Dtrl are not coming on...
Old Jan 4, 2010 | 11:52 AM
AznTran517's Avatar
It was snowing pretty good in philly when my drtl started to not come on..
Im pretty sure I blew a fuse somewhere (fog light are rewired tot he tail light from the fuse box underhood.) I checked the DTRL fuse and thats still good.. Is there any other fuses I should check for like under my hood?? I need this fixed asap because my tail lights are not comin on at night unless I use my brakes.. Thanks.
Old Jan 4, 2010 | 12:28 PM
jasonmax's Avatar
I think you need to check the DTRL module for connection
Old Jan 4, 2010 | 01:23 PM
AznTran517's Avatar
Sorry to sound like a noob but do you know where that is located and how can I do that?
Old Jan 4, 2010 | 01:42 PM
Nelsito65's Avatar
If I'm not mistaken, it is behind the passenger side headlight. A search for "drl module" would probably give you more info.
Old Jan 4, 2010 | 05:25 PM
knight_yyz's Avatar
Toolie
actually if the tail lights are not coming on you blew that fuse.
Old Jan 5, 2010 | 12:16 PM
n3985's Avatar
大陆弟弟
You have DTRL on your car OP? Is your car Canadian spec? DTRL = daytime running lights I assume
If your tail lights are not working you blew a 10A fuse in the driver's side fuxebox, forgot the name, was in right column near the middle I think.
Old Jan 5, 2010 | 01:06 PM
knight_yyz's Avatar
Toolie
because the foglight rewire uses the tail light fuse it has a little more load than before. so that one will blow a little easier than it should.
Old Jan 5, 2010 | 03:16 PM
AznTran517's Avatar
I went to check the fuse box under the driver side fuse and the only fuse that looked like it was relating to tail lights was the stop light fuse but they comes on when I use the brakes. I couldn't check the fuse yet but I will update when I do.
Old Jan 5, 2010 | 03:40 PM
knight_yyz's Avatar
Toolie
I think the tail light fuse might be under the hood
Old Jan 6, 2010 | 10:17 AM
AznTran517's Avatar
It was the tail light fuse. I just dont understand why my side markers, clock, radio,etc lights wouldn't come on from one fuse! It was driving me crazy lol. Thanks for all the help guys!
Mar 12, 2020 12:06 AM
ballerchris510
Sep 23, 2015 08:46 PM
Jay556
Sep 12, 2015 05:50 PM
Violator
Sep 9, 2015 10:14 AM
lux97Max
Sep 4, 2015 05:42 PM
