2000 Maxima Headlights
Old Sep 16, 2011 | 09:31 AM
  #81
EuroDriver's Avatar
UPDATE:
Last night my brother offered to help me with the adjustment and we went to a dark parking lot with a wall where we can do the aiming. It did take a long time, especially since it took us a while to figure out they do adjust vertically and laterally.
When we finally got it right, the lighting quality is indeed impressive. Still have a little bit of scatter, but it is now very minimal and the beam projection is very good. The projectos tremendously reduce the glare factor, comapred to my brother's retrofitted stock housings. Can't wait 'till tomorrow when shop fixes low beams turning off when high beams activated. I think that will leave me a very happy camper with the light output.
Old Oct 6, 2011 | 12:05 AM
  #82
tetete's Avatar
Originally Posted by Feldman
i love the way they look as compared to stock. here are some pics, none of the light pattern though
Looks great,
I want one, hehe
Old Oct 13, 2011 | 11:42 AM
  #83
EuroDriver's Avatar
Here's a pics of the light scatter on the projector-style ebays, for those who wanted to see it:
25 feetsome from wall
Front View
On road
IMHO, not bad for a modest upgrade on a budget from hazy stocks, but does leave a lot to be desired.. I'm in the process of upgrading to G37 projectors. However, it has turned out to be a very expensive endeavor.
Old Oct 20, 2011 | 06:21 PM
  #84
sek11172's Avatar
i plan to do the samething
Old Jan 20, 2012 | 08:53 PM
  #85
01maxium's Avatar
I have the ebay halo lights without the projectors and would like to put HID lights, but I have no idea where to put the ballast. Do I put the ballast inside the housing of the light?
Old Jan 21, 2012 | 09:55 PM
  #86
Nexus67's Avatar
^Definitely not. You can mount them anywhere near the headlight (as long as its secure).
On the one hand I'd tell you that you shouldn't do it, it'll be brighter but not the good kind of 'bright'. On the other hand...I did the same exact thing some years back.
I guess it's almost like a Rite of Passage. Hell, if it weren't for doing those I would've never got my oem lights retrofitted (and I was one of the first)
Old Jan 27, 2012 | 11:25 AM
  #87
tbail25's Avatar
Originally Posted by Rood
I personally would see how long it does to take to hazy up again. If you like the idea of the halos, I would bake them open, paint them black like the AEs and put halos in them. When I had the halos I like them but got tired of them quickly. They werent bright enough.
Both headlights of mine were replaced, but the right one looks slightly different from the left, I'm guessing one might be OEM, and the other aftermarket. That being said, the left one that looks almost aftermarket-ish hasn't glazed over yet, and the right one looks slightly hazy. They were replaced in Septemember of last year.
Old Jan 27, 2012 | 11:42 AM
  #88
luvlexus101's Avatar
Front View
On road
That streaky output would drive me crazy. Good idea to upgrade to the g37s.
Old Jan 27, 2012 | 11:58 AM
  #89
Genes1s's Avatar
Originally Posted by KBCobra
So, I rear ended an FJ Cruiser last week. My hood is bent, my bumper is broken, my grille is cracked, and my headlights are scratched up. I already accumulated all the parts except the headlights. So, I was looking on eBay and I keep seeing these "TWIN HALO BLACK HEADLIGHTS" for about $140. I like the fact that they are the 2002-2003 Style. Does anyone have this installed on their 2000-2001 Maxima? If so, Is it a perfect plug and play fit or did you have to do any retrofitting / cutting with the wiring etc. I'd like to see some pictures before I buy. Thanks! '
I bought these few weeks back. I don't think it is plug and play. I cound;t install them correctly in my car. The bottom plastic bracket isn't matching correctly...so either the design change or I'm missing something...
If you take the plastic bottom bracket, it looks like it's going to install right, but then it's not truly plug and play like it was advertised..
Old Jan 29, 2012 | 09:36 AM
  #90
District's Avatar
They looks so good....but considering how I do not know how much about anything with cars...it would be impossible to install them huh?
Old Jan 29, 2012 | 06:29 PM
  #91
Nexus67's Avatar
Not really. It has the high and low beam bulbs wired into one harness that you simply plug into your factory harness (just like your stock lights). There are small wires for wiring the angel rings and another small harness for plugging in your turn signals (also plugs directly into your turn signal harness).
You should try it.
Old Jan 29, 2012 | 06:33 PM
  #92
Nexus67's Avatar
I swear I wish I could remember if I took mine tabs out or not. I'd definitely give it a try if i were you b/c those lights are a little bigger than oem 00-01's and it would probably still be snug.
Did your ebay projector's go into the plastic tabs w/o incident?
I wouldn't imagine plug and play to be exact but anything on ebay I'd gather as a gamble on that one lol.
Old Jan 29, 2012 | 11:03 PM
  #93
Genes1s's Avatar
Well, after 1 hour trying to take the tabs out without damaging, I finally busted both of them apart, now both headlights fit perfect. I'm going to order a few from delearship tomorrow since I'm not planning to use these quads I'm doing.
Old Jan 30, 2012 | 05:38 AM
  #94
EuroDriver's Avatar
haha, I told you, it's just not worth it trying to save them.
Old Jan 31, 2012 | 12:44 AM
  #95
Nexus67's Avatar
Damn Well at least you got them to fit though
Old Mar 4, 2012 | 08:00 PM
  #96
picnik99's Avatar
would anyone happen know the size of the halos in the reflector style headlights? i just ordered mines and i'm going to upgrade them to either ccfl or smd led, a size in mm would be awsome and much appreciated.
halfpol
Oct 17, 2022 12:16 PM
Dennis Twohy
Oct 1, 2015 06:01 PM
Nintensity
Aug 13, 2015 05:41 PM
jholley
Aug 11, 2015 09:38 AM
niZ
Aug 7, 2015 10:18 PM
