Spongy Shifter
Old Feb 27, 2010 | 09:49 AM
blackandwhite's Avatar
To them I'm like an idol
Spongy Shifter
I have a 2K1 SE manual, and my shift starter feeling really loose a couple of days ago. It goes into gear, but the shifting feels akward, as if the shifter is going to fall off.
Does anyone know what this is?
Old Feb 27, 2010 | 10:08 AM
2slow's Avatar
I don't know how similar the '01 and '02 transmission are, but check the shifter bushing and shifter cable bracket (both under-hood).
Old Feb 27, 2010 | 10:35 AM
vball_max's Avatar
and the linkage in the car under the shifter boot.
Old Feb 27, 2010 | 11:33 AM
knight_yyz's Avatar
Toolie
if it's similar to the 02-03 models, the shifter has crappy rubber bushings at the shifter and the linkage on the tranny. They even put holes in the bushings to make them softer. You may have ripped one or the other causing them to be very sloppy.
Old Feb 27, 2010 | 12:20 PM
TallTom's Avatar
Like the other guys said, check the bushings. They are easy to replace yourself. It should take about 15-20 minutes under the hood and about 10 minutes in the car to do the job.
Get ES bushings.
Old Feb 27, 2010 | 09:12 PM
knight_yyz's Avatar
Toolie
i don't think the 5 speeds have the same bushing style. ES only makes them for the 6 speeds
Old Feb 27, 2010 | 10:34 PM
Arisotezza18's Avatar
5 speeds have the bushing under the shifter. Definitely check that. There's someone on here that makes polyurethane bushings for the 5 speeds. I can't remember, but i think it's carnal that does them.
Old Feb 28, 2010 | 06:18 AM
glockfanbob's Avatar
Can someone tell me the difference felt (if any) if your OEM bushings are good but replaced with ES shifter bushings?
Old Feb 28, 2010 | 06:53 AM
2slow's Avatar
For the 6-speed, the OE bushings are part 'open' whereas the ES bushings are solid and use a stiffer rubber.
Old Mar 1, 2010 | 05:48 AM
vball_max's Avatar
5-speed urethane bushings
http://forums.maxima.org/group-deals...-bushings.html
Fbana41
Aug 29, 2016 12:18 PM
lux97Max
Sep 28, 2015 11:18 PM
atriuum
Sep 28, 2015 01:19 PM
ef9
Sep 10, 2015 10:35 PM
