My new maxima problems. please help
Old Mar 1, 2010 | 10:06 AM
rich2kbusa's Avatar
I just picked up an 01 Maxima SE 5sp. the car has 128k miles and seems to have some typical maxima issues. i have done most of the maintanance stuff and now i'm on to more in-depth problems.
1-Seems i have the dreaded trans whine and seal leak. i Replaced the seals and it still leaks. i have noticed that the axle has play inside the transmission. I believe this means that i need differential carrier bearing and the trans needs to come apart. Is there a company that makes a stock rebuild kit for the trans? i plan on doing it myself.
2-I have a po430 code with a check engine light. i have looked on here and some say i need an O2 sensor, i'm just not sure which one?
3-Also the ABS light has come on. i have not been able to have the code checked but does anyone know what this usually means?
thanks for all of your help!
Old Mar 1, 2010 | 10:11 AM
Grand_hustle17's Avatar
you can get a low mileage trans from Car-parts.com, and IIRC the 5th gen used the same trans as the 95-99 so you can go get yourself a LSD trans and just buy new axles... i just bought a trans for my 5.5 for $400 freighted... 79K miles on it
Old Mar 1, 2010 | 11:00 AM
Amave's Avatar
hhhmmm interesting.
i'll have to go look for another trans. with LSD.
taking turns like on rails is so much fun lol
Old Mar 1, 2010 | 11:07 AM
check it out... i was going to do a 5spd swap on my 5th gen and from what i remembered i was going to use a 95 5spd trans... research first cause i forgot
Old Mar 1, 2010 | 11:32 AM
NissanMan97's Avatar
not to post *****
you bought a used trans for $400 bucks? 6spd? HLSD?
B
Old Mar 1, 2010 | 11:34 AM
Psyfa's Avatar
ABS code usually means that one of the sensors has died. When this happens the whole ABS system shuts down so you basically don't have ABS right now. Get the code checked to see which sensor it is and replace it.
Old Mar 1, 2010 | 11:47 AM
Originally Posted by NissanMan97
not to post *****
B
no, unfortunately im auto and nissan never offered the LSD trans with the i35's
Old Mar 1, 2010 | 11:58 AM
damn! i was hoping you would say yes. id get on there right now and look for an 04 6spd
B
Old Mar 1, 2010 | 06:27 PM
rich2kbusa's Avatar
thanks psyfa, i'll have a shop check it out.
anyone know where i can get a rebuild kit for my trans? i don't want another used one.
also the the p0430 code. which O2 sensor?
Old Mar 2, 2010 | 05:59 AM
sontakke's Avatar
For P0430, you don't change the O2 sensor. You fix the problem by replacing the pre-cat for the appropriate bank. My memory tells me this would be the bank on the radiator side. You can also "eliminate" the problem. Look it up more on "CEL eliminator" on Google.
- Vikas
Old Mar 2, 2010 | 02:20 PM
hot_wax_tree's Avatar
- Vikas
or just buy an aftermarket header and y-pipe set up for dirt cheap from Ebay.
Old Mar 2, 2010 | 04:13 PM
rich2kbusa's Avatar
if i buy aftermarket headers like the OBX kit I see, what do i do about the check engine light?
Old Mar 3, 2010 | 07:24 AM
sontakke's Avatar
You use the same O2 sensor extension that I had alluded in my reply
Lakersallday24
Nov 7, 2024 07:31 PM
Goffery2uned
Aug 21, 2015 09:50 PM
julian888
Aug 6, 2015 04:39 AM
