a few questions.
Old Dec 26, 2009 | 01:38 AM
xshadow715's Avatar
a few questions.
hey guys i was just wondering if you can answer some of my questions for me.
first of all i am planning to get 10000k hids on my max and iwas wondering if i need to replace the projectors too?
2nd my steering wheel whne going straight is kind of angled towards the right a bit and is kind of like annoying at times how could i fix this? ( and how much if its going to be a dealer job)
and 3rd how would i be able to tell if my transmission is starting to turn bad? i have a feeling it is but theres no ses light or anything but like idk maybe its just the cold?
thank you.
Old Dec 26, 2009 | 06:43 AM
VQP0WER's Avatar
First, if you want to see nothing, then you should get the 10k HIDs. My LED flashlight would put out more light then 10k HIDS and honestly, they look rice. You don't have to replace projectors.
In regards to your steering, get a front end alignment.
It helps if you provide more information, like if it's a auto or manual, and what makes you think your tranny is going? A bad tranny will not give you a SES light.
Old Dec 26, 2009 | 07:39 AM
xshadow715's Avatar
which HIDs would you recommend then?
ive had this car aligned so many times its just the steering wheel though
its auto andbecuase idk the shifts seem to take more time?
one more thing added to the list though around 2100rpms at first and 2nd there seems to be a wobbeling noise on the front right its not the wheels because when i put it in neutral i can hear the noise also? but for some reason most of the time its only if i have some1 in the passenger seat that it makes noise?
Old Dec 26, 2009 | 07:49 AM
02SEMax's Avatar
i can't help you with the the other questions, but maybe with the pulling problem
do you have correct and good performance tires on the car? i have an 02 that had pulling problems for quite a while, but it was literally b/c i didn't have good tires on the car. Hope this can help
Old Dec 26, 2009 | 07:59 AM
fishpony's Avatar
What year maxima do you have?
if it's a 2002-2003 get 4300k or 6000k MAX for best visibility.
2000-2001 get an 02-03 headlight swap please before you get HID's
Check your tires and take it to a Good alignment shop and have them drive the car. They should know what is going on. Tell them you want your steering wheel straightened.
As far as transmission. Mine has been slipping for quite awhile now but hasn't gone out. Check your transmission fluid and maybe get it replaced.
Old Dec 26, 2009 | 08:06 AM
xshadow715's Avatar
its an 01, lol whats wrogn wtih the headlights?
so is my transmission slipping?
Old Dec 26, 2009 | 08:19 AM
User 12822's Avatar
Your wheel wobbling can be solved easily with a computerized alignment as long as you arent dropped. It shouldn't cost more than around $40-50.
As far as your tranny there are tell tale signs. When the tranny shifts the RPMs should drop instantly as you go into the next gear. If when the tranny shifts the RPMs jump up a bit or seem to hang in place, you are spiking and you have a serious problem.
The shifts should also seem relatively unnoticeable as in they should be fairly soft and quickish. If you could make a video or describe more how it behaves I can help more.
But if you have anything I listed above, start shopping around now for a new tranny, don't waste time on a rebuild. And you can trust me on this issue, I blew out my auto tranny so I know all too well the symptoms.
But again don't get too scared because there are a few things that could make you think the tranny is broken when its another part that can effect it, post more info.
Old Dec 26, 2009 | 09:24 AM
VQP0WER's Avatar
Since you have an 01, you don't have projectors to begin with. I have 6k HIDs in mine and they are pretty good. When I had 8k HIDs people were flashing me left and right because of the awful glare.
If your transmission is like alot of ours, specially when it's colder out, you will notice a slight shift delay from 2-3 gear. It has been doing this to me for years every winter time. It typically goes away when weather is warmer and the transmission fluid has heated up.
Old Dec 26, 2009 | 09:33 AM
tothemax2003's Avatar
Should get the tranny fluid changed most people forget the tranny fluid, but do not get it flushed.
Old Dec 26, 2009 | 10:16 AM
xshadow715's Avatar
is there any way to check if thats the problem?
so what would i have to do if i did want 6k HIDs? get projectors? they dont have a premade assembly for the headlight things?
