the flywheel...I'm a little apprehensive about putting 150+ft/lbs of torque on that screw driver's durability and possibly having it slip.
mtrai760, if the impact gun doesn't work, I'll attempt this. Thanks
Old Sep 12, 2009 | 07:11 PM
NissanTun3r's Avatar
i did the same lol
Old Sep 12, 2009 | 07:35 PM
Grand_hustle17's Avatar
o.k he explained why, lets get this thread more on track, u laughed cause u know, how about helping when u saw it???...
Old Sep 12, 2009 | 07:44 PM
Puppetmaster's Avatar
This is what I did and it worked like a charm. My weak Dewalt impact wouldn't get the crank pulley bolt off.
See step 9 here for details:
http://maxima.theowensfamily.com/udp.asp
Old Sep 13, 2009 | 08:40 AM
CMax03's Avatar
^^^^+2 Or next time you hold the brake make sure the car is in gear (1st-6th)!
Old Sep 13, 2009 | 10:37 AM
MIK3's Avatar
Puppetmaster, thanks for that link. Very useful information. And yeah, it was in 6th as well...tried all the gears, haha. I go in Monday with access to a couple different impact guns. Wish me luck.
Old Sep 13, 2009 | 10:44 AM
CMax03's Avatar
Use the breaker bar and bump the starter, then....and your done!
Old Sep 14, 2009 | 10:08 PM
MIK3's Avatar
Finally, I'm good to go. Thanks again guys.
tsi6001
Oct 3, 2022 10:23 PM
Matt93SE
May 24, 2019 02:58 PM
kenc15
Sep 25, 2015 06:38 AM
Johnny9595
Aug 21, 2015 09:18 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
