Doors, Help ! WHAT THE HELL
So last year my rear door decided it did not want to work anymore, it was in the winter ofcourse, it would not close and stay closed, after a few tries it stayed close and not it wont open and the lock feels jammed up, So today, 19F outside, i get in, the drivers door does the same thing, 3 times and it closes, i go to get out and wtf it wont open and the lock feels all jammed up, this is on the drivers side, so now i have 2 jammed doors , i dont know what to do, i had the cover off in the back and i cant get it open, now i have no way of getting the cover off the front to even attempt to work on it.
back door stays 'locked'
My Max has same problem, except it happened this summer. you can open with key for drivers/front door, but in my case its one of the rear doors. How can you get the door opened or the panel off while its closed?
I have GLE model and it comes with small levers just above door handles inside the car; by 'manually' I meant to unlock the door using those and not the power door switches. Not sure if yours has them as well.
yea...sorry for confusion...i tried unlocking manually like you just described. the manual lever moves, but doesn't go all the way to the unlocked position.
If the weather is crazy freezing like here then it might be just frozen water and it will start working when it warms up or slowly evaporates. If it was like this even in summer then you might try your luck by removing trim around handle and switch panel to gain some access to the internals of the door. The door plastic has screws only on top and all of them can be removed with door closed. The sides/bottom are held in place with bunch of plastic clips. If you remove all the screws and the top of the plastic it might give you more room to access the door internals.
To remove the door panels you need to remove the rear bench seat if since the door will not open up. There should be one or two black strap hooks sticking out under the seat. You want to pull on them. This will give you access to the door panels. You probably need to grease up some of the parts inside. gl
my rear driver door opens to a point and then stops. im gonna try wd-40 today. only happens in cold weather. also i washed my car after the snow and froze myself out of my car! hahaha careful. I am going to call up the stealership and check out if my model had any recalls, cross my fingers
http://www-odi.nhtsa.dot.gov/cars/pr...ls/results.cfm THAt is the national recall list from the governemnt so u can look at that site to see cause for some reason some dealership be like oh nah u don't have any recalls and I'm like *** hole I have recall number and then all of a sudden their computer comes on and say oh wait u do have recalls lol good luck hopefully they don't play no games with u
REDinLV
Aug 15, 2024 12:30 AM
magiconthetire
Oct 26, 2015 09:03 PM
trsandrew
Oct 25, 2015 02:47 PM
RealityCheck
Oct 2, 2015 06:34 PM
.......> jk WD40 those suckas
