Question about ABS codes
Old Jan 7, 2010 | 12:52 PM
knight_yyz's Avatar
Toolie
hey guys, I tried helping out a friend with his ABS system but we are kind of stuck now. I ran my scanner on we got the code for the ABS module itself. So we checked all fuses and relays and found nothing wrong with them. So we swapped out the ABS module. But the code is still there. Is the code supposed to clear itself or do we need a consult to clear it. I tried following the instructions in the FSM by grounding out one of the OBD2 pins, but all that did was blow a couple fuses. The FSM says to ground out pin #8, but they show you pin number ( in the manual) Had to go online to figure out where pin number 8 was. Anyone do this successfully?
Old Jan 7, 2010 | 01:47 PM
ecrash's Avatar
Pretty sure the ABS system does a self test every time you start and drive the car. If it finds a fault, the light comes on and stays on until the next time you turn the car off and on.
Old Jan 7, 2010 | 01:54 PM
IHAVEA2KMAXIMA's Avatar
Sorry I dont mean to hijack but is it normal for the ABS light to come on when key is in "ON" position? It turns off when I hit ignition though.
Old Jan 7, 2010 | 06:16 PM
knight_yyz's Avatar
Toolie
Yes, but if there was a fault and the fault is repaired you have to erase the code. Page 49 of the BR section of the FSM.
mvm062
Nov 30, 2020 09:00 AM
bbsitum
Sep 6, 2019 07:31 PM
NissanNismoZ
Sep 12, 2015 07:30 AM
Johnny9595
Sep 3, 2015 05:18 AM
maximusrising
Sep 2, 2015 09:55 AM
