How to: True Cold Air Intake From Altima
Old Jan 31, 2010 | 04:34 PM
Rood's Avatar
Alright so I thought I read somewhere on the forums thats its possible to use a cold air intake off of an altima on our 5th gens with a little bit of work...
Its true, it works.
Needed:
02-06 V6 Altima Cold Air Intake Kit off of ebay:
$60 shipped for a good one.
http://cgi.ebay.com/ebaymotors/02-06...ht_3733wt_1167
New Filter, your choice, I used a K&N
Another coupler, I got on from autozone for $10
3'' Hole Cutter
Drill
Some Tape, I used it around the intake, around the hole.
Battery will need to be moved or relocated as a hole will be drilled.
I moved my battery to the trunk.
Hole needs to be drilled around the hole that is already there.
Will look like this:
The tube will need to be cut slightly, and somewhat on an angle... Cut and measure
Rood's Avatar
So put it all together and it will look like this:
Filter fits right in-front of the front wheel.
Any questions, just ask. Thanks
Old Jan 31, 2010 | 04:49 PM
soto2635's Avatar
nice write up
Old Jan 31, 2010 | 05:06 PM
mandyfig's Avatar
Excellent DIY. How did you wire your battery? You said it was relocated in the trunk. Isn't that a lot of resistance, very long wires? What gage did you end up using?
Old Jan 31, 2010 | 05:08 PM
Rood's Avatar
Long wires, I used 0 gauge Positive all the way to the front and a 0 gauge negative to the frame. And another smaller ground to the engine.
No problems starting even in the coldest conditions.
Old Jan 31, 2010 | 05:13 PM
Scottwax's Avatar
That's Mr. Detail to you
Nice job, looks really good.
Old Jan 31, 2010 | 05:52 PM
Rood's Avatar
Old Jan 31, 2010 | 05:54 PM
anomaly117's Avatar
excellent write up, think i might do this.
anyone want to buy an injen CAI?
Old Jan 31, 2010 | 05:56 PM
HotshotVQ35's Avatar
looks great, i just dont feel like relocating my battery..
Old Jan 31, 2010 | 05:57 PM
wait..what? injen made a CAI
Old Jan 31, 2010 | 05:58 PM
hondakiller's Avatar
i like the how to's sessions lol
Old Jan 31, 2010 | 05:59 PM
anomaly117's Avatar
haha, yea or so they call it.
Old Jan 31, 2010 | 06:04 PM
bigpopaj369's Avatar
great write up, looks really good nice work
Old Jan 31, 2010 | 07:10 PM
MoncefA33's Avatar
Mike im at the gym but since you told me to look at your writeup im peeping it on my phone.
looks great !
Old Jan 31, 2010 | 07:18 PM
papo99's Avatar
wait to you see mine hopefully by friday
Old Jan 31, 2010 | 07:19 PM
soto2635's Avatar
what did u do with th sensors??
Old Jan 31, 2010 | 07:34 PM
Rood's Avatar
MAF and large breather hose connected, smaller breather hoses have a small autozone cone one them.. Everything works great, preforms nicely and looks good.
Old Feb 1, 2010 | 08:37 PM
Rood's Avatar
Wanted to say that after a 3 1/2 hour drive everything is working great. Nothing out of the ordinary, it fit in really well with no movement back and forth. One of my favorite mods currently.
Old Feb 2, 2010 | 01:20 PM
nismos14's Avatar
§è~® f®ÈÄk
Could just pop a 4th gen CAI on it.
Old Feb 3, 2010 | 04:02 PM
Jereme329's Avatar
nice, i might end up doing this
Old Feb 3, 2010 | 04:44 PM
Scottwax's Avatar
Now to the write-up on the battery relocation!
Old Feb 3, 2010 | 07:44 PM
Rood's Avatar
I used my 0 Gauge Stinger audio cables out of my old subwoofer system (4 12's, then 2 15's).. Then I added another ground straight to the engine.
Old Feb 4, 2010 | 05:16 AM
2slow's Avatar
Will the 4th gen CAI have the same routing as the his modified Altima CAI?
Edit: couldn't find a good 4th gen CAI (installed) pictured.
