6SPEED SWAP VS SUPRASTICK: WHAT WOULD YOU DO???
Old Nov 4, 2009 | 01:14 PM
SCI's Avatar
SCI
OK...Been reading and researching the ssv4 for a minute now and the pros and cons of this sick *** mod for our auto maximas and just when im bout to drop the hammer and get this I end up jumpin in one of my boys 6spd max's and its like damnnnnn...i want a stick but seeing as though I d k anyone in real life w/the ssv4 I cant do a real comparison so I am looking for the feedback and opinions of other enthusiast to narrow my choice down...I basically want a max i can shift at will for mostly aggresive driving and some track runs that i plan on for summer 2010...plz let me know what setup you would run and why (or why not) Thanks in advance,
Sicko Sci
oh yeah...I would also like to run a small shot of NOS(50-75 shot) with either setup as well
Old Nov 4, 2009 | 01:31 PM
bigpopaj369's Avatar
i say swap it 6MT ftw
Old Nov 4, 2009 | 01:47 PM
HotshotVQ35's Avatar
does anyone have a suprastick installed and working in a max? thought i saw a thread but the guy couldnt get it to work...or maybe he did, i dont recall..
Old Nov 4, 2009 | 01:52 PM
MoncefA33's Avatar
Aaron92 SE (3rd gen with full 3.5 ECU/wiring swap) is running SSV4 on his car.
Well SS is def. cheaper and less time consuming to install and more manageable in traffic. But you're missing two gears so...
Old Nov 4, 2009 | 01:53 PM
rroderiques77's Avatar
Demodded and Forgotten
Doesn't Jime run a Suprastick?
Old Nov 4, 2009 | 01:54 PM
Rochester's Avatar
If you research deep enough in the forum, you might come to the conclusion that it's far easier to sell your car and buy a 6MT, than it is to swap the transmission.
Old Nov 4, 2009 | 02:09 PM
MoncefA33's Avatar
You'd need.
  1. 6MT
  2. 6MT pedal assembly
  3. 6MT ECU(?)
  4. Labor or lots of time
SSV4 will shift faster and more consistently. So you could compensate with less gears (4 speed auto vs. 6 speed manual) by adding more power mods.
EDIT Rochester is 5 posts behind me
Old Nov 4, 2009 | 02:19 PM
iirc, my 6spd in 4th tops out at ~125mph, hes going to need more than a 50-75 shot to hit that trap
Old Nov 4, 2009 | 03:20 PM
Rochester's Avatar
You'd need.
  1. 6MT
  3. 6MT ECU(?)
Don't forget the fancy HLSD pedal pads!
OMG, it took me quite a while to recover from laughing at that.
Too funny.
Old Nov 4, 2009 | 03:21 PM
MoncefA33's Avatar
Too funny.
Wait I forgot something.
Now you're 6 posts and one LSD behind me
Old Nov 4, 2009 | 03:29 PM
wait, the 6spd with hlsd has different pedals? interesting..
Old Nov 4, 2009 | 03:30 PM
Rochester's Avatar
...and one LSD behind me
Value is all relative, Good Sir.
My ride is debt free with only 54K miles. So I got that going for me.
Old Nov 4, 2009 | 03:34 PM
MoncefA33's Avatar
True.
You also have a 3.5.
I just have a quick 3.0
Old Nov 4, 2009 | 03:39 PM
Rochester's Avatar
True.
This was fun, but we really shouldn't biggleman this guy's thread with pithy, OT comments.
Old Nov 4, 2009 | 05:23 PM
KiNgJaMEs's Avatar
Ok I think im the first with a SS on a 5.5 using the stock TCM. I have to say it is a headache but I dont have much time to figure it out. Im guessing one weekend working on it constantly and tuning it you can be done. The problem I'm running into is the speed sensor wire and which one to tap and where. plus I dont believe you can use the cruise control to change gears, our wiring is different then the 4th gens. if you want any additional info pm me and ill tell you all about it
Old Nov 4, 2009 | 06:38 PM
nzelinsky's Avatar
Im pretty sure there a are few guys with SS in the max, Jime being one of them. I plan on getting one after deciding 6mt swap is too expensive/too much work to be worth it. Get a SS with a new TCM. You can wire the shifting on your cruise buttons, you just need an extra switch to choose cruise vs SS controls on that set of buttons. Or you can install paddle shifters and do it that way too.
Also, If you plan on getting a nitrous setup I would stick with the auto because it is actually better for spraying.
