Wire Halo leds to switch
Old Feb 7, 2010 | 06:28 PM
tdabboud's Avatar
I just ordered a pair of headlights with halos in them. I just wanted to know how to wire these halos to a SPST switch so i can turn them off whenever i want. Also, do i need a relay or fuse? Thanks!
Old Feb 7, 2010 | 06:55 PM
bigpopaj369's Avatar
should be pretty straight forward just wire them up to the switch. i wouldnt see why u would need anything for them. power to the switch from the batt then power to the lights. if u use a lighted switch then u will need to run a ground wire for the light.
Old Feb 8, 2010 | 06:14 AM
tdabboud's Avatar
ok cool thats what i figured. thanks man!
Old Feb 8, 2010 | 07:57 AM
no problem, good luck! post a pic of the install when ur finished
Old Feb 8, 2010 | 09:02 AM
jowo9's Avatar
If you don't want the halos on if you forget to turn them off, you should wire the power for them to a source that is only on when ignition is turned on (like the cigarette lighter wire), and then put a switch on that wire. That's what I did.
Old Feb 8, 2010 | 10:35 AM
thats definitely a much better way to wire them good idea
Old Feb 8, 2010 | 10:46 AM
tdabboud's Avatar
Yeah thats a really good idea! So just to make sure...run the wires from the halos into the ACC slot on switch, then tap the cig wire and connect that to the Power on the switch, and then just ground it?
Old Feb 8, 2010 | 11:02 AM
jowo9's Avatar
Yes. And the ground wire is only if you have a switch with a light in it.
Old Feb 8, 2010 | 11:10 AM
tdabboud's Avatar
ok cool! Thanks for help. I'll post some pics later of the install
MannyMonroe
Sep 17, 2015 02:34 PM
minsbang
Sep 11, 2015 08:48 PM
mpbclutch33
Sep 8, 2015 06:21 PM
