maxima=pathfinder?
Old Sep 12, 2009 | 02:23 AM
zarek66's Avatar
maxima=pathfinder?
I have a 2002 pathfinder and it's the same 3.5 engine that's in the maxima. currently it's consuming oil 1 liter for every 1000 km. pissing me off becuz there's no blue smoke coming out the tail pipe and there's no oil burning smell. I'm planning to do a valver cover swap and was wondering if the diy would be applicable to the pathfinder. I know the engine is the same and is placed not sideways like the maxima because it's rear wheel drive so it's placed long in the engine bay.
Old Sep 12, 2009 | 04:41 AM
KRRZ350's Avatar
I'm doing a motor on an '02 pathy as we speak. I am hesitant to believe that valve cover issue, but it's worth a shot. This one needs a motor because of the butterfly issue, you MUST MUST MUST loctite your butterfly screws. This motor had 175k and when I pulled it apart I found 5 of the 6 butterfly valves gone, the only one left on the rod was pretty loose as well. Of the 5 I found 4 of them sitting in the intake port for the number six cylinder and I found 1/2 of one sitting in the number three intake port all chewed up, as for the other 1/2 and the screws I have no idea where they went, but the motor was toast, lots of metal shavings in the oil.
Old Sep 12, 2009 | 04:43 AM
KRRZ350's Avatar
Any valve cover info for a maxima will be a little different, the intake manifold is far different, but it's the same general idea. You can get the FSM on Boredmder.com
Old Sep 12, 2009 | 06:07 AM
VQP0WER's Avatar
Luckily they swapped to the 4.0. I was a little worried when we got our '08 Pathfinder thinking it had the 3.5.
Old Sep 15, 2009 | 12:31 PM
zarek66's Avatar
thanks kkrz350 I'll give it a shot
halfpol
Oct 17, 2022 12:16 PM
Quickgtp
Apr 13, 2017 03:30 PM
schmellyfart
Sep 25, 2015 04:47 PM
halfpol
Aug 5, 2015 08:24 PM
