reduce your highway windnoise now!
Old Nov 8, 2009 | 03:18 PM
  #41
boris's Avatar
Same here. There is just no room for the weather strip even reduced thickness doesn't help. ????
Old Nov 8, 2009 | 04:03 PM
  #42
Rochester's Avatar
Thank you, brother. I thought maybe it was just me.
Old Nov 8, 2009 | 05:39 PM
  #43
mist max2000's Avatar
then you maybe dont have the right kind of tape?,.. before i bought the right kind,.. i had some other tape that was the same size and black but a little more firm.. and it wouldnt fit,...just an idea..
Old Nov 8, 2009 | 06:23 PM
  #44
bigpopaj369's Avatar
the stuff i got is super thick that sucks i seen some real thin stuff at HD while i was there recently thatd prolly work but it mite just be more of a headache than what its worth
Old Nov 8, 2009 | 06:45 PM
  #45
Rochester's Avatar
Frost King, 3/4" wide and a 1/2" deep. And it's the right kind of foam, too. The channels are 3/4", so the weather strip fit perfectly. But once in, the 1/2" foam thickness didn't allow for the window seal to go back on.
Hoursecor's ride is also a 2003, so it's not like there's a difference between our cars. I don't know, unless I read something brilliant and convincing here, I think I'm done.
Swing and a miss.
Old Nov 8, 2009 | 08:01 PM
  #46
comtnbiker's Avatar
Sunroof wind noise
Originally Posted by ridinwitha35
+1. Luckily the rear window fix was done on my car before I became the owner. But the most annoying wind noise is from up front & the sun roof. Passengers in my car have even commented while on the highway, "why is it so loud?"
Just learned to live with it unfortunately.
Shift_Ice also has a fix for sunroof wind noise. I had it really bad, added some shims, and it helped a lot. It's not perfect but way better than it was.
Some notes: I bought 4 shims and used them all on the rear of the sunroof (2 each side). Also, they weren't 65 cents, they were $6 each!
Can't wait to get to the other noise fix. I want quiet!!! I keep finding myself wishing I had bought that Audi A6 in spite of the likely maintenance costs.
Old Nov 9, 2009 | 09:29 AM
  #47
vastmax's Avatar
i did this 2 years ago, i remember I bought foam that was too thick at first so I went back and boguht some 1/2". That worked great, still no wind problems. I still have to do the sunroof fix next...
Old Nov 9, 2009 | 10:08 AM
  #48
mandyfig's Avatar
Swing and a miss.
The sizes threw me off bigtime. I could not get the identical 3M tape and had to rummage through Wallworld and HD. Finally got the 1/2" thick x 3/4" wide. It measures 3/4 x 1/2 which is different from the 3M. Had to use logic...
Then I tried to put them on and bogged down....how do you take off the seal? Yank it out? How do you put it back? Where do they fit? Will they fit?
Maybe just whining....but pitch in for those who have done it!
Old Nov 9, 2009 | 12:53 PM
  #49
SteveB123's Avatar
I was expecting a soft rubber seal....and discovered a hard plastic type of seal, at least part of it was, and it wasn't happy at ALL about being dislodged from its happy home.
Or I was taking out the wrong piece, but i don't think so.
Was just taking it out for a looky-loo to see how it would go for when I get the tape....so far, not so good.
Insights?
Old Nov 9, 2009 | 01:09 PM
  #50
Rochester's Avatar
Insights?
That makes 4 of us here who are unhappy pursuing this little "fix".
I have no insights, Steve. But I sure would love to see exact photos from somewhere other than the write-up on shiftice.com, because that isn't working for me either.
Old Nov 9, 2009 | 01:38 PM
  #51
mandyfig's Avatar
Somehow it is not adding up. The seal does not look like it is just pull and re-place. It is sturdy and may be a one time use.
Old Nov 9, 2009 | 02:34 PM
  #52
ICELANDIC MAX's Avatar
wanted to do this fix for a long time but the wind noise never bothered me that much. maybe will wait until we figure out the right size.
Old Nov 9, 2009 | 08:08 PM
  #53
*will take pictures and update on wed with exact stuff used and where and trim off*
Old Nov 10, 2009 | 04:17 AM
  #54
is it windy yet?'s Avatar
a link to the tsb for wind noise
http://maxima.theowensfamily.com/tsb/NTB01-029.pdf
Old Nov 10, 2009 | 06:04 AM
  #55
Rochester's Avatar
Good deal, mist max. Looking forward to seeing what you did and how you did it.
Old Nov 10, 2009 | 08:00 AM
  #56
Nelsito65's Avatar
^^I'd like to see those pictures too.
I have a 6-page copy of a revised version of the TSB (NTB01-029a), which shows more detailed information than the one linked above (NTB01-029). I'm considering going strictly by those instructions when I do mine (it looks like housecor's write-up leaves out a few details).
Old Nov 10, 2009 | 09:46 AM
  #57
mandyfig's Avatar
Can you possibly post this revised TSB?
