5.0 Gen Front Brakes
Old Mar 2, 2010 | 12:20 PM
AEMAXIMA01's Avatar
Not getting any help over in the advanced suspension, chassis, and braking section. Hopefully someone can help me out here!
So I am pretty sure my front brakes are experiencing the infamous warping/shuddering and am ready to replace the rotors and pads. I've been doing some research and if possible, would like to up the size of the front rotors with as little modification as possible. I know the 6th gen rotors are a popular upgrade, but they do NOT fit underneath my 5.0 AE wheels.
Originally Posted by irish44j
Well, I have some good news and some bad news..
With a warm day here, I did some brake maintenance, and while at it did a test-fit (dry run, no lines or anything) of the 2004 maxima calipers (and rotors) on my 5th gen....
The bad news now:
The will NOT fit beneath our OEM 17" rims (and definitely not the 16's). The OEM calipers come out about 1 1/4" from the rotor face, while the 2004 calipers come out a little over 1 1/2" from the rotor face. SOOOOOO. After test-fitting everything, the wheel will not go on all the way. Damn. (and now I have 2 brand-new caliper assemblies sitting around...)
Since the 6th gen BBK upgrade is out of the question, my next option is to upgrade the fronts to 5.5 gen rotors. I've been searching around and would like some clarification on upgrading to this size. I found this thread and the OP states he did this upgrade. Is all I need to make the 5.5 rotors work with my 5.0 calipers the 5.5 caliper bracket?
I'm planning on replacing the rotors with brembo blanks, which seems to be the consensus choice. As far as pads, I've read a lot on here about how everyone likes the Hawk HPS pads. I've also been hearing about EBC pads (anyone have opinions on ebc's?). Also have been looking through the Group Deal. They have the zinc plated brembo blanks for 89-01 but not for 5.5 gens, they are RTP. How do they compare in quality/stopping power/reliability to the brembo blanks?
I know there's a lot here, but any help would be appreciated. Thanks!
Old Mar 2, 2010 | 01:10 PM
NissanTun3r's Avatar
Why even bother upgrading to 5.5...just go ahead to do teh 6th gen swap...its not hard nor expensive, then just pick up some stock 6th gen 18 inch wheels to clear the calipers. If I, a 22 yr old, part time working, full time student can find a way to afford it so can you.
Old Mar 2, 2010 | 01:20 PM
AEMAXIMA01's Avatar
I don't want to buy new wheels. I just bought brand new tires last summer and they have less than 3000 miles on them. I'm just trying to go the easiest route possible. I'm in my last semester of college and it's definitely not your typical blow-off last semester class load. Kinda funny, took less than an hour to get a response over here. The braking section of this forum doesn't get much action, hadn't gotten a response in over 3 days.
Old Mar 3, 2010 | 12:39 PM
AEMAXIMA01's Avatar
I need to make a decision on this quick. Would really appreciate some thoughts/opinions.
Old Mar 3, 2010 | 02:17 PM
Nexus67's Avatar
I could be wrong but I believe the 6th gen brake setup would work if you get wheel spacers. It saves you having to buy new wheels (since you don't want).
I believe they go for around $80-100
Old Mar 3, 2010 | 02:52 PM
unrealii's Avatar
I have 17" 04 maxima SL wheels on my car which let me fit the 6th gen bbk in there. You can probably find a set off of craigslist for cheap, then swap the tires over.
Old Mar 4, 2010 | 05:36 AM
AEMAXIMA01's Avatar
Please stop telling me to buy new wheels. I've already said I do not want to to do that. It's upgrading to the 5.5 brakes or sticking with the 5.0 gen setup. How many times do I have to say it? I also do not want to buy wheel spacers. /rant
Old Mar 4, 2010 | 09:08 AM
unrealii's Avatar
I have been happy with hawk hps pads (currently not running them because I got too good of a deal on my monroe ceramics when doing the 6th gen bbk). One thing with hawks is that they put out a lot of dust. Just be prepared for that.
fyi: i sold my 16" maxima wheels w/tires for $225 to some altima owner who's car went offroad and damaged 3 wheels. I purchased 04 SL 17" wheels on craigslist for $250. Sold the tires which came with the wheels for $50. Made $25 on the entire swap, but had to buy new tires (expensive!). The reason I am suggesting this option to you since you can swap your tires over.
