Sidemarker rewire to blink with signal....
Old Sep 12, 2009 | 07:30 AM
Tee00Max's Avatar
Does anyone have this rewire or know where the write-up is to do it?
Old Sep 12, 2009 | 07:31 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Yeah, you're going to need to tap off of the headlight turn signal and rewire a relay from radioshack, can be done for about $10
Old Sep 12, 2009 | 07:33 AM
Tee00Max's Avatar
o ok ill prob let my boy do it...i really dont deal with the electrical side...it seems like it wouldnt be that difficult though.
Old Sep 12, 2009 | 09:33 AM
LILMAN's Avatar
Make sure you take pics while he's doing it so everyone else will have a write up.
Old Sep 12, 2009 | 10:32 AM
jrflores's Avatar
Old Sep 12, 2009 | 11:45 AM
Tee00Max's Avatar
does anyone have or know where a write up is of this?
Old Sep 12, 2009 | 02:18 PM
SurraTT's Avatar
HR Swap Pioneer
on my 3rd gen i just ran a wire from the front turn signal to the side marker, no relay needed, should work fine on a 5th gen too.
but it depends on how u want it.
like do you want your side marker to only be blinking when the turn signal is on? so unless your turning the marker is at all.
or do you want the marker to be on like it is normally and just blink with the turn signal
(talking about at night time when side markers are lit)
Old Sep 12, 2009 | 04:54 PM
knight_yyz's Avatar
Toolie
personally i think it would look best if it alternated blinking with the normal turn signal and stayed on as a parking light, but I'm not sure if that can be achieved or not
Old Sep 12, 2009 | 05:01 PM
Rochester's Avatar
That's a great idea.
I would think someone here knows how to make that happen. Where's NALC? He's pretty good at details like this.
Old Sep 12, 2009 | 05:28 PM
fflint_18's Avatar
I like the idea and may do it next weekend.
But you really should keep the marker light on so the trick is to use a relay that is energized by the turn signal.
The markers will be on with the parking lights and when you turn on the turn signal it will energize the relay and break the connection to the markers making them go out.
so when the turn signal is on they will go out and vice versa.
You will need one relay for each side and will need to use some sort of heat shrink to weather seal them.
If I do this next weekend I will take lots of pictures.
If I get a chance tomorrow I will look into putting together a writeup in case someone wants to get the jump on it.
Old Sep 12, 2009 | 06:07 PM
AEMAXIMA01's Avatar
That would be awesome man. I am definitely in for pics after you do it. Keep us posted!
Old Sep 13, 2009 | 08:00 AM
Yes, it can be, hence why you need the relay. I'll see if I can get to the write-up today.
Old Sep 13, 2009 | 09:25 PM
nzelinsky's Avatar
I found a write up for this before. Its supposed to stay on with lights then blink alternate with signal.... search harder, I know its on here. Im gonna check, let you know if I find anything
Old Sep 13, 2009 | 09:40 PM
Tee00Max's Avatar
thanks man yea im about to do some searching now...
Old Sep 13, 2009 | 09:42 PM
Stormzusmc's Avatar
Thought about it - I could do it, however I'm about done with mods for the Maxima (focusing on house). If you have questions, I can chime in.
Old Sep 13, 2009 | 09:43 PM
Tee00Max's Avatar
http://forums.maxima.org/5th-generat...er-rewire.html
I guess a discussion on it really didnt read it yet
Old Sep 13, 2009 | 09:45 PM
Tee00Max's Avatar
has a pretty good writeup after i read through it real quick
Old Sep 13, 2009 | 09:54 PM
Ghost_54's Avatar
^^^ yes this was the same posting that I found "areX" gave a pretty good description on How to Do in posting #14
Old Sep 13, 2009 | 09:55 PM
Tee00Max's Avatar
yeah he did a pretty good job prob going to try this either tomorrow or the next...
Old Sep 13, 2009 | 11:04 PM
nissanmax2001's Avatar
I will be there to see you do it.
Old Sep 14, 2009 | 06:14 AM
bigpopaj369's Avatar
cool free mod! im guna do it today as well
Old Sep 14, 2009 | 07:47 AM
Rochester's Avatar
Those instructions are for the 5th gen, not the 5.5 gen.
The fog-rewire was different between the two models, so I'm guessing there would be a difference here as well.