Old Nov 10, 2009 | 10:19 AM
  #58
Nelsito65's Avatar
It would be nice to have a section for documents such as TSB's in these forums.
Here's the link:
http://sites.google.com/site/nelsito...attredirects=0
Old Nov 10, 2009 | 01:57 PM
  #59
mandyfig's Avatar
Great! Thanks a lot! You are right, we should have a repository of documents like this. Thanks again, this is a much better and clearer TSB than the old one.
Old Nov 10, 2009 | 10:00 PM
  #60
Gemner's Avatar
For those having trouble, make sure you look closely at the pictures on the site and get it in the correct channel. I screwed up cause I didnt know where the right channel was and it didnt really fit right, but then I removed it and put some in the right place and
Old Nov 11, 2009 | 07:19 AM
  #61
FanaticMadMax's Avatar
good post, i didn't know the moonroof is adjustable, that's one of my biggest problem since my moonroof doesn't flush with the panel.
Old Nov 11, 2009 | 05:07 PM
  #62
mandyfig's Avatar
The amended TSB is much detailed. Should work. However it did not state the specs of the foam.
Old Nov 11, 2009 | 05:53 PM
  #63
boris's Avatar
Yes this is much better description, thanks! However, this is exactly what i tried to do with my windows and it didn't work (no room for the tape, even much thinner than 1/2 "). It makes me think our cars are already "corrected" by manufacturer (The mine is from Feb 2K2). The noise is still here though
Old Nov 11, 2009 | 05:59 PM
  #64
OOmaxSE's Avatar
While you guys are all fixing wind noises, try the sunroof fix as well:
http://www.shiftice.com/sunroof_wind_noise_fix.html
Old Nov 14, 2009 | 09:08 AM
  #65
mandyfig's Avatar
Anybody else who has tried this fix using the TSB details?
  #66
mandyfig's Avatar
If you did, how was it and did it work? What size of foam did you use?
Old Nov 17, 2009 | 06:26 AM
  #67
mandyfig's Avatar
Finally yanked the seal off the window and I can see a small foam already installed in the corner...looks like an attempt was made already. Did not work, there is wind noise, both sides in the rear.
I will attempt to rectify this shortly and will do a DIY with pics.
Old Nov 17, 2009 | 06:19 PM
  #68
mandyfig's Avatar
Reviewing the amended-updated TSB, it is pretty clear. I now know what to do. Will take detailed pics when I do it this week.
Old Nov 18, 2009 | 01:28 AM
  #69
Revs2Hard's Avatar
BARF
Ok im gunna have to try this.
Old Nov 18, 2009 | 09:14 AM
  #70
mandyfig's Avatar
The specified 1/2" thick by 3/4" wide foam strip (from the shiftice DIY)might be too big for the TSB. At least from looking at where they want it installed.
I will go back to Wally or HD to get some 3/8" thick by 1/2" wide which from looking at the TSB is more of what they used.
I will be following the updated TSB rather than the shiftice DIY...
Old Dec 20, 2009 | 06:28 AM
  #71
mandyfig's Avatar
I did the TSB this weekend and it freeking worked! Followed the TSB to a T and solved the hiss coming from the rear windows. Did both. Bought the 3/8" foam from wallyworld.
Old Dec 20, 2009 | 06:30 AM
  #72
mandyfig's Avatar
The TSB is pretty clear...it will show you exactly what to do. Follow the directions andit willdo the job. Was going to take pics, but really not necessary. Just shove the foam as instructed. $4 repair.
Old Dec 20, 2009 | 12:36 PM
  #73
Kevin319's Avatar
Never heard of wallyworld ... is that another name for walmart So you got the 3/8" thick x 1/2" wide 3M foam strip? If you can, please take a picture of the product you bought since it will help alot of people on which size and type to buy.
Old Dec 21, 2009 | 01:24 PM
  #74
mandyfig's Avatar
I will post a pic of the actual foam. Yes, wallyworld is WM!
Old Dec 21, 2009 | 04:16 PM
  #75
Romey's Avatar
REALLY????? Wallyworld= Walmart!!!! LoL
Old Dec 22, 2009 | 10:07 AM
  #76
mandyfig's Avatar
Remember National Lampoon's VACATION? Wallyworld?
Old Dec 22, 2009 | 04:40 PM
  #77
mandyfig's Avatar
Foam
Here we go. Wallyworld, $3.00.
Old Dec 22, 2009 | 07:25 PM
  #78
Kevin319's Avatar
Sweet thanks for the picture! Did you notice an increase of noise reduction from the rear windows?
Old Dec 22, 2009 | 07:37 PM
  #79
mandyfig's Avatar
The hiss was gone!
Old Dec 22, 2009 | 07:38 PM
  #80
mandyfig's Avatar
Take a 4.5 inch strip and drop it in the slot, make sure the areas specified in the TSb are covered. You are all set. Some people went overboard and installed the strip all along the channel. Do not know if it helped. I just followed the TSB.
