Wierd Auto shifting
Old Oct 27, 2009 | 02:24 PM
Love_00_Max's Avatar
Wierd Auto shifting
The auto tranny has this wierd behavior, hopefully I can put it in the right words. Receent jobs on car are new tires, cleaned revoln sensor, cleaned MAF and drain/fill tranny with DexVI.
1) When I accelerate a bit hard, looks like the traction on one tire is less than the other, kind of wierd feeling where one axle is running faster than the other, or in other words, a feeling that the axle is in air.
2) Uphill shift, the car would look like it is slipping (it happens sometimes and sometimes it wouldn't).
3) Gear bang in 1->2.
Any ideas if the tranny is on it way out or should I go back to thicker DexronIII type ATF.
Old Oct 27, 2009 | 06:38 PM
jasonmax's Avatar
1. open diff does that
2. slowshift does feel like that, mine feels like shifting a manual, rev doesnt spike tho
Old Oct 27, 2009 | 08:01 PM
Scottwax's Avatar
That's Mr. Detail to you
If the shifts flare (over rev) once the car is warmed up and under load (like going uphill), it is usually an indication of an internal problem. You can try a drain and fill, adding a quart of Lucas Transmission Fix, which noticably reduced the cold weather 2-3 slip in my car.
http://www.lucasoil.com/products/dis...smission%20Fix
Old Oct 28, 2009 | 10:01 AM
I am not a great fan on anything other than ATF in my tranny.
But I have to get realistic, the tranny has 170K and I want to drive it for another year or so since we have payments for another one. 2 car payments at the same time is non-concievable with this lousy economy.
I will drain and fill with Castrol Import MV ATF and put the Lucas tranny fix. Hopefully it take me thro another year.
Unclejunebug
Apr 2, 2016 05:42 AM
BobTX10
Oct 7, 2015 08:43 AM
hayne
Oct 5, 2015 11:53 AM
