MAF sensor Replacement
Old Oct 4, 2009 | 06:00 PM
HOMERUN4THGLE's Avatar
I have seen alot of different comeents about replacing a MAF sensor I would like to know exactly what is needed when I replace it. I have come to the conclussion the this is the problem with my car bcause it is running like S***. Some days it runs smooth until I get 50 or 60 but don't give it gas because when it shifts down to a lower gear to pass a car it does NOTHING! It seems as if it is stalling or hung up in the gear. I let off the gas some and it will shift to the next gear. The final straw was when I put 2 gallons of 100 octane fuel in the car and it did not make a difference. So I have come to the ORG for assistance. I rolling up on 150k and I want to get my baby running full speed before it gets cold. Any assistance and pointers given will be appreciated.
  1. Is there any part number or engine number needed to order the correct MAF?
  2. Should I reset the ECU or take it to the dealer to have that done.
  3. Find Dave B. on the ORG and order the part from him.(He comes highly recommended)
Old Oct 4, 2009 | 06:19 PM
RhodeyMax01's Avatar
1. No
2. No
3. Yes
Old Oct 4, 2009 | 06:22 PM
2kmax865's Avatar
I just replaced mine a couple of months ago. Got it from Dave Burnett, he has correct part # and good price. I took mine to stealership for programing and was told there was no up date for ECM, but an O2 sensor problem. They wanted $500 to replace sensor. I done it for $100 and 30 minutes time.
Old Oct 5, 2009 | 09:27 AM
CDN2000SE's Avatar
Getting OBD PO100 now had po171,po174 before that Tried CRC Cleaner this time she is toast so I ordered a new MAF saved lots of $$ the dealer wants 599. CDN $ There is no way I am paying that from the Stealership they are smokin Crack! anyway when I get the part I will let you now how it goes ....!?without a ecu update
Old Oct 11, 2009 | 07:47 AM
CDN2000SE's Avatar
Ordered a Maf from Ebay 22680-ad200 noticed it has a resister on the outside
and the original does not? Do I need a reprogram from the steelership?
kjlouis
Nov 24, 2018 06:09 AM
vingodine
45
May 21, 2016 12:46 PM
vanebecker
Aug 19, 2015 09:45 AM
