Changing MT fluid...i have a question
Old Jan 18, 2010 | 08:10 AM
NissanMan97's Avatar
Im going to change the MT fluid in my 02. I have the HLSD does that effect the overall fluid capacity or is it the same? im trying to make sure i buy enough fluid.
B
Old Jan 18, 2010 | 09:40 AM
knight_yyz's Avatar
Toolie
It's the same capacity
Old Jan 18, 2010 | 09:51 AM
thanks...thought it might be a dumb question but better safe than sorry
B
Old Jan 19, 2010 | 11:21 AM
demasi1515's Avatar
Don't know if it matters...but, I changed my MT Oil in my `03 6spd last summer. I used the AMS Oil synthetic, works great, a little on the pricey side however. I think I used just under 4 quarts, can't remember though.
Old Jan 19, 2010 | 11:29 AM
fflint_18's Avatar
It's about 2.5 quarts if I remember correctly.
I used Redline MTL 90 full synthetic.
When you refill make sure you are on a flat level surface and fill until it starts coming out the fill hole.
And don't forget some cardboard on the ground to catch that overflow.
Old Jan 19, 2010 | 09:34 PM
kbohip's Avatar
Since we're on the subject, how often do you guys change your manual trans oil? I did it once at about 60k miles and I'm thinking of doing it again at 100k which should be within the next 6 months. Redline MT-90 btw.
Old Jan 20, 2010 | 04:46 AM
knight_yyz's Avatar
Toolie
motul 75/85 is the best, and the most expensive.
Old Jan 20, 2010 | 05:04 AM
can you verify that it is the best? and where can you get it?
i have the dread 3rd gear crunch and i heard the MT90 tends to lessen this a little. ill pay the extra $$$ to keep my car running i dont care
B
Old Jan 20, 2010 | 08:06 PM
K20z1_rsx's Avatar
I used Redline mt 90 in my 6 speed I bought it from jeg's. You can get Amsoil from the local bumper to bumper auto parts stores in Louisville. I would say it is just as good.
Old Jan 20, 2010 | 09:09 PM
joeltender's Avatar
I switched to Motul 75-85 and noticed improvement. Unfortunately 3rd still crunches, but it's better than before.
Definitely seems to "warm up" faster than last winter
Old Jan 21, 2010 | 04:56 AM
sweet another Lou KY member. Im sure i see you rolling around now that i know what to look from.
i may go with redline general consensus is pointing towards it.
B
Old Jan 21, 2010 | 05:16 AM
i can only find a 75w/140, 80w/90 and a 75w/90 in Motul
B
Old Jan 21, 2010 | 02:33 PM
knight_yyz's Avatar
Toolie
B
I have run, in no particular order, amsoil, redline, mobil 1 synthetic, motul 80/90 and motul 75/85. The motul 75/85 has outperformed all the other oils, including the freezing cold. It shifts like butter all year round. Motul ran out of the 75/85 last year when I went for a lube change so my mechanic put in the 80/90 and it sucks right now.
Old Jan 21, 2010 | 02:36 PM
knight_yyz's Avatar
Toolie
oops.. ok my mistake, I thought it was 75/85 but the better stuff is 75/90 the 80/90 is in my car right now and I don't like it. BTW my mechanic races on the weekends in a sentra and he uses the 75/90 as well. sorry for the confusion.
Old Jan 21, 2010 | 03:08 PM
SteveB123's Avatar
Both of those oils are the same viscosity when warm.
Why don't you like the 80W-90, as opposed to the 75W-90?
Old Jan 25, 2010 | 04:44 AM
so get the 75/90? i found that on some website...thanks for the help
B
Old Jan 25, 2010 | 05:25 AM
knight_yyz's Avatar
Toolie
the 80/90 does not shift as well in the cold, the 75/90 is much better in the sub zero temps. I'm talking -15 Celsius it is a night and day difference.
Old Jan 25, 2010 | 07:40 AM
i think it get to 0 Fahrenheit at the coldest here at night which it hasnt done yet. but it does get hot as hell in the summer 90+ even in the 100's.
would you still recommend the 75/90 or could i go with the 80/90 since it doesnt get that cold?
B
Old Jan 25, 2010 | 05:18 PM
knight_yyz's Avatar
Toolie
I haven't driven with the 80/90 in the high heat yet, but as I said my mechanic races his sentra with the 75/90 and he beats the hell out of the tranny, no repairs to the tranny yet. So I would stick with the 75/90.
Old Jan 26, 2010 | 05:04 AM
that pretty much makes my mind up for me then. thanks for the help
B
matts95max
Apr 23, 2025 10:44 AM
markevans999
Oct 25, 2015 08:27 AM
Courtneysnow
Sep 4, 2015 05:10 PM
Johnny9595
Sep 3, 2015 05:18 AM
sdotcarter
Sep 2, 2015 09:53 PM
