PCV Valve locations?
Did my search, but couldnt find the answer.
Does anyone know where is to be exactly the location of the PCV valve. i need to change mine. my car is '00. thanks in advance
It's on the driver side. If you look at the engine bay, standing on the diriver side, it's just to the left of the throttle body. You will have to remove a few things that are in the way to have better access to it.
the yellow circle it where the hose is that you can follow down to the lower PCV...the upper PCV is located where the top yellow X is on the picture!. U also have a breather valve that connects to your intake system from the driver side of the front valve cover.
hope i helped :-)
hope i helped :-)
. btw, how many PCV valves do i need? i thought our car only had 1 PCV valve.
I'm betting you got one of the generic replacements from a parts store, right? If you looked at it before you replaced it, you would see that it has a stepped edge where it's supposed to fit. Sort of like this...
That little second step is what butts against the block, not the larger step. It looks and feels like the valve isn't fully seated and it does wobble. But, it's in as far as it can. It's not the best design.
tseng1023
Oct 15, 2015 08:30 AM
hayne
Oct 5, 2015 11:53 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
