Gas mileage averages for VQ30DEK?
Old Mar 8, 2010 | 07:00 PM
DCZC's Avatar
Just bought a clean one owner 2000 infiniti I30 with 82k, just finished my first tank and got 380 miles before the low fuel light came on, probably 80% highway miles. Is that normal for a A33?
Thanks all in advance,
PS no codes stored, already checked.
Thanks all for the feedback
Old Mar 8, 2010 | 07:20 PM
AEMAXIMA01's Avatar
Miles to the tank mean nothing. Divide the miles you traveled by the amount of gallons you put back in. That will give you Miles Per Gallon. I average between 24 and 27 on mixed driving. Never gotten above 30 though.
Old Mar 8, 2010 | 08:39 PM
DCZC's Avatar
Thanks for the response, any others? looking to get a general group average consensus that I can use as a benchmark
Old Mar 8, 2010 | 08:48 PM
soto2635's Avatar
that not to bad i do mixed driving moslty highway though and i only get 300 to the tank
Old Mar 8, 2010 | 10:16 PM
Shoot.'s Avatar
I KNOW for a fact I get less than 20 to the gallon
Constant stop/go driving and when I get on the freeway or open road I'm usually flooring it. Of course my car is in need of new tires, new oil, and a tune up so im sure those play into it as well
Old Mar 9, 2010 | 05:12 AM
DCZC's Avatar
just wondered because consumer reports said range for a tank was 475!
and during the test drives they averaged 27 mpg (14/32)
from what i'm seeing here that kind of mileage doesnt last long. I had a 97 I 30 and it seemed to do a little better but the average mpg rating was lower?
Go figure
Keep the responses coming good info
Old Mar 9, 2010 | 08:06 AM
phatboislim's Avatar
i get average of 24mpg, when i first bought it i was getting 21-22mpg. then i did teh spark plugs jumped up to 25-26..then came back down to 24mpg...there was one time though, went on a trip to savannah..got two tanks at 29mpg and yes, i jammed it full both times, so the reading was accurate...and suprising
Old Mar 9, 2010 | 08:34 AM
maximal01's Avatar
Go figure
well ya the 97 to 00 changed alot it gain power an some weight but i got 18.25 my last fill up
Old Mar 9, 2010 | 08:49 AM
03kodiak's Avatar
380 is about average... probably right around 22 mpg... It depends on alot of factors, like how clean the engine's running (do plugs, filters, and all fluids if you just got it and a bottle of Techron or a SeaFoam treat never hurts), if its winter gas, and mainly how you drive... I've pushed 500 before out of mine, but its alot of gentle highway driving and going til ur basically on fumes.
Old Mar 9, 2010 | 08:57 AM
03kodiak's Avatar
Should add I have a 2000 SE 5spd with iridium ix's and a K&N that only drinks premium unleaded 35psi all around on 17" stock size yokos.
I often do 20-22mpg delivering pizza around town with tons of idling.
Old Mar 9, 2010 | 09:10 AM
Rydicule's Avatar
Don't you know who I am?
Man I wish my car got 380 miles to the tank...
The 475 miles to the tank consumer reports gives is measured with pure highway driving. Also, being on a highway does not mean highway driving. Highway driving is constant 60 mph in the right lane with zero brakes and minimal throttle change. It's a bit less than 26 mpg on these cars. A mix of around town driving and highway ventures usually gives around 22-24 mpg on a Maxima... which would be about 352 - 384 miles from full to the light. I'd say you're doing pretty well.
As for me, I usually have to fill up right at 300
But I can get to 60 in just under 5 seconds.
Old Mar 9, 2010 | 09:12 AM
200SXSE's Avatar
Usually 27 mixed. 30 all highway. 5 speed.
Old Mar 9, 2010 | 09:20 AM
VQP0WER's Avatar
I get about 270 miles to a tank. 70% highway. I have a heavy foot as well.
People who get 400 miles to a tank must drive like my grandmother...
Old Mar 9, 2010 | 10:42 AM
03kodiak's Avatar
I'll occaisionally just kinda float along like grandma, specially on road trips with the fam along for the ride... If you've got a stick shift coasting in gear makes a world of difference in my car, mileage wise.
Old Mar 9, 2010 | 02:03 PM
Nelsito65's Avatar
With 169k miles, automatic, the most I've averaged is 28 mpg, pure highway, at 75 mph average on flat Florida roads. Mixed city/hwy is 21-22 mpg. I also think you are doing pretty good. I typically get around 340 miles to the tank, down to the E mark.
Old Mar 9, 2010 | 02:20 PM
VQP0WER's Avatar
You know you should never let the gas light come on, right? If you run your tank down that low, your fuel pump is no longer submerged in fuel to keep it cool. I've seen lots of pumps burned up because of this.
