Trying to lower coilovers
Old Jan 11, 2010 | 05:17 PM
Grand_hustle17's Avatar
Couldnt think of a better topic but basically i will be attempting to lower my coilovers some more, but the grooves are a bit rusty, i wanna have everything i need just incase they dont budge... there is no grease or nothing on em, they are just rusty, my friend was saying a wirebrush may bo the trick, so ill go get that some WD40 and some PB blaster lls ill try get a pic of the coilovers.............
Old Jan 11, 2010 | 05:22 PM
http://forums.maxima.org/5th-generat...coilovers.html..............
Im pretty sure the rears are no problem but the fronts is what gets me
Old Jan 11, 2010 | 05:28 PM
2slow's Avatar
It's just like you friend stated, PB Blaster and a wire brush. Oh, and soak them in PB Blaster for as long as you can; maybe spray some on there once a day for a few days prior.
I am surprised the threaded section is not aluminum.
Old Jan 11, 2010 | 05:32 PM
k... will be doing that tomorrow and the day after... going to lower them all the way down in the front and half way in the rears
Rood's Avatar
Im having the same problem with one of my rear k sport coilovers.... I used a toothbrush, which helped somewhat to get some crud out, but stoll no luck.
Ill try PB blaster. Get back to us if you find the magic trick
Old Jan 11, 2010 | 05:34 PM
what the car looks like as of right now..........................
height is o.k but not where i prefer it
Old Jan 11, 2010 | 05:42 PM
for sure
Old Jan 11, 2010 | 05:58 PM
johnnyd2k2's Avatar
I'd start by cleaning them up with some fine steel wool then PB blaster to break em loose then use some wheel bearing grease to help them turn smoothly then wipe it all off and reapply a thin coating to keep them from further corroding.
Old Jan 11, 2010 | 06:04 PM
sounds great... only if i can get such grease... any substitute for that???
Old Jan 11, 2010 | 06:19 PM
johnnyd2k2's Avatar
You can get it at Autozone and Advance Auto its pretty common easy to find stuff, just ask they'll know what you're talking about.
http://www.autozone.com/autozone/cat...randName=Mobil
http://shop.advanceautoparts.com/web...51_T%7CGRP2035____
Old Jan 11, 2010 | 06:41 PM
K... thx... I didn't kno that
Old Jan 11, 2010 | 07:13 PM
e-subliminal-2's Avatar
I see you liked my rims so much eh?
Old Jan 11, 2010 | 07:55 PM
perkman87's Avatar
Yup pb blaster, and a brush. After that i would recommend a silicone based grease so you dont have any more corrosion.
The car looks good for a 13.84 car lol!
We will see after my powwwah mods!
Old Jan 12, 2010 | 01:24 PM
... i got another look that will make eyes drop on here lls
Old Jan 12, 2010 | 01:38 PM
Thank u, u think ur mods will own mines??? goodluck, wish u the best fo real yo
Old Jan 12, 2010 | 02:13 PM
MoncefA33's Avatar
Watch out Hustle - I'll see you at Maxus
Old Jan 12, 2010 | 02:30 PM
perkman87's Avatar
werd.
Old Jan 12, 2010 | 02:52 PM
PininFarina456's Avatar
Do you have the tool that came with the coilover to adjust them? That always makes it 100x easier.
Spray wd-40 on them like no other and use the tools. You should be ok.
BTW, car looks great, what rims are those?
Old Jan 12, 2010 | 03:35 PM
HotshotVQ35's Avatar
you can use channel locks but these make it way easier..
Old Jan 12, 2010 | 04:43 PM
i will be using the locks, im just worried about it not turning cause its so rusted
Old Jan 12, 2010 | 04:45 PM
thehoop's Avatar
you should look into getting the threads coated/anodized so you dont have this problem again
Old Jan 12, 2010 | 04:46 PM
dont spray... i will be racing at maxus, if all goes well i should have a low 13 possibly 12 sec automagic yes i said it, 12seconds N/A, go ahead laugh now too
Thanks bro, they are the 350z anniversary edition wheels
MaxLvr21
Oct 17, 2015 12:11 PM
JonBlz
Oct 5, 2015 06:02 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Garrettz459
Sep 28, 2015 02:50 PM