Old Nov 5, 2009 | 06:31 AM
KiNgJaMEs's Avatar
Jime and Aaron both use it as a stand alone and im piggy backing that the difference. and I'm pretty sure if you try to use the cruise control you will lose your cruise control functions even if wired on a separate switch. I'm not saying don't do the SS or not to try it or challenge me, It would be great if someone figured this out cause i thought it was more Plug N Play but with the 5.5 gen thats not the case. Ive been working closely with Garrett Rowe the CEO of the SS to help iron out these issues
Old Nov 5, 2009 | 07:16 AM
mist max2000's Avatar
in terms of the 6speed swap,..parts wont be terrible to find,.. but if you or you and some buddies dont have the ability to do it yourself and have your car layed up for a while then its not worth it IMHO,.. labor would be wayyy too much..
Old Nov 5, 2009 | 08:11 AM
e-subliminal-2's Avatar
Sell your car and get a 6mt once you run across one in your area. I don't think you'll be thinking "it's the same car" type theory. Definitely a difference in hp, and fun. The supra sport imo IF set up correctly would be 50% as fun as actually shifting in and outta gears, but I just like the feel of a clutch/shifter more than an auto... jus my 0.2$
Old Nov 5, 2009 | 08:13 AM
Rhyno02's Avatar
Call me a newb if you want but, I never heard if this until now but I think I just found the next mod im doing after I get my suspension finished I just can't believe that it's only $350! I just wish there was a 1/4 track near me so I could do a before & after comparo....
Old Nov 5, 2009 | 08:20 AM
Rochester's Avatar
I mostly agree with that, about MT vs. Auto. However, there are some OEM automatics that can be fun. The Infiniti G37 automatic has 7 forward gears, and is an absolute delight to bump up and down manually.
And the Volkswagon CC 2.0T automatic has 6 forward gears, with a dual-clutch that's a blast to drive. (Yeah, dual-clutch, in torquey little turbo for seriously reasonable cost. Who knew?)
And if you can drink the kool-aid (which I can't), the new Maxima CVT automatic is actually lots of fun to drive in sport-mode. Stoopid, but fun.
Old Nov 5, 2009 | 08:22 AM
What he said ^^^^^^^^^^^^^^^^^
Mines got 67K. Title's in the filing cabinet.
Old Nov 5, 2009 | 08:58 AM
Gemner's Avatar
Entertainment value for everyday and track-6-spd
all around easy (consistent) speed- suprastick
Old Nov 5, 2009 | 01:50 PM
SCI's Avatar
SCI
SSV4 vs 6speed swap pt.2
1st off thank you 2 everyone for their ultra-swift replies...i didnt expect 2 get so much feedback in such a short amount of time Max.org is truely the ****...
To King James- I thought the ssv4 was plug n play too...I guess ill pm you about the kinks that need to be worked out with it
To those that said "sell my car" to get a 6spd-NEVER!!! I am not super-modded like some of you but I gotta good amount into to it now and even tho i'd have 6 gears to play with, i'd have to start from the bottom again modding and my car would look regular as hell lol Thanx for the suggestion(s) tho
I drive my lil' sisters 4th gen time to time and I DO have alotta fun bangin' thru the gears but when the fun is over that **** gets annoying so i thought the ssv4 might be the best of both worlds,my girl just gotta 09' g37 sedan and the tiptronic is FUN as hell in that car...so yes i guess i am leaning a lil more toward the ssv4
I heard the 6spd tranny has the infamous "6th gear grind?!?" what the **** is that??? def don't sound good...would 5spd swap be worth it or is it the same **** involved except minus 1 gear???
King James said you couldnt wire it to the cruise control buttons in the 5.5 gen and an extra switch wouldnt work either...so would paddle shifters be the cure for this??? I read the ssv4 also corrects tranny slippage ALSO but would it also be a good Idea to rebuild the auto trans before this mod? ( I was looking at the transgo shift kits and tranny cooler)
The current performance mods I have are a CAI and custom catback w/Apr muffler...Ive had the car since 2k7 and tho Ive been a member since I got my car in stock form I am still learning so forgive my lack of maxima knowlege
My goal is to have the car running low 13's/high 12's (is this unreasonable w/out FI?) on spray but I know the trans is a key component to have a "Fast" car so i am focusing all my $$$/time to get this bulletproof before doing other ****...THANX again to all the MAxima OG's who have given me feedback so far,
Sicko Sci
Old Nov 5, 2009 | 01:56 PM
hot_wax_tree's Avatar
The gears arnt the same size as in the 6spd!! duh
Old Nov 5, 2009 | 02:00 PM
really? i had no idea the 6spd and 4 auto had different gears? thanks captain obvious!
to the OP, there is no 6 gear grind, some people have problems with a 3rd gear grind under high rpms
Old Nov 5, 2009 | 02:03 PM
MoncefA33's Avatar
I've only heard about 3rd gear crunching on 5.5 gens, this is only a problem if you swap in a transmission from 02-03 Maximas due to weak syncros. If you get one from a 6th gen ('04+) you will not have this problem. Plus the 6th gen gearbox has slightly more aggressive final drive gearing so acceleration will be even quicker.
