ABS Sensor
Old Dec 15, 2009 | 10:02 PM
ohitzme's Avatar
ABS Sensor
Recently i had to replace my driver side spindle/knuckle not sure what it is exactly called but i called a local junkyard and found one for $75 off an 2003 infiniti i30 ($300 new from the $tealership) picked it up still had an ABS sensor in it and thought i could use it since mine was seized in. Well turns out the connectors are different so should i try splicing the wires in off my old one or should i spend the $150 for a new ABS sensor?
Old Dec 16, 2009 | 11:38 AM
Colonel's Avatar
Old Fuddy Duddy
If you can get the pinouts of the sensor connector, I would try rewiring the sensor to work with your existing connector going into the wheel well. I would not change the connector on the engine side.
Plus if you go to DaveB, you wont be paying 150. I have a left rear thats had a CEL, but I have yet to walk the wire back into the engine bay as the error code is an OPEN error versus a short error.
my03maxima
Jul 28, 2024 07:40 AM
leatherneck
Sep 30, 2015 09:16 PM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