Old Mar 4, 2010 | 09:45 AM
n3985's Avatar
大陆弟弟
Have you considered doing the 6th gen BBK and simply adding a 5mm spacer to your stock wheels for clearance?
One rotor which is affordable and great quality is Centric Premium, the hubs (IIRc and vanes too) are painted black so no ugly rust occurs. Hawk HPS is good but unless you are going to use them i.e. hard braking from high speeds you can easily settle for something cheaper like Axxis Ultimates or Hawk ceramic...etc.
Old Mar 4, 2010 | 12:15 PM
Thorzdad's Avatar
There's no real need to upgrade to 5.5 or 6th gen rotors. Splurging for better-than-OEM-quality direct replacement rotors cured our repeated shuddering problems.
Old Mar 4, 2010 | 03:57 PM
vinco's Avatar
To answer your original question, yes - all you need to do the 5.5Gen swap is the caliper brackets. I'm the OP in the other thread you referenced. I used ATE Powerslot rotors and ceramic pads from Advance Auto Parts. I did do a pad change after a HARD track day about a month after I first did the swap, but I did not have the rotors turned. 2 years and 50K miles later, still NO warpage or discernable rotor wear, or even rust on the rotors!
Old Mar 4, 2010 | 04:12 PM
Feldman's Avatar
Just go oem size with better rotors, this will take care of your warping problem and save you the headache that this situation is clearly creating for you.
Old Mar 5, 2010 | 12:19 PM
AEMAXIMA01's Avatar
So if I go with OEM siize but a different brand, which one usually gives everyone the best results? Centric Premium, Brembo blanks (zinc plated) in the group buy, or some other brand?
Old Mar 5, 2010 | 12:28 PM
Feldman's Avatar
brembo blanks get good reviews, i have the ATE slotted rotors and so far so good. I have Haws hps pads and love them but the Axxis pads are good as well from what i have read here
Old Mar 5, 2010 | 08:35 PM
AEMAXIMA01's Avatar
No matter what I do I'm just going with blanks. Anyone have any opinions on the ebc pads?
Old Mar 5, 2010 | 09:04 PM
CMax03's Avatar
They're ok...virtually dust free isn't really true....the dust is just lighter in color but it's still there...They're ok brake pads, I prefer my Hawks which seem to bite better....
Old Mar 6, 2010 | 11:34 AM
Christobal65's Avatar
Most people I talk to dont really like them, apparently they make AWESOME pads for motorcycles but their 4 wheeled pads aren't too spectacular. I had gotten some EBC Green stuff's for free and ran them on my VR-4 for a while and cold initial bite was decent but they didnt like heat. I now run Porterfield R4S pads on that car.
I've also heard reports of hawk pads not aging well at all. Apparently they lose their bite.
With how most of these cars are used i see no reason to spend a fortune on brake pads.
Old Mar 6, 2010 | 11:55 AM
Rich1's Avatar
Brembo Blanks, Akebono pads
Like many I used to have the same warping/shudder problem. I got a set of brembo blanks and had the Axxis Ultimate pads (group buy) - lots of dust though. Recently switched to Akebono Ceramic pads and have been really happy with them. Great stopping and literally no noticable dust. Better than OEM I would think for most uses - I don't take my 5th gen to the track.
Not sure you'll get a huge difference when upgrading to a 6th Gen kit over a really good set of 5.0 gen quality brake parts....So if you're trying to save money and keep your wheels spend the money on quality 5.0 parts...IMHO.
Old Mar 7, 2010 | 07:42 PM
AEMAXIMA01's Avatar
Think I'm going to go with the zinc coated brembo blanks in the group deal. Now I just need to decide on pads. Looks like the Hawk HPS fit my driving style the best. Don't think I need ceramics.
Old Mar 7, 2010 | 08:14 PM
OOmaxSE's Avatar
Go with Hawk HPS pads and NAPA blanks. That's right, NAPA. Most of the shuddering/warping feel is 'build up' from cheap pads. Can't beat $40/pair for rotors picked up.
Old Mar 7, 2010 | 08:27 PM
AEMAXIMA01's Avatar
Best price I can see on their website is $32.89 EACH. Price must have gone up?
vingodine
45
May 21, 2016 12:46 PM
03VQMAX
Sep 25, 2015 04:19 PM
homeyclaus
Sep 3, 2015 06:15 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
egali045
Aug 16, 2015 01:19 PM