Sicko Sci
People are doing this N/A. JayPee_99 is running high 12s and I'm sure you can get low 13s as long as your launch is good and you get some more bolt-ons and something to tune with.
Gemner's Avatar
yes, you will be able to run low 13/high 12 with the auto and def with a 6. With a good tune, a very lightly modded 6spd and a 50shot will do low 13 all day and with a good set of rubber, 12's are def there. In an auto, with a good tune the 50 will get you low 13's but it might take the 75 to get 12's unless you have all the supporting mods (headers, 3" exhaust, driver mod, etc)
Old Nov 5, 2009 | 03:50 PM
Rhyno02's Avatar
Would it be necessary to have the transgo shift kit installed AND get the ssv4? Or is it possible to get away with just one? Would the be redundant? Or no? I am just curious, thanks
Old Nov 5, 2009 | 04:11 PM
KiNgJaMEs's Avatar
i have been talking with Jime and Aaron on this and if i recall right the SS and the DR mod is all you need but to each their own
Old Nov 5, 2009 | 04:47 PM
Rhyno02's Avatar
DR mod?
Old Nov 5, 2009 | 05:58 PM
MoncefA33's Avatar
Transgo only speeds up part-throttle shifts. Useless with SSV4.
DR mod?
Drop Resistor mod. Allows the transmission to shift at full line pressure (super hard/fast shifts)
Old Nov 5, 2009 | 07:01 PM
in terms of your CAI,.. i hope its not an injen,.. because that will kill your 1/4 and trap times ,.. you need a WAI with a block plate,..
those times are possible,.. but you better be a damn good driver with some expensive rubber
Old Nov 5, 2009 | 07:40 PM
Grand_hustle17's Avatar
easily answered... 6spd
Old Nov 5, 2009 | 08:34 PM
Deckdout2's Avatar
Play with my balls
Go drive a GT-R and you'll forget what a 6-speed manual is.
Old Nov 6, 2009 | 11:22 AM
SCI's Avatar
SCI
SSV4 vs 6speed tranny
whoa...its like everyone here knows the 5.5 gen in and out lol and just gave me way more to think about I wont be doin anything until around after Jan so I gotta lil time 2 dwell on this info provided by the Max Gods...
question: Whats the diff between using this as a standalone and a piggyback???I kinda know but need a lil insight
I didnt know the 6th gen 6spd can fit in the 5.5gen...thats ****in sick with the better final drive for better acceleration
I be seeing dudes get blasted on here for not searching for **** so dont smoke my boots for this but...I couldnt really find how much the 6spd swap is gonna be,I got a couple homies that can do the work so I guess i just need the price range of ALL the parts together
I ALSO WAZ unaware the auto iz better for spraying so I guess thats 1 positive to having an auto trans and now that Yall let me know low 13's-high 12's are realistic I am very excited
Ive also read jimes post countless times and it seems like he got it going pretty good at one time so as a standalone it works right? I like the lcd monitor showing what gear you are in too...seems like this mod will give u extra cool points at car shows too seeing theres only a handful of ppl who even know about this...I gotta modified mag and sum dude is runnin 550 hp sc300 boosted lexus w/soarer motor and is using the ssv4!!! he also is running raybestos performance clutch packs and bands w/ his auto trans...so i guess this **** works somehow someway...Thanx for all feedback again,still open for more so hollaback,
Sci
Old Nov 6, 2009 | 12:07 PM
some more friendly advice,.. the mods like to keep it clean around here so dont avoid the profanity filter,.. or swear in general
Old Nov 6, 2009 | 04:00 PM
you really would, but you would surely remember the price tag ..................... 6spd all day for me, whenever this auto tranny goes (146K and soon i know) im definately going 6spd (and no hotshot im not going HLSD... JK )
Old Nov 6, 2009 | 04:05 PM
Sci
well to be honest 12's is realistic in an auto even without the suprastick... i also didnt know that NOS was better in auto's so +1 there fo me too... using Car-parts.com, you can probebly get 97% the 6spd parts for $1200-1500.. i just had a buddy giving me a price fo $900 for all the parts
Old Nov 13, 2009 | 10:43 PM
KiNgJaMEs's Avatar
Break through SS works in the 5.5 just need to figure out where to mount switches, screen.
