Eibach vs. H&R springs
So, I am speccing out some improvements to my 01 SE20A. The rear shocks are going fast, and this brings with it the opportunity to seriously improve the way the car drives.
So - Tokico Illuminas, up front at least. Looking at the pricing I won't save much by going with GR2's in the back. The front could use some tightening up in terms of damping, but the original rears were great while they lasted - compliant but not mushy.
Now come the springs, and here I basically want the same or slight improvement to the stock ride (firm, not harsh), but take a half inch off the front and rear to center the wheels in the wheel well. So either Eibach Pro Kits (1.3"F, 1.0R) or H&R 53060's, 1.4F, 1.3R. I checked housecor's site, it gives the edge to the H&R's, and some other FAQ on the internet gives it to the Eibachs.
So what say you?
So what say you?
For purely comfort with a bit of a drop, H&R. To tip the scale slightly towards better handling, Eibach, but from what you're saying, you won't really go wrong with either for what you want to do. Both are good quality springs and should ride just fine.
Similar drops man. The Eibachs are a bit stiffer than the H&Rs. However they also sit more level as well. As long as you pair either with a decent set of struts which you will, you'll be happy.
I recommend H&R's, just got them installed a few weeks ago and am loving them..they are on stock struts so the ride is nice...here is a pic for ride height...
plus: A friend of mine (zero2sixtyZ on the org) had Eibachs and one of them snapped and had problems with their customer service, I would ask him directly too...
Thanks, somewhere around there I think...have not measured recently...perfect setup for me right now, until I get Tein SS...
You realize that a) since everyone puts their mods in their sigs around here, EVERY thread is a hit, right? and that b) when people use the .org search, smart-alecks like you say to use google? Not you, ever, but the posters who generally post the informative "try search first" posts since they have nothing to contribute.
http://forums.maxima.org/5th-generat...ng-thread.html post #6
http://forums.maxima.org/5th-generat...rs-fronts.html post #18 but the whole thing is good.
http://forums.maxima.org/5th-generat...rings-out.html whole thread
http://www.shiftice.com/spring_strut_decision.html this ones been around a while
I'm more smart than a$$
Anyhow, time to quit being in the special olympics with you.
I have H&R springs with Tokico Blues and have not been happy with the ride. The drop is uneven, slightly lower in the rear, and all potholes (New Jersey) causing really rough ride. Plus, my wife is starting to complain...
I'm thinking of making a change back to OEM (in springs/struts, not wife) to get a softer ride back. My question is this: If I were only changing one, struts or springs, which would provide a better ride? I'm trying to figure out if the struts are hurting the ride quality more/less/equal to springs.
I thought I picked the best ride quality options in the Blues / H&R combo. Is it possible something else is wrong?
Thanks.
Thanks.
Don't get mad at me, your the one beating a dead horse with a "which spring should I get?" question. To avoid this in the future don't ask a dumb question.
Thanks.
Thanks.
I once did a spring setup in a 5th gen that had an amazing ride quality. He put H&R's in the front and left the stock springs in the rear. He coupled them with KYB GR2's all around. I was very suprised at the excellent ride quality, and the stance looked great too, with just a nice rack twards the front.
That's something you may want to keep in mind and would be easy for you to try, being you alreay have all the components. If you need any help installing them, please shoot me a PM as I'm also in NNJ.
njmaxseltd - you said H&Rs up front, stock rear, but I'm getting most of my hard hits over bumps from the front, not the rear. Makes me worried about keeping the H&Rs up front. Any reason to think something else is wrong?
Quite a bit. You loose around 1.3" of wheel travel with the lowering springs. Plus the car didn't come with much suspension travel to begin with, I think that is part of the reason for the OEM front end height. You have to take off .75-1" off the bump stop or you'll be bouncing off them all the time on the larger bumps.
[quote=MaximusMorpheus;7390653]I recommend H&R's, just got them installed a few weeks ago and am loving them..they are on stock struts so the ride is nice...here is a pic for ride height...
How are the lowering springs on stock struts holding up?
MaxLvr21
Oct 17, 2015 12:11 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
followthadollar
Sep 27, 2015 01:06 PM
Im sure there is a local who is willing to do it for you for a lot less man.