Old Sep 14, 2009 | 08:32 AM
nzelinsky's Avatar
honestly doubt it.... your just tapping the power for the signal, its probably the same thing. Signal wire = signal wire ??
Old Sep 14, 2009 | 08:45 AM
blktalon456's Avatar
The instructions aren't that clear but we'll see what happens.
Old Sep 14, 2009 | 08:46 AM
Professor's Avatar
This is a good idea, is there a way to make it so there like sequential, like when the front light is on, the side is off and vice versa.
Old Sep 14, 2009 | 09:13 AM
User 12822's Avatar
I'm assuming its the same if you wanted the rears done as well? Im gonna try and do all four, shouldn't take more than an hour.
FYI anyone with Halos! Wire the Halos along with the side markers so they took will blink when you turn! I noticed the Audis with those sexy leds do this as well when they flip their turn signals.
Old Sep 14, 2009 | 11:05 AM
jrflores's Avatar
lol i think if i do that with my halos it might be annoying to other drivers since they are so bright.
Old Sep 14, 2009 | 11:48 AM
The6spdMax's Avatar
I'm assuming its the same if you wanted the rears done as well?.
Yea, that would be interesting.
Old Sep 14, 2009 | 12:58 PM
All you do is take a piece of wire and splice into the green turn signal wire on each side run it through the white grommet on each side to the side marker. Cut the ground on each plug and attach your wire to the ground. And it will be done.
Old Sep 14, 2009 | 01:49 PM
Tee00Max's Avatar
blktalon456 did mines today before I went to class and it works and looks great! When the lights are off it blinks with the signal and when the lights are on, they blink back and forth....
Old Sep 14, 2009 | 01:58 PM
Ricky429's Avatar
Its easy i did mine last year following these instructions
http://www.vqpower.com/v2/articles.php?article_id=160
Old Sep 14, 2009 | 02:02 PM
did mine too i love it! free mods are this shh! its extremely easy maybe a 3 on a 1-10 scale. looks really cool
Old Sep 14, 2009 | 02:45 PM
fflint_18's Avatar
This is a great way to do it. Frankly I never thought of it. And I do electrical for a living. I was making things too complicated.
You are just using the signals relay to do the job. As long as it can handle the current of an extra bulb everything should be fine.
The only thing using external relays would do different would be that the would only work when your markers are on. Otherwise (during the day) markers would stay off.
I'm going to do it this weekend.
The only thing I would suggest is to use good splices and try to weatherproof them with either heatshrink or some silicone.
And I would actually use a splice on the wire you are cuttung back just to mnake sure you have a good insulated connection. Tape eventually loses it's grip when it gets really hot and get brittle when cold. And you might get a short.
Old Sep 14, 2009 | 05:01 PM
knight_yyz's Avatar
Toolie
most people are using led's now so extra current should not be a problem
Old Sep 15, 2009 | 06:25 AM
Rochester's Avatar
LED? Where? In the side markers, or the turn signals?
In the turn signals you want as bright a light as possible, so that's probably not it. You must mean the 194 wedge bulbs in the side markers.
I bring this up because I tried that and bailed. The LED light wasn't diffuse enough to allow for the side marker to light up uniformly. That, and both white and amber LED's ended up changing the side marker color when lit, to where it no longer matched the turn signal amber.
Knight, I'm interested in knowing what you did here with this LED reference, and your thoughts on why it works for you.
Old Sep 15, 2009 | 08:39 AM
fflint_18's Avatar
LEDs or not current is probably not an issue. You are only talking about adding a mas of a 15W lightbulb (more than likely only 7W) so it is not a much bigger current draw.
Old Sep 16, 2009 | 05:31 PM
so i did the rewire the other day and today i noticed when my blinkers are on the odometer back light flashes with it is that just a simple bad connection???
Old Sep 16, 2009 | 06:06 PM
Tee00Max's Avatar
its seems like thats all it would be.
Old Sep 16, 2009 | 06:12 PM
alright thanks! i will check the connections tomorrow i figured as much but i wanted to make sure
Old Sep 16, 2009 | 06:29 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Currently, I'm using these LEDs for the side markers and running lights.
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT
They fit the front sides easily, but the rear needs coaxing as they're very long. I'd super glue the PCBs together for strength (or the solder connection will probably break).
Also, for the running lights, they're pretty long. I had to push really hard and jam it against the lens. But they work just fine.
Gimme a bit, see if I can get some pics up.
OT I know, sorry haha.
