LOW IDLE ON 03 max how do i fix this
Old Jan 22, 2010 | 08:47 PM
03VIPMAX's Avatar
my maxima has a very low idle sometimes it gets so low to the point where it almost wants to turn on its automatic and i really dont know what it is. it shakes when itgets low. what can i look for or how can i fix this! plz any suggestions would be appreciated. thanks
Old Jan 22, 2010 | 08:53 PM
DrunkieTheBear's Avatar
Turbo'd Saab
What does that even mean?
Anyways more details are needed but it sounds like a bad MAF.
Details like...
SES light?
Codes?
mileage?
Old Jan 22, 2010 | 09:00 PM
AEMAXIMA01's Avatar
Exactly what I was thinking...
Old Jan 22, 2010 | 09:13 PM
Scottwax's Avatar
That's Mr. Detail to you
I don't know what you are saying either but my first guess would be a dirty throttle body. Since it sounds from your post you really don't know a lot about cars, I'd have a mechanic clean the throttle body, should be $40-50. Fixed my low idle problem.
Old Jan 22, 2010 | 09:20 PM
Ghost_54's Avatar
I really believe the OP simply has a typo, "sometimes it gets so low to the point where it almost wants to turn on"
He more than likely meant to type "sometimes it gets so low to the point where it almost wants to turn off" meaning it just about stalls. If there are no CEL/SES lights on you may just need to perform an idle relearn. I have an automatic and mine idles reasonably low when it has reach operating temperature. My is around 500-600 rpm but has never displayed any symptoms of stalling so I pay it no mind.
Try searching for threads on "How to perform and Idle relearn" and see if that helps you out.
Old Jan 23, 2010 | 12:02 PM
jasonmax's Avatar
SES? might have been dirty injectors or bad plugs
Old Jan 23, 2010 | 01:04 PM
tothemax2003's Avatar
you also could have a vacuum leak thats usually the symptoms.
Old Feb 12, 2010 | 12:18 AM
03VIPMAX's Avatar
thanks ghost thats what i meant i was a typo lol but yeah it idles to low still have to look into that idle relearn... thanks!!!!
Old Feb 13, 2010 | 12:24 PM
RR5's Avatar
RR5
First you need to perform the Accelerator Pedal Released Position and Throttle Valve Closed Position learning is completed. Then you perform the Idle Air Volume Learning.
Someone cleaned my 2002 maxima's throttle body and I got a MIL for Idle RPM too high, and was pulling my hair out. Took the car to a Nissan dealer who wanted $1,600 for a new throttle body + labor. Then they said I was getting TPS failure codes also. So I picked up a used throttle body from the org and the TPS codes went away. I even got the Idle Air Volume learning done but it would reset after turning off the engine.
Finally the stealer ran the Idle Air Volume learning with CONSULT II and took $40 from me. This was AFTER I dropped $400 for the used throttle body.
Old Feb 13, 2010 | 12:27 PM
maxima122192's Avatar
ADJUST THE THROTTLE BODY I BELIEVE
Old Feb 13, 2010 | 12:34 PM
RR5's Avatar
RR5
Fuel delivery could also cause the low idle RPM to the point of the engine wanting to stall. This can include the fuel pump, filter, injectors.. but try the simple low cost things first.
Old Feb 13, 2010 | 01:11 PM
914Max914's Avatar
did you try cleaning the throttle body? or touch the valve befor? that could cause it. if you disconnect the battery for 36 hours it resests everything. i had the same idle problem disconected the battery and it fixed it self. if not i have a throttle body for sale. PM me if you need
Old Feb 13, 2010 | 01:17 PM
RR5's Avatar
RR5
@914Max914
If you are asking me, no I no longer need a throttle body. Unless you're asking the original poster.
Old Feb 14, 2010 | 02:02 PM
914Max914's Avatar
Originally Posted by RR5
@914Max914
yea asking original poster.. lol
Old Feb 16, 2010 | 11:10 AM
03VIPMAX's Avatar
oh ok thanks guy how much for throttle body just in case nothing i try works!! thanks again i will be busy trying all these things this week!!
Old Feb 16, 2010 | 11:32 AM
RR5's Avatar
RR5
Ask 914Max914.
Old Feb 19, 2010 | 11:36 PM
chuckd2k's Avatar
This was my problem. I went to firestone and had them do a fuel system cleaning and it made a big difference. It solved the low idle problem, but I think there is still room for improvement. There still seems to be a small delay when I hit the gas. My max has over 95k miles on it, do you think throttle body cleaning would do the trick or was that done with the cleaning at Firestone?
Sorry for hijacking the thread.
Old Feb 20, 2010 | 09:28 AM
03VIPMAX's Avatar
that probably is the problem with ur bro try cleaning that i havent had a chance to do it but im pretty sure itll help. im gonna be getting some money here soon and i plan on checking all my fuel system and cleaning it out and my stupid oil leak that i dont know where its coming from its pissing me off. but yeah good luck with that let me know if it help and thanks for suggestion on fuel system cleaning...
Old Feb 23, 2010 | 04:37 PM
Maxxxi69's Avatar
sounds like a bad O2 sensor to me.
mine used to do that.
buy some seafoam from local auto parts store and run it thru your gas and oil for about 30 min, should fix the problem.
Old Feb 26, 2010 | 10:01 AM
03VIPMAX's Avatar
working on it today and i fixed my oil leak it was from the gasket seal from the oil filter base
The Frye
Sep 2, 2021 11:03 AM
Maxima.KsA
May 15, 2020 04:14 PM
MaxLife17
Sep 8, 2015 02:36 PM
TheMafia
Sep 4, 2015 08:26 AM
trungg86
Sep 4, 2015 04:58 AM
