Will this O2 sensor work?
Old Dec 22, 2009 | 07:37 AM
xuimod's Avatar
This sensor has 4 wires but I just noticed the bank 2 sensors have 3 wires. Will this sensor work (if I splice 3 wires and leave 1 hanging)?
Partstrain.com says the sensor will work for a 2001 Maxima.
Old Dec 22, 2009 | 08:12 AM
The6spdMax's Avatar
Check to see if there is a wiring instruction inside the box. When I replaced mine, there was instruction inside the box. It is pretty straight forward, you just need to solder it.
Old Dec 23, 2009 | 01:54 PM
Col Ronson's Avatar
eh its cheap but i dont know if its compatible. I know for a fact that a Bosch is one of the few aftermarket confirmed O2 sensors that work... thats because the OEM sensors are just Bosch sensors as well they just have the plugs wired in for you.
Old Dec 23, 2009 | 03:43 PM
Unklejoe's Avatar
You might have to use splice connectors, the ones with the ends that can be heat shrunk.
I wasn't able to solder the wires because of the material they were made out of. (Stainless Steel I believe)
maxinout93
Oct 27, 2015 01:29 PM
homeyclaus
Sep 3, 2015 06:15 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
doobadoo
Aug 15, 2015 06:43 PM
kenc15
Aug 5, 2015 08:29 AM
