Car shaking after tuneup HELP
Old Dec 24, 2009 | 12:06 PM
DoNcHoYaX1's Avatar
I have a 2000 maxima gle with 167k miles. The car is in mechanically good shape. No real problems since I bought it 4yrs with 100k miles. I decided to do a tuneup but now the car is shaky when in gear and when its just driving off. It Idles fine I cant seem to understand what it is. I know I have to replace the O2 sensors but that shouldnt have to do with the car shaking. I replaced all parts with oem nissan parts.
Old Dec 24, 2009 | 12:38 PM
Unklejoe's Avatar
Exactly what parts were replaced during the tune up?
Old Dec 24, 2009 | 01:03 PM
VQP0WER's Avatar
I take it he replaced the plugs, and in the process, prolly didn't seat a coil good enough.
Also, whats with all the advertising spam links in your sig?
Old Dec 24, 2009 | 01:12 PM
DoNcHoYaX1's Avatar
I replaced the sparkplugs pcv valve, filters
Old Dec 24, 2009 | 03:41 PM
Unklejoe's Avatar
+1 VQPOWER
Old Dec 24, 2009 | 04:50 PM
Skorp1on's Avatar
look for un-plugped vacuum lines, in case u had to take any off. In addition to shaking, ECU could throw a code. g'luck
Old Dec 24, 2009 | 05:56 PM
67whitegoat's Avatar
Did you check the gap on all 6 plugs before installing them? Sounds like a misfire you didn't have prior to working on it. First step...Double check your work.
Old Dec 24, 2009 | 06:13 PM
asma123's Avatar
when in gear and you're idleing whats the rpm at?
Old Dec 24, 2009 | 06:39 PM
maxfever1987's Avatar
i think you the have an undetected misfire, soon your ecu should throw a code for it, but check the harness clips for each coil and also make sure they coils are on nice and snug.
Old Dec 24, 2009 | 07:00 PM
DoNcHoYaX1's Avatar
ok I will check the coil packs to see if they are all pressed down. Thanks
Old Dec 26, 2009 | 09:11 AM
dklanecky1's Avatar
Had a similar issue with my 2K and found I messed up a coil pak when I removed it. They get somewhat fragile after 100k miles.
Old Dec 26, 2009 | 11:43 PM
foodmanry's Avatar
Da Roller Coaster!
Check for spark plug gap...coils properly seated and connected properly...vacuum hoses properly connected and no leaks.
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
jhontelj
Aug 17, 2015 04:07 AM
Balkins
Aug 12, 2015 06:39 AM
