Day after the blizzard........ Codes
Old Dec 22, 2009 | 02:18 PM
Grand_hustle17's Avatar
O.k so im just hoping this was just some coinsidence of some sort, but after digging my car out the snow yesterday i turned it on and let it warm up, after driving to my job to go get my brother a Xcrap for christmas i realised i had a very odd idle, car would want to sputter randomly... on my way to work today it got way worste, it just sputters all the time and the CEL starts blinking... i decided to go by advance to pull codes and this is what i got... P0303, P0420, P0158, P0442... i didnt look the codes up yet cause for some reason im not finding the long sticky with all the codes... anyways that P0303 (cyl. 3 miss fire) is what is gettn me... my spark plugs are about 3-4months old, what could cause me to blow spark plugs so much?
Old Dec 22, 2009 | 05:40 PM
VQP0WER's Avatar
Those codes are for the 3way catalyst, O2 sensor, #3 cylinder misfire, and a EVAP leak.
I'm think a bad vacuum hose so I would inspect for that. You can check your #3 cyclinder coil by disconnecting the coil while the engine is running, if the engine does not hesitate when you do that, it means the coil/plug is bad.
Old Dec 22, 2009 | 06:48 PM
But isn't cyl 3 one of the rear plugs??? How can I have the car running if so??? Wouldn't the IM have to be off??? I do smell gas
Old Dec 22, 2009 | 08:04 PM
spock's Avatar
Did you check underneath the car for any wires, hoses that could have got messed up do to the heavy snow?
Old Dec 22, 2009 | 08:14 PM
No not as yet... unfortunately there is still a lot left on the ground in my complex and at work so I can't even checked without gettn messy... ntm would assume its messy under there and probebly couldn't pinpoint but I thought the samething... f*ing snow, ish
Old Dec 23, 2009 | 04:12 PM
OutMaxxed's Avatar
Yes it is a rear plug, 2nd from the left (or right doesnt matter). Take the bolts that hold in the coil but leave the coil in the engine. Start up the car and then pull out the plug while its running. If the coil is good then the engine will slightly bog, if its bad nothing will happen. Make sure its quiet wherever your doing this cause I had to really listen/look at it to notice. Hell you can even pull any other coil to compare. Good Luck
Old Dec 25, 2009 | 05:55 AM
well that is true... fortunately i have three coils just sittn in my house so ill just switch it regardless... what could be the cause for excessive gas smell???
Old Dec 25, 2009 | 06:24 AM
VQP0WER's Avatar
Gas not being burned due to lack of ignition.....
Old Dec 25, 2009 | 08:14 AM
hmmm i see... im bout to get to work in this sucky weather and no garage
Old Dec 25, 2009 | 08:24 AM
VQP0WER's Avatar
You could be looking at a leaking injector as well.
Old Dec 25, 2009 | 11:21 AM
Even though there is no codes for it???
Old Dec 25, 2009 | 07:08 PM
Barada's Avatar
its the coil for sure.. i had the same problem
The gas smell.. could be the catty. im not 100 on that one.
Old Dec 27, 2009 | 05:10 PM
Yes it was the coil... ill post pics in a few... it was a tad burned... wonder y???
Old Dec 27, 2009 | 06:50 PM
billygeg's Avatar
sounds to me like something got wet...kind of a coinsidence it happened the day of the snow..Is it still doing it?
shilov
Feb 19, 2024 09:40 PM
Mar 12, 2020 12:06 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
Steven Orozco
Sep 12, 2015 10:41 PM
NissanNismoZ
Sep 12, 2015 07:30 AM