Old Mar 9, 2010 | 04:51 PM
DCZC's Avatar
Hey guys,
filled up this morning went 390 miles took 15.33 gal. to fill. that averages out to 25.44
Just added some seafoam to the gas and put in my AFE dry flo S filter from the 97 I30 and it fit! (love infiniti/nissan). I'll keep you updated on the results of this next tank
Old Mar 9, 2010 | 06:05 PM
Christobal65's Avatar
You can see my average in my sig. It includes a month or more where my thermostat was stuck open and mileage dropped a lot. Although i did manage 26.7MPG averaging about 70mph on a trip from Sacramento to LA when the thermostat was stuck. Return trip was at 85mph and mileage dropped to 24.7.
22-25 is normal for me best was 27. Car is an 01 AE SE with 5spd
Old Mar 9, 2010 | 06:31 PM
a33i30's Avatar
I get 275 on a tank, about 17mpg with mixed city and highway.
Old Mar 9, 2010 | 06:39 PM
AEMAXIMA01's Avatar
Ouch!
Old Mar 9, 2010 | 07:19 PM
Feldman's Avatar
24 city 28 highway
Old Mar 9, 2010 | 07:25 PM
a33i30's Avatar
Originally Posted by AEMAXIMA01
Ouch!
yea really annoys me, some of you guys manage some high numbers.. I guess I need to drive more carefully.
Old Mar 9, 2010 | 10:56 PM
Ouch!
only times my MPG went below 20 was when my thermostat was stuck open and the car would never get fully warm. Since I replaced it MPG has never gone below 20 including a tank with 80% + city driving and some pretty aggressive driving.
Heck I averaged somewhere around 15mpg in a 92 explorer with 190k on it in LA.
Basically i think there is something wrong with your right foot or your car.
Old Mar 9, 2010 | 11:21 PM
IHAVEA2KMAXIMA's Avatar
It depends on auto and manual too. I do a lot of highway commute and my best was MPG probably 25.3 with cruise set at 63mph.
Old Mar 10, 2010 | 06:01 AM
this is so comforting to know i'm not the only one getting 'low' gas mileage...my brother use to have a 4th gen and bragged on how high of mileage he use to get and made me feel bad
Old Apr 16, 2010 | 10:59 PM
TNseguy's Avatar
2K2 6 speed, 149K miles and I get 26-28 city and a hair over 30 on the hwy. But I am one that keeps the psi 32-35, constant rotate/balance 6k. Seafoam works wonders
Old Apr 16, 2010 | 11:18 PM
CraigSE's Avatar
Good numbers, however not that relevant for this thread
Old Apr 17, 2010 | 12:18 AM
a33_ridah's Avatar
for all the people that refer to seafoam on there...
a question for you..
from what i recall one time looking at it in the store the mfg of seafoam recommends spark plugs be changed after seafoaming as contaminants may clog on the plugs.
in our vq's this is not fun...
seafoam=plug change??
Old Apr 17, 2010 | 05:17 AM
DCZC's Avatar
Not sure about the plugs, but since my thread was bumped; After runnung some seafoam through the gas(havent done the seafoam intake treatment yet) and adding a drop in aFe filter I'm averaging 25.75-26.8 mpg per tank. 80/20 driving
Old Apr 17, 2010 | 09:19 AM
NYCMaxima01's Avatar
i am olny geting 200 to the tank if i am lucky on a 2001 auto maxima can someone hep me what i can do to get more miles
Old Apr 17, 2010 | 04:28 PM
rock_it2183's Avatar
From full tank to light I can get approx 400 miles out of a tank. Thats also about 90% highway at 65-75mph. fyi- 00 max w/ auto tranny, all stock...and in need of several repairs.
Old Apr 19, 2010 | 07:11 AM
kukx30de's Avatar
01 GLE Auto... 189K miles... generally 24-26 in a mix of city/hwy driving... Highway only probably upper 26 lower 27.... occasional 28.. Never seen 30 LOL but I do have 150lbs of Mass Loaded Vinyl to make my Max more quiet than those es300's out there!
Old May 5, 2010 | 10:59 PM
rayac88's Avatar
2000 gxe auto. average mixed driving 21-22 mpg. going 45-55 on long trips i get 27-29 mpg. city is killing me probably on at 18-19 mpg. sea foam the gas every couple thousand miles tires close to 40 with 18's
Old May 5, 2010 | 11:40 PM
PBMAXX's Avatar
2000 Maxima SE I average 330 to 350 city. No highway miles yet. I have 230k on my Max. ...no mods yet.
Old May 6, 2010 | 03:03 AM
01-maxima-24's Avatar
2001 Maxima SE Auto- 120k miles- On a recent trip to Six Flags I averaged 24.4 mpg on about 80-85% highway driving. Only mods are a Jim Wolf pop charger intake and a basic home made grounding kit. I also have the CEL on because of Catalyst Efficiency or something so im sure it can get a little better. At one point I was getting about 15 mpg because I had 2 bad O2 sensors and 2 bad coils.
mclasser
22
Nov 12, 2020 01:58 PM
maxinout93
Oct 31, 2015 02:04 AM
ef9
Oct 4, 2015 08:43 AM