Old Feb 4, 2010 | 05:26 AM
KCMAXX's Avatar
KC's FINEST
Hopefully you dont get into any hydrolock issues like alot of the 6th gen guys are having with the Fujita.
Our filter sits in front of the wheel too...
Old Feb 4, 2010 | 05:40 AM
fflint_18's Avatar
Great writeup.
One question. Any worries about driving through deep puddles. Especially at speed.
I'm just worried about sucking up some water. From what I hear even a small amount can toast my expensive MAF. We all know what a bunch of water in the intake will do.
Thanks.
Old Feb 4, 2010 | 06:29 AM
Rood's Avatar
You could get this instead of the coupler:
Old Feb 4, 2010 | 07:09 AM
arcueda's Avatar
Originally Posted by fflint_18
Great writeup.
Thanks.
i hit a slush puddle on the highway last year and it took a big gulp.pretty much started to chug and shut down....i pulled over and turned it off for a min, turned it back on and finished my trip (i have since changed all the fluid) no major problems.but i have since wanted to change to short ram....in the winter atleast.i dont have tru-cold air mod...mine sits right behind the splashguard under the bumper
Old Feb 4, 2010 | 08:35 AM
foxy curls's Avatar
great mod! thanks for the DIY!
Old Feb 4, 2010 | 10:23 AM
Nice DIY and it looks great, I just hope you don't suck up any water.
Old Feb 5, 2010 | 07:48 AM
Rood's Avatar
From what I have read, its hard to unless your are submerging the cone and driving quickly with more throttle...
With the altima CAI you can cut it how far you want it down. I have mine by the splash shield but there is a good amount of room to cut.
I used a hack saw...
Old May 5, 2010 | 07:13 AM
WhoDatBuuL's Avatar
i wonder if i do this can i turn the batt like orgullo did instead of puttin it in the trunk ???
Old May 5, 2010 | 07:20 AM
NmexMAX's Avatar
dot dot dot ...
Old thread bump, FT/?
Maybe ... the OP does have a 2000, and Orgullo has an 02+.
Old May 5, 2010 | 09:01 AM
nismopc's Avatar
You can do this instead. Remove battery tray, turn it 180 degrees, re-drill mounting holes and this is what I ended up with...
...if I ever decide to do a true CAI. I am now back to this...
...low end torque seemed to suffer massively with the longer tubing.
Old May 5, 2010 | 09:17 AM
NmexMAX's Avatar
dot dot dot ...
Isn't that what Orgullo did?
Old May 5, 2010 | 09:26 AM
nismopc's Avatar
I'm not sure who I "borrowed" the idea from.
But I do recall Orgullo turned the battery 90 degrees and went through a bunch of modifications, grinding, cutting, etc.
My way moved the battery closer to the engine within 15 mins of time...
...oh well.
Old May 5, 2010 | 10:15 AM
fishpony's Avatar
i also noticed a substantial low end loss with the longer Pipe. I installed a cattman right in front of the tire and ended up taking it off and installing the filter just after the MAF.
Nice write up.
Old May 5, 2010 | 10:29 AM
Rochester's Avatar
Originally Posted by fishpony
...also noticed a substantial low end loss with the longer Pipe.
Good observations to refer back to should people get the itch to convert their SRI to cold-air setup. Personally, I don't want to bring my filter closer to the colder air... I want to bring colder air closer to my filter.
How do we do that?
Old May 5, 2010 | 10:42 AM
merovi's Avatar
How do we do that?
Using a pick axe you create speed holes in the hood.
Old May 5, 2010 | 11:37 AM
Rochester's Avatar
Yes, water holes... I mean, speed holes.
Short of putting an offset air-scoop on the hood, I'm at a loss as well. I know someone here was convinced they didn't need their left, plastic under-panel, but that doesn't seem a valid option for rain & snow. And I remember a thread where someone crafted a very elaborate front-air scoop using the OEM collector. Except, without negative pressure, that little slit under the hood is pretty much useless, IMO.
It would have to be some kind of under-hood scoop directed to the SRI filter, and accounting somehow for road spray. You know, something insanely elaborate, to justify barely measurable gain, if at all.
Old May 5, 2010 | 11:40 AM
nismos14's Avatar
§è~® f®ÈÄk
All this over 1-2 horsepower and low end loss? Jesus.
