Heater fan only works on High (#4)
Old Dec 29, 2009 | 08:30 PM
00MAXI's Avatar
What could it be???
Old Dec 29, 2009 | 09:30 PM
Mr. Brett's Avatar
It's because the resistor in the motor has gone bad. You'll have to get a new resistor. It's actually a pretty easy fix. The part is about $30 from Nissan I believe. See if you can find a used one first, though.
Search through the stickies. I believe there are a few how-to threads on this around...
Old Dec 30, 2009 | 10:17 AM
Professor's Avatar
Easy fix, a trace on the circut board melted on mine and i resoldered it, worked since, however it may not be your case , could be toasted.
Old Dec 30, 2009 | 10:45 AM
Ricky429's Avatar
Very very easy i had to do mine
http://www.vqpower.com/v2/faq.php?cat_id=1
Scroll ll the way 2 the bottom
you dont have 2 take out the glove box
Old Dec 30, 2009 | 11:03 AM
fflint_18's Avatar
Ditto.
If you are handy with a soldering iron you may be able to fix.
Otherwise I'd buy a new one. A used one could be heading down the same path as yours and fpr $30~$40 you can't go wrong.
And make sure you change your cabin air filter while you have the glovebox out.
Old Dec 30, 2009 | 11:05 AM
BuRoJo's Avatar
'00 GLE
The cost of the resistor depends on whether you have a manual or automatic HVAC system. The one for the automatic costs more...
Old Jan 6, 2010 | 02:19 PM
FanaticMadMax's Avatar
definitely the blower resistor, you can get one from Autozone, but i'm not sure, cuz i work there, I'm always googling all the parts see what they carry for our 5th gen, surprisely most of them they don't carry that has to be special order which is bullsh*t. lol
Old Jan 9, 2010 | 07:40 PM
KBCobra's Avatar
Lucky you, my heater practically burns your face while you drive. It's sooo hot even if I lower the heat -_-
Old Jan 9, 2010 | 07:44 PM
User 12822's Avatar
Word right!? In a 5th gen there is no compromise, you either burn in the winter, and then the AC in the summer is so damn cold you'll catch a cold. That **** requires some precise as tuning to be able to just set it and leave it. Otherwise you gotta keep turn the fans back on and off.
Old Jan 9, 2010 | 07:57 PM
KBCobra's Avatar
Yup but if I'm driving alone I close the driver side vents and open the passenger vents. That evens it out haha
Old Jan 11, 2010 | 06:22 AM
ColtMax's Avatar
There is got to be something wrong with my Max! A/C works just fine in summer, but the heater takes for ever before blowing what I would call warm air.
I have tried everything,
- Engine thermostat
- Ambiant air temp sensor
- Radiator cap
Blower works fine, but pratically no heat is comming from the ducts...
Old Jan 11, 2010 | 07:28 AM
Mr. Brett's Avatar
That really bothers you guys?
I love the fact that my Max's A/C is so powerful. Especially with it getting as hot and humid as it does where I live. Nothing's nicer than having to walk outside in the heat, and then getting into an ice-cold car after.
dr3am
25
Oct 22, 2015 08:53 PM
homeyclaus
Sep 3, 2015 06:15 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
acw
Aug 7, 2015 04:20 PM
kenc15
Aug 5, 2015 08:29 AM
