brake parts depending on build date
Old Jan 15, 2010 | 07:23 AM
rockfordmaxII's Avatar
Ok, i need a new rear caliper for my 01. build date on the car is 10/00. when looking at advance auto parts site, it says that its either two different calipers, ones for different build dates, before 10/00 or from 10/00. First question is which one do i need then? because technically mine was built IN 10/00 lol. my guess would be the from 10/00 and unfortunately its the more expensive one, of course. also, what is the real difference, the newer calipers are 20 bux more so why couldnt i just use the cheaper ones?
Old Jan 15, 2010 | 08:54 AM
vinco's Avatar
Get the cheaper one and compare it to the one on your car. If it won't work, then return it and get the other one.
Old Jan 15, 2010 | 10:16 AM
SuperStasiu's Avatar
BINGO TTAAADDDDAAAAAAA
Old Jan 15, 2010 | 04:02 PM
foodmanry's Avatar
Da Roller Coaster!
Or....call dealer and match your VIN to the parts date. Then order the correct caliper from Advance Auto.
Old Jan 15, 2010 | 04:11 PM
SteveB123's Avatar
If you are getting the calipers AND brackets, it probably doesn't matter. If your not, it probably does.
Any reason you don't just order the right (FROM 10/01) ones and be done with it?
Is your time really worth less than that $20 to order the wrong parts, try them, and then go back to get the right ones?
Old Jan 15, 2010 | 06:27 PM
foodmanry's Avatar
Da Roller Coaster!
Again a simple call to the dealer parts counter with your VIN will solve this entire mystery....
Why does everyone take the hard road?
Old Jan 17, 2010 | 09:45 AM
called the dealer and he said to go with the from 10/00 one, but he didnt really know the difference. took old one off, went into advance and compared the three. only difference was the grooves in the piston so i just got the cheaper one and it works just fine, no difference in size or anything really. and as a matter of fact yes, my time is worth the $20. i would rather spend 2 hrs on a 1 hr job to save the 20 bux
MAXSE5SPD
Sep 17, 2022 04:00 AM
AcuraLegend
Sep 22, 2015 04:22 PM
homeyclaus
Sep 3, 2015 06:15 PM
A32goldylocks
Sep 2, 2015 06:39 AM
