Sawed off lettering
Old Dec 6, 2001 | 01:51 PM
zman187's Avatar
Sawed off lettering
I just got my new 5th Gen and I wanted to saw off the Maxima and SE off the back of my car. How do I exactly do that? Thanks
Old Dec 6, 2001 | 02:47 PM
drudawg888's Avatar
Re: Sawed off lettering
what for??
Old Dec 6, 2001 | 02:50 PM
the paragon's Avatar
I think you use a fishline or something.
Old Dec 6, 2001 | 03:46 PM
Newman's Avatar
yeah used fishing line or dental floss.
make sure you do it in a warm place because if the glue is too cold then it will be really hard to get off.
just put the dental floss or fishing line beind the letters and start "sawing" them off. go back and forth. eventually the badge will come away from the car.
now you need to get the rest of the glue off. just get Goo Gone and squirt it on the remaining glue. rub it away with a cloth (dont use anything that might scratch the paint like a brillow pad or the rough part of a sponge) it took me a long time to get the glue off before i realized it was way too could outside so i set up a heater right next to me in the garage.
Old Dec 6, 2001 | 04:00 PM
zman187's Avatar
Re: Re: Sawed off lettering
Could i just use a hair dryer right next to it?
Old Dec 6, 2001 | 05:38 PM
can't u use the WD80 thing to get the glue off?
Old Dec 6, 2001 | 06:10 PM
Newman's Avatar
Re: Re: Re: Sawed off lettering
yeah you can but dont point the hair dryer at the same place for a long time. getting it too hot can be bad. just get the glue warm enough so its sort of soft.
i dunno about the WD80 stuff. never heard of it. is it something different than WD40?
Old Dec 6, 2001 | 06:44 PM
zman187's Avatar
Re: Re: Re: Re: Sawed off lettering
If I decide I want to put the lettering back on, can i still do that?
Old Dec 6, 2001 | 07:46 PM
Newman's Avatar
Re: Re: Re: Re: Re: Sawed off lettering
yep. just go to trak auto and get some 3M Emblem/Badge adheisive.
Old Dec 6, 2001 | 08:22 PM
sorry, yea the WD40.
Old Dec 7, 2001 | 01:16 AM
Proceedbob's Avatar
I just did this last weekend, as the back of my 01 AE/SE looked to cluttered, DO NOT use a heat gun! This resulted in the adhesive hardening and was far worse to remove, I sat in the driveway with a rag and Goo-be-gone and Goof-off and a fingernail for quite some time before trying something more drastic. Soak a rag in above solvent of choice then use a plastic ATM or credit card to scrape off the glue, worked great and didn’t harm the paint. I buffed it and waxed it when finished. (Yes, use fishing line (20lb)).
Old Dec 7, 2001 | 11:53 AM
Newman's Avatar
how could a heat gun cause the adheisive to harden? heating the glue will make it softer. cooling the glue will make it harden. i dont recommend using a heat gun. thats is probably too hot and may harm your paint.
i sort of explained it before but this is exactly what i did:
used regular old dental floss to saw the letters off (i didnt have fishing line and this works just as well)
then set up a heater next to me to bring the temp around me up to 7o or 80 degrees
then i soaked the remaining glue in Goo Gone
then i used a rag and just rubbed the glue away
after all that i waxed it and buffed it.
you can follow Proceedbob's instructions but i think the ATM card is a risky idea. you dont want to use anything hard that may scrape the paint at all. just in case.
Old Dec 7, 2001 | 12:23 PM
adman's Avatar
Does the ATM Card still work?
ADMAN
Old Dec 7, 2001 | 03:34 PM
Proceedbob's Avatar
ADMAN
Yes, yes it does. One would think heat would soften the glue but that was not my experience, the soft gummy adhesive turned into something-resembling dried shellac. The plastic card did not harm the paint one bit, although the Goof-Off acted as a lubricant.
Old Dec 8, 2001 | 09:41 PM
zman187's Avatar
thanks guys I'm not sure if I'm going to do it yet. Just wanted to ask for how to do it
litch
123
Jan 4, 2024 07:01 PM
maxinout93
Oct 31, 2015 02:04 AM
sliptap
Sep 30, 2015 05:57 AM
