Front end clunking over rough/broken pavement - Solution
Old Jan 3, 2010 | 06:09 PM
  #41
Nelsito65's Avatar
Originally Posted by kbohip
The passenger side motor mount looks like a nightmare to get out though. How long did it take you to do yours? After reading a few motor mount threads I'm now contemplating eventually doing the front and rear motor mounts and maybe even replacing them with the stiffer Energy Suspension mounts.
There is one nut you have to get from below. I had to remove the passenger tire and plastic fender cover to stick a rachet and 14mm deep socket, along with extension bars and universal joint. I also jacked up the engine a little bit to release some of the pressure from the main through bolt. I would say it took about an hour.
I don't know if the other mounts are any easier.
Old Apr 1, 2011 | 01:05 AM
  #42
$Ghostrider$'s Avatar
Not trying to revive have an 03 with the clunking issue. Have all new struts in garage to do this weekend, hate I didn't find this site sooner. I would have started with the cheaper stuff, but I got 170,000 miles and they are probably due a change anyway. Thanks
Old Sep 18, 2011 | 06:50 AM
  #43
rvanders37's Avatar
2000 gle 160k miles clunking noise was definitely coming from the front motor mount. i could clearly see where the thing had burst and something rust colored had spilled on the mount. got under there and changed both mounts myself one afternoon after work. thanks for the tip about getting some 30 inc 1/2 inch extensions. i used a 2 ton floor jack and a wood block to support the transmission/engine. took some muscle to remove the engine mounts from the support bracket. by the way i had the electric ones which made a horrible loud noise at startup. just disconnect the wire and tape over the connectors. i got 4 motor mounts from a place deh i believe in calif. for $100.00 one day i'll replace the two on the top side. best news of all. the clinking noise is gone when i hit a bump in the road.
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
dvcamp
Sep 18, 2015 10:17 AM
Maxima30
Sep 7, 2015 06:13 PM
