I know that in the 5.5 gen both the front window are auto. If I swap the button cluster from the 5th to 5.5th gen will both my windows be auto?
Thanks!
Thanks!
I have an 03 the master switch on the driver side has both front windows as auto n passenger side master switch is auto also. If ya passenger side switch is auto they both should still b auto.
if it was only that easy but its not.
wiring is different and so ar the window motors.
anything can be done with enough work but it is NOT a plu-n-play kind of thing
edit: motors are the same
Quote:
Because my understanding the auto mechanism is in the actual switch itself. ?
yeah, look int the fsm in the electrical schematics for the front doors, everything goes throught the body control module and IIRC, the 2000-2001 are different from 2002-2003Originally Posted by webjohn
Do you have any proof to that statement? Because my understanding the auto mechanism is in the actual switch itself. ?
I had a 2000 maxima parts car and a 2003 parts car, trust me they're different.
By the way, I also worked on the 3rd gen altimas where some of them had both front windows to be auto and others only the driver front one, i also wanted to swap them but realized its not that simple.
Like i said before, it can be done, just a bit more work than just swapping out the switches.
the master switch from 00 will not fit in an 03, and vice versa, unless you swap the panels as well. Or start cutting the panel to make them fit
the fsms don't work right now so i can't double check, but i'll check on monday at work at exactly what is involved in a maxima to get this to work.
how about an auto down AND up switch?
did you know if you hold your unlock button on your remote both front windows go down i just found that out after 2 years of owning the car its nice in summer to get some of that heat out before you get in
Quote:
i thought thats what we're talking about here this whole time...Originally Posted by smai555
how about an auto down AND up switch?Quote:
yeah, thats a nice feature, too bad the 2000-2001 don't have it.Originally Posted by smai555
Quote:
Please do.. Thank you.
i thought thats what we're talking about here this whole time...yeah, thats a nice feature, too bad the 2000-2001 don't have it.
yea... i thought i was in the 4th gen section .... weird anyway i have an auto down but not up on my 97 im guessing it wont be worth my time to try and get this done on a 4th gen
i cant believe the 2000-2001 dont have the unlock auto roll down hummm.. weird
