Motor Mounts Replacement
Old Feb 16, 2010 | 05:56 PM
wyche89's Avatar
Ok, so I need to install my new motor mounts. I got 3 new OEM motor mount assemblies, and I'm going to put them in soon. I planned on replacing one mount at a time with the other 2 mounts supporting the engine. Is that possible, or do I need to support the engine with something while I replace every mount?
Old Feb 16, 2010 | 06:24 PM
MrChuckFL's Avatar
I just changed 3 of the 4 mounts. The 2 bottom mounts on the cross member and the transmission mount on the drivers side.
I put a jack under the oil pan with a block of wood just enough to hold the wood in place. Then I removed the crossmember and 2 bottom mounts. Replaced those and then moved to the transmission mount.
When I was finished I removed the jack and wood.
Old Feb 16, 2010 | 06:32 PM
Maxima112's Avatar
Curb Rash Repair 100 a wheel
use the jack stand and wood method. when i did my front and rear mounts once i unbolted the mount the engine sank down really quick, kinda scary. i ran out and jacked it up right away. better safe than sorry. good luck!
Old Feb 16, 2010 | 06:38 PM
wyche89's Avatar
they say you're not supposd to jack under the oil pan... is there a safer place to put it?
Old Feb 16, 2010 | 06:39 PM
wyche89's Avatar
yeah, when my mechanic was putting my headers in, he dropped the crossmember on a lift with nothing supporting the engine, and it was moving a whole lot! i was kinda scared, lol
Old Feb 16, 2010 | 07:00 PM
nismopc's Avatar
Doesnt take much to support when removing the crossmember. I used a piece of 2x4 between the jack and the tranny casing to hold in place while replacing the crossmember mounts.
Once they are done, you can then do the tranny mount pretty easily without any support. Crossmember will hold engine in place. Then use same 2x4 under tranny to raise/lower engine until it matches up to tranny mount.
Old Feb 17, 2010 | 06:53 PM
wyche89's Avatar
how about the side engine mout.. can i do that with just the support of the crossmember, or should i support it still?
Old Feb 17, 2010 | 07:12 PM
Nelsito65's Avatar
Basically same as the tranny mount. I used a jack with a wooden block under the oil pan to raise the engine just enough to allow the main bolt slide in and out with ease.
Old Feb 18, 2010 | 05:04 PM
wyche89's Avatar
i don't have my haynes manual on me, nor can i find this anywhere on the site.. does anybody know the torque specifications for all the bolts?
Old Feb 18, 2010 | 05:05 PM
wyche89's Avatar
cool.. thanx
Old Feb 19, 2010 | 08:18 AM
ghostrider17's Avatar
Putting a load on the Oil pan in ANY WAY is a VERY bad idea.
gr
Old Feb 19, 2010 | 12:22 PM
nismopc's Avatar
2003 Maxima FSM:
http://www.nicoclub.com/FSM/maxima/2003/
Al the torque specs you'l ever need. ;-)
Old Feb 19, 2010 | 03:11 PM
exodusx187's Avatar
what about when changing just the rear motor mount? any engine support needed?
Old Feb 19, 2010 | 03:36 PM
nismopc's Avatar
Same procedure. You need to remove the crossmember to get the rear replaced.
vingodine
45
May 21, 2016 12:46 PM
homeyclaus
Sep 3, 2015 06:15 PM
Rage Maximus
Sep 3, 2015 12:26 PM
george__
Aug 18, 2015 07:06 PM
Balkins
Aug 12, 2015 06:39 AM
