HELP! Radiator fan...
Old Mar 1, 2010 | 01:54 PM
Foellarbear's Avatar
my left radiator fan seems to make a weird noise... well I figured out that it is loose and wobbling. nothing serious which is a sigh of relief... How do you tighten those fans? I can't seems to figure out how to disassemble it. thanks!
Old Mar 1, 2010 | 02:06 PM
cajun1104's Avatar
i think that there are three bolts on the inside of the fan housing that are holding each of the fans in. I can't remember right off hand, but i think if you take out two bolts on top of the housing and disconnect the fans and the entire unit will come out. then you can make sure your fans are secure.
Old Mar 1, 2010 | 02:48 PM
Amave's Avatar
i think he means how do you remove/resecure the fan blade to the motor
Old Mar 5, 2010 | 12:42 AM
BronxSleeperMax187's Avatar
your fan motor needs to be replaced, and the noise will get worse soon if you don't do it soon.....90 bucks at autozone each......search fan removal or radiator removal for instructions how to do this......oh and change both cause you dont wanna do it again in A few months when the other one goes
Old Mar 5, 2010 | 04:25 AM
Amave's Avatar
mine is also making the wobbling noise.
Amazom.com sells the whole fan blade & motor assembly for like $82
http://www.amazon.com/CONDENSER-RADI...7791857&sr=8-8
Old Mar 5, 2010 | 05:23 AM
mandyfig's Avatar
Lots of threads on this. replaced mine recently. Search is your friend.
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
Unclejunebug
Apr 2, 2016 05:42 AM
jchronis2552
Sep 23, 2015 04:57 PM
RWCreative
Sep 21, 2015 11:01 AM
