Buying new clutch
Old Feb 2, 2010 | 10:13 PM
toby's Avatar
Buying new clutch
Hi im gonna be buying A new clutch soon and i was wondering what some of the opinions that some of yall have on a stage 1 spec clutch and a fidanza 11lbs fly wheel. does anyone here have either of these installed on there car? How does the spec clutch feel ? and do yall have any other sugetions for clutches ?
Old Feb 3, 2010 | 06:50 AM
rroderiques77's Avatar
Demodded and Forgotten
I just bought a ACT 6-puck Z34 clutch and Fidanza flywheel. I can let you know what I think about it. Haven't heard much about the Spec. What are you looking for in the clutch? Performance? Stock feel? Durability?
Old Feb 3, 2010 | 08:05 AM
knight_yyz's Avatar
Toolie
if you are stock i don't see the point of going for anything more than a stage 1. with the lightened flywheel the car will rev up like a bike.
I've heard problem with the spec, either love it or hate it, I'm running an exedy stage one and it hold my close to 300 hp with no problems
Old Feb 3, 2010 | 10:10 AM
shmezelk8's Avatar
How does the pedal feel with the Exedy stg 1? Does it change the stiffness at all? Does it affect the point of engagement? Would this help with the sloppy feel of the stock clutch?
Thanks.
Old Feb 3, 2010 | 06:16 PM
toby's Avatar
well my car is only slightly modified right now so that is y i am only going with a stage one clutch. but im trying to find a good clutch that wont break the bank . does anyone have any suggestions ?
Old Feb 3, 2010 | 08:41 PM
knight_yyz's Avatar
Toolie
you should be able to get an exedy OEM replacement for less than 200 bucks.
The stage 1 pedal is a little stiffer, the engagement point is the same
Old Feb 3, 2010 | 08:52 PM
Unklejoe's Avatar
Another option is the 350z clutch with the Fidanza flywheel. I've read that it is equal to the Exedy stage 1 in terms of clamping force and stiffness.
You must use the Maxima throw out bearing if you use the 350z clutch. And you can use the 350zHR clutch also.
Also remember that the Exedy stage 1 has a sprung clutch disc, so it is really recommended to get a solid flywheel like the Fidanza for use with that clutch.
Also, if you get an oem replacement clutch, you shouldn't use the Fidanza as it is not a dual mass flywheel like the stock one.
So basically you want either a sprung flywheel and solid disc (this is how it is stock), or a sprung disc and solid flywheel, but NOT neither and NOT both. One or the other.
FWIW- The part number for the proper OEM replacement clutch that can be used with the stock flywheel is Exedy NSK1002. It is for the Altima and Maxima, 3.5.
Old Feb 4, 2010 | 07:25 AM
toby's Avatar
I can't use the 350z clutch cause i have a 3.0 5.0 gen I wish i had the 3.5
Old Feb 4, 2010 | 07:34 AM
Nealoc187's Avatar
SLOW
spec clutches are absolute fvcking trash. please do yourself a favor and get something else, almost anything else.
If you're stock or just basic bolt ons with no racing on drag slicks then get an OEM clutch.
If you're more modded or will be actually racing the car on drag radials or drag slicks get ACT, Exedy, RPS, South Bend, etc.
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
pears
Sep 18, 2015 05:25 AM