Old Dec 26, 2009 | 10:34 AM
RLStrick756's Avatar
I thought that 01 lights (not HID) were not able to be directly switched with OEM 02+ lights, which are HID? If the outer lens is cloudy, the are methods of cleaning and polishing the outer surface along with going with a high end aftermarkiet bulb within the OEM specs.
If the alignment is fine, then I've heard that steering rack (bushings) might be the problem.
The auto trans will act up with old and/or low fluid, but I thought Nissan could do a Consult diagnositc check of the electronic controlled transmissions?
Last edited by RLStrick756; Dec 26, 2009 at 10:41 AM. Reason: turbozx96@earthlink.net
Old Dec 26, 2009 | 10:49 AM
User 12822's Avatar
My tranny completely went, lost reverse, lost 1st and 2nd gears, the car moved forward if revved in neutral, NO SES light came on. I wouldnt waste time on the consult, describe more what the tranny issue is. I'm surprised you haven't responded to me lol.
Old Dec 26, 2009 | 11:19 AM
ridinwitha35's Avatar
+1 with others, no reason to go over 6000k HIDs. Bigger number doesn't mean better.
Old Dec 26, 2009 | 12:41 PM
xshadow715's Avatar
my bad ive been at the doctors al lmorning.. but anyway on topic: idk it shifts at higher rpms and it like takes a little why like i notice it now to shift from 1-2 and 2-3. idk how to check the fluids but im sure they are fine?
Old Dec 26, 2009 | 01:47 PM
VQP0WER's Avatar
You can get the HID kit from hidextra.com
If you look in our Group Buy section, they have a coupon code for a discount. You are looking at about $60 for the ballasts, bulbs, wiring. It will directly connect to your stock headlight harness and the bulb will directly fit into your stock halogen housing.
http://forums.maxima.org/group-deals...g-members.html
Old Dec 26, 2009 | 04:49 PM
rroderiques77's Avatar
Demodded and Forgotten
You are sure they are fine??
Why don't you do yourself a favor and start by checking the tranny fluid (while it's running of course) on level ground? Low fluid can cause irregular shifting point. Also remember that you are only going to get a tranny related MIL if it has electrical problems.
Old Dec 26, 2009 | 06:29 PM
Scottwax's Avatar
That's Mr. Detail to you
Actually, no reason to go above 4300k since the whole purpose of HIDs is to put more light on the road.
Old Dec 26, 2009 | 08:18 PM
jasonmax's Avatar
Ive been driving with a slow 2-3 shift for 2 years, nothing changed, just warm up the car a bit before you release your heavy foot.
Old Dec 26, 2009 | 08:19 PM
jasonmax's Avatar
werent you doing all this brake stall launchs before the the tranny went?
Old Dec 26, 2009 | 09:11 PM
User 12822's Avatar
Yeah man that tranny took serious abuse from me. Im no expert but it may well have took 3-5 years of abuse in the 8 months I drove it before it broke. You name it, I probably did it. Gotta learn somehow right? lol the cost of the rebuild was enough to tame me reaal quick.
Old Dec 26, 2009 | 10:03 PM
Scottwax's Avatar
Same here. Doesn't seem to be getting worse, have 166,350 miles on the original transmission now.
Old Dec 26, 2009 | 10:08 PM
maximal01's Avatar
transmition flush might help out alot it did with mine 200,000 an going strong
Old Dec 27, 2009 | 07:27 AM
xshadow715's Avatar
how about that noise? anyone have an idea what that might be?
Old Dec 27, 2009 | 11:44 AM
VQP0WER's Avatar
Does it change with RPM, or is it constant?
Old Dec 27, 2009 | 12:20 PM
Chris Gregg's Avatar
Get Off My Lawn
Wheel bearing? Taping the brakes change/eliminate the noise? Maybe brake dust or brake pads?
Old Dec 27, 2009 | 06:47 PM
billygeg's Avatar
ttt
Old Dec 28, 2009 | 08:30 PM
xshadow715's Avatar
the noise happens at around 2100 rpms first 2nd and 3rd gears. its louder with some1 in my passenger seat. its not the bearings i know what the bearings sound like
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Socalstillen
Sep 20, 2015 11:46 PM
pears
Sep 18, 2015 05:25 AM
