help please
Old Jan 22, 2010 | 09:53 AM
914Max914's Avatar
help please
So i installed a Oil catch can that i purchased from home depot. the "huskey filter". on the bottom of the filter there is a little breather that sucks in air and you can hear it almost whistling. im getting a P0507 code "high idle code" and my RPMS are sitting at 1000 when its warmed up. should i plug the hole? is it supposed to be there? does any one have a oil catch can with a breather on it? thanks for the help in advance i appreciate it
Old Jan 22, 2010 | 09:54 AM
P. Samson's Avatar
Yes, plug it......its a "vacuum leak".
Old Jan 22, 2010 | 09:55 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
i dont have it but plug it nd see what happen, i dnt recall seeing a breather on any of the ones shown here
Old Jan 22, 2010 | 09:57 AM
914Max914's Avatar
ok ima go plug it, thanks alot for the quick responses.
Old Jan 22, 2010 | 10:03 AM
Ghost_54's Avatar
You will also want to clear the code you are getting, then plug the vac leak and hopefully all should be good to go.
Old Jan 22, 2010 | 10:31 AM
914Max914's Avatar
yea ima disconnect the battery terminals to reset the code cause im not good with timing with the pedals and stuff lol, but thanks alot for the help i pluged the hole and the rmp is sitting lower like stock somewhere between 800-900 i really appreciate the help guys thanks
